Home » Eclipse Projects » Rich Client Platform (RCP) » make external jar to plugin into my rcp application
icon9.gif  make external jar to plugin into my rcp application [message #689652] Tue, 28 June 2011 01:53 Go to next message
Can anyone help me to resolve this question?
My rcp application need some external jars, for example, analysis xml jars: dom4j.jar, jaxen-1.1.1.jar. I don't want add them to my rcp application bulid path.
So I make jars to a plugin (new > Project > Plug-in from existing jar archives), then add this plugin to my rcp application, run application has a error:
Warning: Caught exception attempting to use SAX to load a SAX XMLReader
org.xml.sax.SAXException: Can't create default XMLReader; is system property org.xml.sax.driver set?
Warning: Exception was: org.xml.sax.SAXException: Can't create default XMLReader; is system property org.xml.sax.driver set?
Warning: I will print the stack trace then carry on using the default SAX parser
at org.xml.sax.helpers.XMLReaderFactory.createXMLReader(XMLReaderFactory.java:155)
at org.dom4j.io.SAXHelper.createXMLReader(SAXHelper.java:67)
at org.dom4j.io.SAXReader.createXMLReader(SAXReader.java:650)
at org.dom4j.io.SAXReader.getXMLReader(SAXReader.java:525)
at org.dom4j.io.SAXReader.read(SAXReader.java:311)
at org.dom4j.io.SAXReader.read(SAXReader.java:264)
at tjkj.sfm.client.update.Site.<init>(Site.java:59)
at tjkj.sfm.client.update.Site.getInstance(Site.java:38)
at tjkj.sfm.client.update.InstallOperation.hasUpdate(InstallOperation.java:43)
at tjkj.sfm.client.windows.LogonDialog.checkUpdate(LogonDialog.java:232)
at tjkj.sfm.client.windows.LogonDialog.access$9(LogonDialog.java:231)
at tjkj.sfm.client.windows.LogonDialog$7$1.run(LogonDialog.java:430)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3425)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:172)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:370)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
at tjkj.sfm.client.custom.RunnableTask.run(RunnableTask.java:28)
at tjkj.sfm.client.windows.LogonDialog.okPressed(LogonDialog.java:471)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:472)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at tjkj.sfm.client.Application.start(Application.java:46)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
Warning: Error occurred using SAX to load a SAXParser. Will use Aelfred instead
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Thanks a lot~
Re: make external jar to plugin into my rcp application [message #689696 is a reply to message #689652] Tue, 28 June 2011 03:52 Go to previous messageGo to next message
I think the problem is not with the rcp application, it is with the code written for the xml parser. Have you tried writing vanilla application for the xml parser lib that you are using.
Re: make external jar to plugin into my rcp application [message #690120 is a reply to message #689696] Tue, 28 June 2011 22:41 Go to previous messageGo to next message
But I add jars to my rcp application build path,it's run ok.
I tried another way:
new > project > plugin project, add these jars to plugin project build path, then at plugin.xml "runtime" tab exported packages.
Add plugin project to my rcp application, it's run ok.(before this step, I run plugin project is ok too).
But when I export project, has an error log file:
The import org.dom4j cannot be resolved
Re: make external jar to plugin into my rcp application [message #690319 is a reply to message #690120] Wed, 29 June 2011 07:24 Go to previous messageGo to next message
This might be due to configuration Manifest file. Please ensure that you have added required plugins in the Require-Bundle attribute.
Require-Bundle: org.dom4j;bundle-version="1.0.0"
Re: make external jar to plugin into my rcp application [message #692252 is a reply to message #690319] Mon, 04 July 2011 00:04 Go to previous message
I'm sure I did it, it's still has that error.
I create a plugin project, then add this plugin project to my rcp application. it's run ok, but when I export project has an error file:
"The import org.dom4j cannot be resolved"...
But another way:
I create a plugin project, and export this plugin project to a jar, then delete this plugin project from my workspace, and add plugin jar to eclipse plugin directory, restart eclipse, add plugin to my rcp application, it has a compiler error, org.dom4j
can not found.
why?
Previous Topic:(no subject)
Next Topic:Toolbar and commands interaction
Current Time: Sun Jul 20 15:52:12 EDT 2025
Powered by FUDForum. Page generated in 0.03317 seconds
