Home » Modeling » EMF » OPTION_ESCAPE_USING_CDATA
OPTION_ESCAPE_USING_CDATA [message #687381] Fri, 03 June 2011 23:44 Go to next message
I have an Ecore model with an EAttribute named "rule" that is typed to EString. I am using the default XMI serialization which makes it an XML attribute. I want to use this feature to store XQuery which may contain XML content and special characters.
I added an EAnnotation with source set to ExtendedMetaData and kind => 'element'. Then I set default load/save options to OPTION_USE_EXTENDED_META_DATA to true. Additionally, I set save options for OPTION_ESCAPE_USING_CDATA and OPTION_SKIP_ESCAPING to true. So everything appears to be set up correctly. My expectation is that the XQuery will remain "as-is" containing unescapted '<' and '>' characters, etc. However, I am still seeing these types of special characters getting escaped.
What criteria does the deserializer use to insert <![CDATA[ ]]>?
Is there anything that I can do to ensure that what gets serialized remains "as-is"?
JT
[Updated on: Fri, 24 June 2011 13:01] by Moderator
Re: OPTION_ESCAPE_USING_CDATA [message #687382 is a reply to message #687381] Sat, 04 June 2011 00:10 Go to previous messageGo to next message
John,
Is it coming out as an element? You can see the option being used in
convertText; it's called by getDatatypeValue for element content...
> remains "as-is"?
> JT
Re: OPTION_ESCAPE_USING_CDATA [message #688422 is a reply to message #687382] Fri, 24 June 2011 12:46 Go to previous messageGo to next message
Ed,
It does appear to be coming out correctly (if deserliaze and invoke the getRule() method). The serialized version of the document, however, does not use CDATA, instead it excapes all the XML "special" characters (even iwth the options set as mentioned above). Any ideas?
JT
Re: OPTION_ESCAPE_USING_CDATA [message #688438 is a reply to message #688422] Fri, 24 June 2011 13:25 Go to previous messageGo to next message
Ed,
I looked at XMLSaveImpl and did some more experiments. What I found was that there is a conflict between OPTION_ESCAPE_USING_CDATA and OPTION_IGNORE_ESCAPE. So I got rid of the second option and the XMLSaveImpl.Escape class does what I would expect and puts things in CDATA sections when they contain special chararcters. However, to complicate things, I found that this does not work when I serialize to DOM. I'm still investigating why there is no createCDATASection in there when toDOM is true.
JT
Re: OPTION_ESCAPE_USING_CDATA [message #688488 is a reply to message #688438] Fri, 24 June 2011 15:27 Go to previous messageGo to next message
To get it to work when serializing to DOM, I actually had to override the default XMISaveImpl implementation as follows:
public class MyCustomXMISaveImpl extends XMISaveImpl {
	private Escape domEscape = null;
	public MyCustomXMISaveImpl(XMLHelper helper) {
		super(helper);
	protected void init(XMLResource resource, Map<?, ?> options) {
	    super.init(resource, options);
	    if (toDOM) {
	    	domEscape = new Escape();
	    	domEscape.setUseCDATA(true);
	protected void saveElement(EObject o, Object value, EStructuralFeature f) {
		if (value == null) {
			saveNil(o, f);
		} else {
			String svalue = getDatatypeValue(value, f, false);
			if (!toDOM) {
				doc.saveDataValueElement(helper.getQName(f), svalue);
			} else {
				helper.populateNameInfo(nameInfo, f);
				Element elem = document.createElementNS(nameInfo.getNamespaceURI(), nameInfo.getQualifiedName());
				// BEGIN: CDATA handling code
				Node text = null;
				String converted = domEscape.convertText(svalue);
				if (converted != null && converted.startsWith("<![CDATA[")) {
					text = document.createCDATASection(svalue);
				} else {
					text = document.createTextNode(svalue);
				// END: CDATA handling code
//				Node text = document.createTextNode(svalue);
				elem.appendChild(text);
				currentNode.appendChild(elem);
				handler.recordValues(elem, o, f, value);
				handler.recordValues(text, o, f, value);
Kind of a hack, but it works. Though I'm not sure that it works for *all* cases.
JT
[Updated on: Fri, 24 June 2011 15:57] by Moderator
Re: OPTION_ESCAPE_USING_CDATA [message #688513 is a reply to message #688488] Fri, 24 June 2011 16:38 Go to previous message
John,
I see. It would seem good for it to be supported for the DOM case too...
> public MDMISaveImpl(XMLHelper helper) {
> super(helper);
> @Override
> if (toDOM) {
> @Override
> saveNil(o, f);
> } else {
> if (!toDOM) {
> } else {
> Element elem =
> Node text = null;
> } else {
> Kind of a hack, but it works. I'm also not sure if it works for *all*
> cases.
> JT
Previous Topic:[2.3M5] Problems validating Ecore models
Next Topic:(no subject)
Current Time: Sat Jul 19 20:57:31 EDT 2025
Powered by FUDForum. Page generated in 0.03952 seconds
