Virgo Kernel turns off MBeanServer creation [message #688776] |
Sat, 25 June 2011 13:34  |
Settings:
virgo-kernel-3.0.0.M05, activemq-5.5.0, window 7 professional 64-bit
Commands to fire up virgo: startup.bat -clean -jmxport 1099
Problem:
I created a bundle imgs-bootstrap-1.0.0 to embed activemq inside virgo-kernel.
it appeared that embedded activemq's jmx connector was not completed, because ActiveMQ.Advisory.Topic is missed
However, Jconsole can access embedded activemq instance through JMX URL as service:jmx:rmi:///jndi/rmi://localhost:1099/jmxrmi
Solution:
I would like to turn off Virgo's creating Mbeanserver, so let Activemq take over task of creation of MBeanserver so that I could find the root cause of lacking of advisory support in activemq embedded in osgi container
Below screenshot showed in Jconsole under org.apache.activemq.localhost.Topic, ActiveMQ.Advisory.Topic is missed.
Following is log of virgo kernel console complained about java.rmi.AccessException: Cannot modify this registry
[2011-06-25 08:18:08.351] region-dm-4 <> Load-time weaving not enabled for bundle 'multi-artifact.plan-1-imgs-bootstrap_1.0.0 [76]',
[2011-06-25 08:18:08.354] region-dm-4 <> MBean exporting not enabled for bundle 'multi-artifact.plan-1-imgs-bootstrap_1.0.0 [76]',
[2011-06-25 08:18:08.377] region-dm-4 <> No outstanding OSGi service dependencies, completing initialization for OsgiBundleXmlApplica
tionContext(bundle=multi-artifact.plan-1-imgs-bootstrap, config=osgibundle:/META-INF/spring/*.xml)
[2011-06-25 08:18:08.384] region-dm-5 <> Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBea
nFactory@445aa997: defining beans [org.springframework.beans.factory.config.PropertyPlaceholderConfigurer#0,org.apache.activemq.xbean.XBeanBrokerServi
ce#0,activemqConnectionFactory,pooledConnectionFactory,resourceManager,DlbOutDestination,specialListener,specialLogger,DlbOutContainer]; root of facto
ry hierarchy
[2011-06-25 08:18:08.494] region-dm-5 <> PListStore:C:\activemq\localhost\localhost\tmp_storage started
[2011-06-25 08:18:08.712] region-dm-5 <> Using Persistence Adapter: KahaDBPersistenceAdapter[C:\activemq\localhost\kahadb]
[2011-06-25 08:18:08.768] JMX connector <> Failed to start jmx connector: Cannot bind to URL [rmi://localhost:1099/jmxrmi]: javax.namin
g.NoPermissionException [Root exception is java.rmi.ServerException: RemoteException occurred in server thread; nested exception is:
java.rmi.AccessException: Cannot modify this registry]
[2011-06-25 08:18:09.148] region-dm-5 <> KahaDB is version 3
[2011-06-25 08:18:09.178] region-dm-5 <> Recovering from the journal ...
[2011-06-25 08:18:09.182] region-dm-5 <> Recovery replayed 4 operations from the journal in 0.019 seconds.
[2011-06-25 08:18:09.193] region-dm-5 <> ActiveMQ 5.5.0 JMS Message Broker (localhost) is starting
[2011-06-25 08:18:09.195] region-dm-5 <> For help or more information please see: http://activemq.apache.org/
[2011-06-25 08:18:09.491] JMX connector <> Failed to start jmx connector: Cannot bind to URL [rmi://localhost:1099/jmxrmi]: javax.namin
[2011-06-25 08:18:09.532] region-dm-5 <> Listening for connections at: tcp://Squilchuck:61616
[2011-06-25 08:18:09.535] region-dm-5 <> Connector openwire Started
[2011-06-25 08:18:09.540] region-dm-5 <> ActiveMQ JMS Message Broker (localhost, ID:Squilchuck-55156-1309015089220-0:1) started
[2011-06-25 08:18:09.562] region-dm-5 <> Resource manager is unrecoverable due to missing classes: java.lang.NoClassDefFoundError: or
g/apache/geronimo/transaction/manager/NamedXAResource
[2011-06-25 08:18:09.595] region-dm-5 <> Starting beans in phase 2147483647
[2011-06-25 08:18:09.712] region-dm-5 <> Publishing application context as OSGi service with properties {org.springframework.context.
service.name=multi-artifact.plan-1-imgs-bootstrap, Bundle-SymbolicName=multi-artifact.plan-1-imgs-bootstrap, Bundle-Version=1.0.0}
[2011-06-25 08:18:09.717] region-dm-5 <> Sending event to topic 'org/osgi/service/blueprint/container/CREATED' with properties '{bund
le.version=1.0.0, bundle=multi-artifact.plan-1-imgs-bootstrap_1.0.0 [76], bundle.symbolicName=multi-artifact.plan-1-imgs-bootstrap, type=1, timestamp=
1309015089717, bundle.id=76}'
[2011-06-25 08:18:09.723] region-dm-5 <> Handling event 'org.osgi.service.event.Event [topic=org/osgi/service/blueprint/container/CRE
ATED]'
[2011-06-25 08:18:09.726] region-dm-5 <> Recording created application context for bundle 'multi-artifact.plan-1-imgs-bootstrap_1.0.0
[76]'
[2011-06-25 08:18:09.730] region-dm-5 <> Application context successfully refreshed (OsgiBundleXmlApplicationContext(bundle=multi-art
ifact.plan-1-imgs-bootstrap, config=osgibundle:/META-INF/spring/*.xml))
[2011-06-25 08:18:09.730] start-signalling-2 <> Driving signal 'org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$S
tateMonitorSignal@771c7eb2'
[2011-06-25 08:18:09.738] start-signalling-2 <> Thread context class loader 'KernelBundleClassLoader: [bundle=org.springframework.osgi.io_1.
2.1]' pushed and set to 'KernelBundleClassLoader: [bundle=multi-artifact.plan-1-imgs-bootstrap_1.0.0]'
[2011-06-25 08:18:09.742] start-signalling-2 <DE0005I> Started bundle 'multi-artifact.plan-1-imgs-bootstrap' version '1.0.0'.
[Updated on: Sat, 25 June 2011 15:51] by Moderator
Re: Virgo Kernel turns off MBeanServer creation [message #690218 is a reply to message #690073] |
Wed, 29 June 2011 03:47  |
Ming Qin wrote on Tue, 28 June 2011 23:57Glyn:
thanks for your reply.
I made a few changes on my bundle's configuration on activemq, ActiveMQ.Advisory.Topic appears on my Jconsole and activemq web console get started in another JVM also works fine, though my bundle which embedded activemq broker started with error messages
[2011-06-28 15:26:42.632] JMX connector <> Failed to start jmx connector: Cannot bind to URL [rmi://localhost:1099/jmxrmi]: javax.naming.
I don't think Virgo is doing anything to provoke this exception.
My experiment approved that virgo kernel could be a versatile microkernel for applications employing transport protocol like activemq.
Should Virgo has a release as "Virgo Message Broker" based on activemq?
Potentially, but the current set of committers have no particular ActiveMQ skills and there are other queue managers that others might want to run under Virgo (IBM MQ Series, RabbitMQ, ...), so unless someone steps forward with the skills and drive to construct such a release, it probably won't happen.
A step in that direction would be for you to write up your experience for the benefit of others, perhaps in one or more blog posts.
FUDForum. Page generated in 0.06758 seconds
