Home » Modeling » OCL » Create Influence Diagram from OCL Statement
Re: Create Influence Diagram from OCL Statement [message #691474 is a reply to message #691451] |
Fri, 01 July 2011 10:20   |
I have one confusion from the documentation page, below is the chunk of code from documentation page.
final OCLExpression e = ...;
final ImpactAnalyzer impactAnalyzer = ImpactAnalyzerFactory.INSTANCE.createImpactAnalyzer(
e, // the expression to re-evaluate incrementally
false, // whether to re-evaluate when new context objects appear
OCLFactory.INSTANCE);
here OCLExpression is org.eclipse.ocl.ecore.OCLExpression and normally it is used for AbtractVisitor class
and org.eclipse.ocl.expressions.OCLExpression is another class which is used to parse OCL statements like
OCL<?, EClassifier, EOperation, ?, ?, ?, ?, ?, ?, Constraint, EClass, EObject> ocl;
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
OCLHelper<EClassifier, EOperation, ?, Constraint> helper = ocl.createOCLHelper();
helper.setContext(eClass);
OCLExpression<EClassifier> query = helper.createQuery(attribute.getpOCLStatement());
Why impact analyzer is using org.eclipse.ocl.ecore.OCLExpression and do this mean i have to extend AbstractVisitor or some other to get object of org.eclipse.ocl.ecore.OCLExpression ?
how can i get org.eclipse.ocl.ecore.OCLExpression object?
please help
Warmest Regards
Re: Create Influence Diagram from OCL Statement [message #691490 is a reply to message #691474] |
Fri, 01 July 2011 11:00  |
Yes. These templates are very confusing, which is why a prototype new
approach with no templates is available in the examples plugins
awaiting promotion in the Juno release.
org.eclipse.ocl.ecore.OCLExpression extends
org.eclipse.ocl.OCLExpression<EClassifier>
and
org.eclipse.ocl.uml.OCLExpression extends
org.eclipse.ocl.OCLExpression<Classifier>
so the templated classes give shared Ecore/UML functionality. Only one
of the two can be imported, the
other must be explicitly qualified.
I recommend always importing the untemplated versions and qualifying the
templated ones. Most of the
time you can use the untemplated classes, and I suspect that half of
your quoted example can be simplified in this way.
Unfortunately return values from shared functionality do not return
untemplated classes; you can safely cast them.
Ed Willink
On 01/07/2011 16:20, forums-noreply@eclipse.org wrote:
> EObject> ocl;
> please help
> Warmest Regards
Current Time: Sat Jul 19 21:58:38 EDT 2025
Powered by FUDForum. Page generated in 0.30238 seconds
