Home » Modeling » TMF (Xtext) » Inject a different StaticMethodsFeatureForTypeProvider
Inject a different StaticMethodsFeatureForTypeProvider [message #692217] Sun, 03 July 2011 19:53 Go to next message
Originally posted by:
I extend the Xbase grammar and with the XbaseGeneratorFragment i get a
ScopeProvider that extends XbaseScopeProvider. In this class, a
StaticMethodsFeatureForTypeProvider gets injected with
@Inject
private Provider<StaticMethodsFeatureForTypeProvider>
implicitStaticFeatures;
I want to inject a different instance (my own one), and guess this
should be possible using some trick in my RuntimeModule. I have tried
the following:
@Provides
public
org.eclipse.xtext.xbase.scoping.featurecalls.StaticMethodsFeatureForTypeProvider
provideStaticMethodsFeatureForTypeProvider() {
return new StaticMethodsFeatureForTypeProvider(); // this is my own
class, not the existing Xbase one
This works, but the values that should be injected into this instance
aren't! I think that I somehow must make the Injector create the
StaticMethodsFeatureForTypeProvider, but I don't know how! Can someone
can enlighten me!
Hallvard
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692218 is a reply to message #692217] Sun, 03 July 2011 19:59 Go to previous messageGo to next message
I think I found the answer:
public void configure(Binder binder) {
super.configure(binder);
binder.bind(org.eclipse.xtext.xbase.scoping.featurecalls.StaticMethodsFeatureForTypeProvider.class).to(StaticMethodsFeatureForTypeProvider.class);
I hope!
Hallvard
On 04.07.11 01.53, Hallvard Trætteberg wrote:
> @Inject
> the following:
> @Provides
> public
> can enlighten me!
> Hallvard
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692221 is a reply to message #692217] Sun, 03 July 2011 19:59 Go to previous messageGo to next message
I hope!
Hallvard
> @Inject
> the following:
> @Provides
> public
> can enlighten me!
> Hallvard
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692329 is a reply to message #692218] Mon, 04 July 2011 04:25 Go to previous messageGo to next message
Don't mix up Guice's Provider<?> concept with your SMFFTProvider!
To change the binding for a specific interface type, it should be enough
to write
Class<? extends interfaceType> bind<interfaceType>() {
return YourImplType.class;
So in your case
Class<? extends StaticMethodsFeatureForTypeProvider>
bindStaticMethodsFeatureForTypeProvider() {
return <your impl>.class;
Guice's Provider<?> enables you to get multiple instances of the type by
calling get(). It relies on default constructors or constructors with
injected parameters only. Explicit binding of a Guice Provider<?> should
only be necessary if you want to customize the instantiation /
initialization behavior, e.g. when wrapping a external singleton such as
the workspace or the workbench.
Am 04.07.11 01:59, schrieb Hallvard Trætteberg:
> @Override
> I hope!
> Hallvard
>> Hi,
>> @Inject
>> the following:
>> @Provides
>> public
>> can enlighten me!
>> Hallvard
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692361 is a reply to message #692329] Mon, 04 July 2011 05:37 Go to previous messageGo to next message
> to write
> So in your case
I think I understand this. However, XbaseScopeProvider declares a
provider of a provider class:
@Inject
And it uses get to get a new instance:
protected StaticMethodsFeatureForTypeProvider
newImplicitStaticFeaturesProvider() {
return implicitStaticFeatures.get();
Hence, I thought I needed to make the default creation use my
StaticMethodsFeatureForTypeProvider class instead of Xbase's.
Correct me if I'm wrong.
Hallvard
>> @Override
>> I hope!
>> Hallvard
>>> Hi,
>>> @Inject
>>> the following:
>>> @Provides
>>> public
>>> can enlighten me!
>>> Hallvard
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692412 is a reply to message #692361] Mon, 04 July 2011 07:37 Go to previous messageGo to next message
Using a Guice Provider<>or not is usually the client's choice.
You need to *bind* a Guice Provider<> only if you want to change Guice's
default instantiation strategy.
Am 04.07.11 11:37, schrieb Hallvard Trætteberg:
>> to write
>> So in your case
> @Inject
> Hallvard
>>> @Override
>>> I hope!
>>> Hallvard
>>>> Hi,
>>>> @Inject
>>>> the following:
>>>> @Provides
>>>> public
>>>> can enlighten me!
>>>> Hallvard
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692446 is a reply to message #692412] Mon, 04 July 2011 08:42 Go to previous messageGo to next message
In this case XbaseScopeProvider has made the choice to use a Provider<>,
so I believe I must comply with it.
I think the default strategy for a Provider<X> is to instantiate X,
while I want it to instantiate a specific subclass.
Anyway, it works, so I'm happy!
Hallvard
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692450 is a reply to message #692446] Mon, 04 July 2011 09:09 Go to previous messageGo to next message
i already wanted to file a bug for this since such copy und paste subclasses of XbaseScopePRovider just to add some more methods to the StaticMethodsFeatureForTypeProvider is annoying. and StaticMethodsFeatureForTypeProvider is not easyly subclassable / extendable too.
~Christian
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692470 is a reply to message #692446] Mon, 04 July 2011 09:46 Go to previous messageGo to next message
Am 04.07.11 14:42, schrieb Hallvard Trætteberg:
No, as I said, it's the clients choice (the one who gets the component
injected). You just bind an implementation class to an interface or
class. The latter is what the client uses as its API to access this
service. So if a client wants a
@Inject
it gets a Guice Provider that delivers objects whose type is assignable
to StaticMethodsFeatureForTypeProvider. Any subtype or the type itself
will do. It doesn't matter that StaticMethodsFeatureForTypeProvider is a
class and not an interface. The only difference is that we don't have to
bind a default implementation in this case, as the class itself is bound
by default. You can override that default binding using the same
mechanism as for an interface binding.
No, Guice creates an instance of the class that is bound to the specific
interface type. This binding is what you want to change. By default
instantiation strategy I meant calling the default constructor or the
one with only injected parameters.
> Hallvard
Maybe it is a good idea to re-read the documentation on dependency
injection now, and get more familiar with Guice?
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692518 is a reply to message #692470] Mon, 04 July 2011 12:15 Go to previous messageGo to next message
> @Inject
As follows, you mean:
public Class<? extends
org.eclipse.xtext.xbase.scoping.featurecalls.StaticMethodsFeatureForTypeProvider>
return no.hal.ecoretypes.x.StaticMethodsFeatureForTypeProvider.class;
>> Hallvard
I tend to read just enough to get things done. In this case, the
strategy I used worked, but wasn't the cleanest solution. Over time,
misunderstandings like this will be fewer, partly thanks to patient
experts like you!
Hallvard
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692519 is a reply to message #692450] Mon, 04 July 2011 12:19 Go to previous messageGo to next message
> extendable too.
I agree. I have also extended OperatorMapping, and need some copying &
pasting there, too. In general, it's difficult to imagine what parts
that will need to be extended using subclassing, and hence, design a
nice and extendable API.
My example project will give me some experience in extending Xbase, and
will hopefully result in some feedback about what parts are easily
extendable and how things can be improved.
Hallvard
Re: Inject a different StaticMethodsFeatureForTypeProvider [message #692852 is a reply to message #692518] Tue, 05 July 2011 06:52 Go to previous message
Am 04.07.11 18:15, schrieb Hallvard Trætteberg:
>> @Inject
Exactly.
>>>> Guice's
>>> Hallvard
> experts like you!
> Hallvard
No problem. I was just starting to get a bit impatient :-)
Previous Topic:Beginner grammar problem
Next Topic:Flatten xtext grammar & ui projects?
Current Time: Sat Jul 19 13:52:20 EDT 2025
Powered by FUDForum. Page generated in 0.06527 seconds
