Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFIndex still an active projecct?
EMFIndex still an active projecct? [message #688079] Thu, 23 June 2011 17:27 Go to next message
I'm looking for a way to index my Ecore files so I can run searches. I found the EMFIndex project and page says its work in progress but the last meeting note are from Dec 09. Is there something that replaced it? Or is it a dead project?
http://www.eclipse.org/emfindex/
Roshan
(no subject) [message #688127 is a reply to message #688079] Thu, 23 June 2011 20:46 Go to previous messageGo to next message
Roshan,
It's terminally ill right now.
> Roshan
Re: EMFIndex still an active projecct? [message #688160 is a reply to message #688079] Thu, 23 June 2011 23:40 Go to previous messageGo to next message
Hi Roshan,
As Ed mentioned EMF Index is inactive now.
You can try using EMF Query2.Query2 comes with an in built index engine.
This index engine will help you to index your files.Plus the index comes with few convenient index queries which will aid you to search.
http://wiki.eclipse.org/EMF/Query2
On addition to this you can check Querying mechanism, where a simple search string like 'from Library as lib select lib' will yield you the results from the index.
cheers,
Saurav
(no subject) [message #688405 is a reply to message #688160] Fri, 24 June 2011 12:09 Go to previous messageGo to next message
Saurav,
Yes, both Query2 and Xtext independently provide indexers. I imagine in
the future there will be folks who want to query their Xtext serialized
models and they'll question why their stuff needs to be indexed twice....
saurav wrote:
> Hi Roshan,
> cheers,
> Saurav
Re: EMFIndex still an active projecct? [message #689276 is a reply to message #688079] Mon, 27 June 2011 06:13 Go to previous messageGo to next message
Hi Ed,
Well, having a common index and hence avoidance of duplicatie indexing would have helped.Right now we can have a separate adapter (query storage processor) for Xtext if required and let that processor decide which index to use.
Saurav
(no subject) [message #689436 is a reply to message #689276] Mon, 27 June 2011 12:23 Go to previous messageGo to next message
Saurav,
Cool. That's a good idea.
On 27/06/2011 3:13 AM, saurav wrote:
> Hi Ed,
> which index to use.
> Cheers,
> Saurav
(no subject) [message #689466 is a reply to message #689436] Mon, 27 June 2011 13:02 Go to previous messageGo to next message
Perhaps after Juno, when EMF Query and Xtext requirements are
established, it may be possible to merge the two competing solutions,
since the costs of duplicate indexing are imposed on all modeling users
that even indirectly exploit these two tools.
Ed Willink
On 27/06/2011 18:23, Ed Merks wrote:
> Saurav,
>> Hi Ed,
>> Cheers,
>> Saurav
(no subject) [message #689514 is a reply to message #689466] Mon, 27 June 2011 14:43 Go to previous messageGo to next message
Ed,
It's possible, but as I understand it, no one is particularly motivated
to do it.
On 27/06/2011 10:02 AM, Ed Willink wrote:
> Hi
> users that even indirectly exploit these two tools.
> Regards
> Ed Willink
>> Saurav,
>>> Hi Ed,
>>> Cheers,
>>> Saurav
Re: (no subject) [message #689534 is a reply to message #689514] Mon, 27 June 2011 15:27 Go to previous messageGo to next message
Saurav,
Does Query2 work with Eclipse 3.5? I saw your presentation on http://www.slideshare.net/sauravsarkar/query2-eclipse-day and after installing Query2 I'm not able to get some of the preferences and the query tools as you have in your presentation. I also can't install the query2 examples.
Roshan
UPDATE-So I did end up moving to 3.6.2 and I was now able to see the preferences for Query2 and Index View, Query View, etc. However, when updating through the update site for Query2 I get an error when I try to add EMF Query2 Tests and Examples. I'm missing the library swtbot:
Cannot complete the install because one or more required items could not be found.
Software being installed: Query2 Tests 1.0.0.201105300149 (org.eclipse.emf.query2.test.feature.feature.group 1.0.0.201105300149)
Missing requirement: org.eclipse.emf.query2.index.ui.test 1.0.0.201105300149 requires 'bundle org.eclipse.swtbot.eclipse.core 2.0.4' but it could not be found
Cannot satisfy dependency:
From: Query2 Tests 1.0.0.201105300149 (org.eclipse.emf.query2.test.feature.feature.group 1.0.0.201105300149)
To: org.eclipse.emf.query2.index.ui.test [1.0.0.201105300149]
Once I added the update site for SWTBOT http://download.eclipse.org/technology/swtbot/helios/dev-build/update-site I was good to go.
[Updated on: Mon, 27 June 2011 18:29] by Moderator
Re: (no subject) [message #689651 is a reply to message #689534] Tue, 28 June 2011 01:53 Go to previous messageGo to next message
Hi Roshan,
Yes the Index View is only supported in 3.6.To be frank we have not tested the same in 3.5 so i am not sure of the incompatiblity.
And yes since Query tests have some UI tests which depends on SWT BOT.
Good to see you are able to work with Query2 now.
Let me know if you face any further problems.
cheers,
Saurav
Re: (no subject) [message #690035 is a reply to message #689651] Tue, 28 June 2011 16:31 Go to previous messageGo to next message
Hi Saurav,
So I'm not sure how to get started on the indexing of my EMF model. I'm working (trying to) through the example http://wiki.eclipse.org/EMF/Query2/DevGuide. I created a new Query Statements Example project with the Library domain model. To setup the indexes am I supposed to add the extension point like in the example?
<extension point="org.eclipse.emf.ecore.extension_parser">
<parser class="com.demo.ResourceFactoryImpl"
type="xml">
</parser>
</extension>
And then implement the org.eclipse.emf.ecore.resource.Resource.Factory as the parser class? I'm a little confused in how to setup the index using QueryBuilder.
I appreciate your help.
-Roshan
Re: (no subject) [message #690301 is a reply to message #690035] Wed, 29 June 2011 06:30 Go to previous message
Hi Roshan,
If you are using the builder then you must have to add your project the index nature.You can add it by right click on the context menu of the project and click on 'Add/Remove Index Nature'.
And yes if you are trying to index any other files apart from xmi you need to add it in the ExtensionToFactory map.
Please open a new thread relating to Query2 in the EMF sub-forum if you have further questions because this thread has already been long enough
and has some generic discussions.
cheers,
Saurav
Previous Topic:[Teneo] Need ClassMetadata but it's not present
Next Topic:[EEF] Stabillity
Current Time: Sat Jul 19 21:04:19 EDT 2025
Powered by FUDForum. Page generated in 0.05242 seconds
