Home » Archived » BIRT » Compare value in detail row
icon4.gif  Compare value in detail row [message #692828] Tue, 05 July 2011 06:12 Go to next message
In my report I have a table with a detail row with the value
dataSetRow["step"]
I want to number my rows with the following rule:
row.__rownum*10+400 (400, 410, 420, ...)
But if the value of dataSetRow["step"] is the same as the row before, the row number has also have the same number.
Can I create such like:
if (dataSetRow["stap"] == previous.dataSetRow["stap"])
rownum = previous.rownum
I hope i've descriped my problem clear on this way.
Re: Compare value in detail row [message #692991 is a reply to message #692828] Tue, 05 July 2011 11:14 Go to previous messageGo to next message
There is a previous row aggregate function extension example on birt
exchange that could be used to show you how to implement your own
aggregate function.
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1103-aggregate-function-to-subtract-previous-row-value/
Or you could do it all in a data item expression like:
importPackage(Packages.java.lang);
var rwc = 0;
if( reportContext.getGlobalVariable("last") == null ){
rwc = row.__rownum*10+400
reportContext.setGlobalVariable("last", new
Integer(dataSetRow["ORDERNUMBER"]));
reportContext.setGlobalVariable("lastrwc", new Integer(rwc));
}else{
if( parseInt(reportContext.getGlobalVariable("last")) ==
dataSetRow["ORDERNUMBER"] ){
rwc = reportContext.getGlobalVariable("lastrwc");
}else{
rwc;
See attached example.
Jason
> dataSetRow["step"]
Re: Compare value in detail row [message #693339 is a reply to message #692991] Wed, 06 July 2011 05:39 Go to previous message
Thank you!
This is the solution, it works.
Smile
Previous Topic:(no subject)
Next Topic:java.lang.NullPointerException after shutdown platform
Current Time: Sun Jul 20 15:59:20 EDT 2025
Powered by FUDForum. Page generated in 0.04724 seconds
