Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TEXO] Java errors in generated code
[TEXO] Java errors in generated code [message #691182] Thu, 30 June 2011 18:25 Go to next message
Just started using Texo and noticed that the Java code generated by texo for our ecore model uses the same casified name in the model for the "Valid Java Member Name". This leads to self-reference errors in a case like this:
private Origin Origin = Origin.NOTSET;
Origin is a EEnum type and "Origin" is used as the model field name.
Our workaround is to edit the annotation for each such model and change the "Valid Java Member Name" to be all lower case. This can be quite a pain in a large model.
It would be nice if Texo had an option to use all lowercase names for Java Members or some other convention to ensure the member names are not the same as the class names.
mike
Re: [TEXO] Java errors in generated code [message #691409 is a reply to message #691182] Fri, 01 July 2011 07:55 Go to previous messageGo to next message
Hi Mike,
I am working on a new build which solves this, will probably be published late today.
gr. Martin
> Cheers,
> mike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TEXO] Java errors in generated code [message #691432 is a reply to message #691182] Fri, 01 July 2011 08:43 Go to previous messageGo to next message
I published a new build which should solve this, can you give it a try?
You need to regenerate the orm.xml.
gr. Martin
> Cheers,
> mike
The Netherlands
Re: [TEXO] Java errors in generated code [message #691551 is a reply to message #691432] Fri, 01 July 2011 13:41 Go to previous messageGo to next message
Hi Martin,
You're behind Texo too? You are a very, very busy guy. Smile
Tried to update in eclipse but got update errors:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Artifact not found: osgi.bundle,org.eclipse.emf.texo,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo_0.1.0.v201107011214.jar
Problems downloading artifact: osgi.bundle,org.eclipse.emf.texo.generator,0.1.0.v201107011214.
MD5 hash is not as expected. Expected: 0d7a841b3fac2cb1ddc1cd5d4cea33f9 and found a6db9e2b43501d0c9187740e37cd69bf.
Artifact not found: osgi.bundle,org.eclipse.emf.texo.modelgenerator,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.modelgenerator_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.modelgenerator.edit,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.modelgenerator.edit_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.modelgenerator.edit.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.modelgenerator.edit.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.modelgenerator.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.modelgenerator.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.orm,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.orm_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.orm.edit,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.orm.edit_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.orm.edit.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.orm.edit.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.orm.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.orm.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.xml,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.xml_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.xml.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.xml.source_0.1.0.v201107011214.jar
Re: [TEXO] Java errors in generated code [message #691581 is a reply to message #691551] Fri, 01 July 2011 14:59 Go to previous message
Indeed quite busy :-)...
I get the same error, I tried a new build but something fails on the eclipse.org hudson build infrastructure. I will try
again later and send a reply to this thread again.
gr. Martin
On 07/01/2011 07:41 PM, Mike Cooper wrote:
> Hi Martin,
> You're behind Texo too? You are a very, very busy guy. :)
> action=).
The Netherlands
Previous Topic:[EEF] Issue with
Next Topic:[TEXO/Hibernate] Help with AnnotationException: No identifier specified
Current Time: Sat Jul 19 20:52:25 EDT 2025
Powered by FUDForum. Page generated in 0.45699 seconds
