Home » Modeling » EMF » [Net4j] Using with ECF and Remote progress monitoring
[Net4j] Using with ECF and Remote progress monitoring [message #687171] Thu, 09 June 2011 09:11 Go to next message
Hi Eike,
I was looking for a possible solution to remote OSGI progress monitoring
(with ECF as our remote provider implementation).
I ended up on an old article on Net4j
(http://thegordian.blogspot.com/2008/12/remoting-with-iprogressmonitor.html)
and it's reference to bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203406 that talks about
using Net4j as a remote service transport provider for ECF.
I see some activity up to last fall on restarting this effort.
So, here's my questions:
1. Do you see Net4j has a good candidate to achieve this remote progress
monitoring in this context?
2. Do you see possible shared advantages (or issues) if the server that
we are connecting to also serves as a CDO Server?
3. How complicated and involved do you estimate the effort to complete
this. We can help but would you be available to mentor if we go that route?
Alain
Re: [Net4j] Using with ECF and Remote progress monitoring [message #687173 is a reply to message #687171] Thu, 09 June 2011 12:29 Go to previous messageGo to next message
Hi Alain,
Comments below...
Am 09.06.2011 15:11, schrieb Alain Picard:
> Hi Eike,
> I was looking for a possible solution to remote OSGI progress monitoring (with ECF as our remote provider implementation).
> I ended up on an old article on Net4j (http://thegordian.blogspot.com/2008/12/remoting-with-iprogressmonitor.html) and it's reference to bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=203406 that talks about using Net4j as a remote service transport provider for ECF.
Neither we nor the ECF team has put much effort in it. I haven't looked at it for years.
> 1. Do you see Net4j has a good candidate to achieve this remote progress monitoring in this context?
Certainly. Net4j is a very flexible and, from a developer perspective, convenient communications solution. And my old blog shows how easy remote progress monitoring can be with it.
> 2. Do you see possible shared advantages (or issues) if the server that we are connecting to also serves as a CDO Server?
Only advantages. From the perspective of a Net4j server CDO is "just" an ISignalProtocol like others, e.g. your own ones. You'll be able to save socket connections because Net4j multiplexes several protocols through a single transport connection.
> 3. How complicated and involved do you estimate the effort to complete this. We can help but would you be available to mentor if we go that route?
What route exactly? What is the goal?
Cheers
/Eike
http://www.esc-net.de
Re: [Net4j] Using with ECF and Remote progress monitoring [message #687174 is a reply to message #687173] Thu, 09 June 2011 14:04 Go to previous messageGo to next message
Thanks Eike
See below
On 6/9/2011 12:29 PM, Eike Stepper wrote:
> Hi Alain,
> Comments below...
>> Hi Eike,
> at it for years.
>> route?
The route of resurrecting the Net4j/ECF provider in a correct way and
implement a remote monitoring solution for those remote OSGI services.
> Cheers
> /Eike
> http://twitter.com/eikestepper
Re: [Net4j] Using with ECF and Remote progress monitoring [message #687175 is a reply to message #687174] Thu, 09 June 2011 14:18 Go to previous message
Am 09.06.2011 20:04, schrieb Alain Picard:
> Thanks Eike
> See below
>> Hi Alain,
>> Comments below...
>>> Hi Eike,
>> at it for years.
>>> route?
> The route of resurrecting the Net4j/ECF provider in a correct way and implement a remote monitoring solution for those remote OSGI services.
I see. Unfortunately I can not afford "gratis time" for this work. Of course I could assist with knowledge about Net4j and the existing (old) integration...
Cheers
/Eike
Re: [Net4j] Using with ECF and Remote progress monitoring [message #687428 is a reply to message #687171] Thu, 09 June 2011 12:29 Go to previous message
Hi Alain,
Comments below...
> Hi Eike,
Cheers
/Eike
Re: [Net4j] Using with ECF and Remote progress monitoring [message #687429 is a reply to message #687173] Thu, 09 June 2011 14:04 Go to previous message
Thanks Eike
See below
> Hi Alain,
> Comments below...
>> Hi Eike,
> at it for years.
>> route?
> Cheers
> /Eike
Re: [Net4j] Using with ECF and Remote progress monitoring [message #687430 is a reply to message #687174] Thu, 09 June 2011 14:18 Go to previous message
> Thanks Eike
> See below
>> Hi Alain,
>> Comments below...
>>> Hi Eike,
>> at it for years.
>>> route?
Cheers
/Eike
Previous Topic:Resource serialization options
Next Topic:CDO Server Deployment
Current Time: Sat Jul 19 21:03:19 EDT 2025
Powered by FUDForum. Page generated in 0.06337 seconds
