Home » Eclipse Projects » Mylyn » How can I use hudson/jenkins connector ?
How can I use hudson/jenkins connector ? [message #688067] Thu, 23 June 2011 16:27 Go to next message
Hi!
I've just installed Indigo and then I added the hudson connector using "Mylyn connector discovery": the installation went fine but I don't understand how to configure an Hudson repository.
When I select "Add task repository" from "Task repository view" I can select only Bugzilla repostory type... How can I use the hudson integration ?
Thanx
Fabio
[Updated on: Fri, 24 June 2011 00:41] by Moderator
Re: How can I use hudson/jenkins connector ? [message #689242 is a reply to message #688067] Mon, 27 June 2011 04:20 Go to previous message
Ok solved...
In order to user jenkins/hudson integration you should configure your jenkins/hudson server from the build view.
Fabio
Previous Topic:Problems logging in with mylyn
Next Topic:Creole syntax contribution for WikiText
Current Time: Sun Jul 20 08:05:43 EDT 2025
Powered by FUDForum. Page generated in 0.08421 seconds
