Home » Modeling » EMF » [Hibernate] HQL statement for one-to-many
[Hibernate] HQL statement for one-to-many [message #681821] Thu, 09 June 2011 18:42 Go to next message
Got a newbie HQL/SQL question for you all.
I have the following HQL statement
select count(ID) from Asset as asset where asset.StateInfo.MobileProvider.Name='Vodafone'
The Asset->StateInfo reference is one-to-many and the rest are one-to-one. This query generates a QueryException:
org.hibernate.QueryException: illegal attempt to dereference collection [asset0_.`id`.StateInfo] with element property reference [MobileProvider] [select count(ID) from Asset as asset where asset.StateInfo.MobileProvider.Name='Vodafone']
I'm sure this is because I'm doing the asset.StateInfo reference in the query all wrong. Would some kind soul please set me on the right path?
mike
Re: [Hibernate] HQL statement for one-to-many [message #683500 is a reply to message #681821] Mon, 13 June 2011 17:42 Go to previous messageGo to next message
Hi Folks,
I'm still struggling with this one. Any kind souls out there with a suggestion or two? It would be most appreciated.
mike
Re: [Hibernate] HQL statement for one-to-many [message #683501 is a reply to message #683500] Mon, 13 June 2011 17:45 Go to previous messageGo to next message
i have no idea why you are asking this in the Eclipse Modeling Framework forum.
~Christian
Re: [Hibernate] HQL statement for one-to-many [message #685080 is a reply to message #683501] Thu, 16 June 2011 15:16 Go to previous messageGo to next message
Here the answer I gave earlier but which disappeared in the void (there are apparently problems with the newsgroup/forum to sync up):
I think you should make this a join to the MobileProvider entity (assuming that's the name), and use the special elements function, something like this:
select count(asset.ID) from Asset as asset, MobileProvider as mp where mp in elements(asset.StateInfo) and mp.Name='Vodafone'
Hibernate/HQL has some nice collection functions which you can use in the where clause.
gr. Martin
[Updated on: Thu, 16 June 2011 15:16] by Moderator
Re: [Hibernate] HQL statement for one-to-many [message #685183 is a reply to message #685080] Thu, 16 June 2011 21:35 Go to previous messageGo to next message
Hi Martin,
Thanks again for the info. One question, how do I limit the data being counted (selected) to just the last entry of StateInfo.MobileProvider? In other words... there are multiple StateInfo rows for each Asset. The last/most recent StateInfo is the only one I want to count/select.
Thanks again.
mike
Re: [Hibernate] HQL statement for one-to-many [message #685236 is a reply to message #685183] Fri, 17 June 2011 01:01 Go to previous messageGo to next message
I have not tried it but see this part of the HQL chapter in the Hibernate docs:
HQL functions that take collection-valued path expressions: size(), minelement(), maxelement(), minindex(), maxindex(), along with the special elements() and indices functions that can be quantified using some, all, exists, any, in.
you can try maxelement I guess in the whereclause:
select count(asset.ID) from Asset as asset, MobileProvider as mp where mp = maxelement(asset.StateInfo) and mp.Name='Vodafone'
Can you let me know if this works (cause then I know it to)?
gr. Martin
Re: [Hibernate] HQL statement for one-to-many [message #687176 is a reply to message #681821] Fri, 10 June 2011 16:44 Go to previous messageGo to next message
mp.Name='Vodafone'
gr. Martin
> Cheers,
> mike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Hibernate] HQL statement for one-to-many [message #687193 is a reply to message #683500] Tue, 14 June 2011 00:12 Go to previous messageGo to next message
Hi Mike,
I answered your post on the 10th of June, or do you mean that my reply did not help?
gr. Martin
On 06/13/2011 11:42 PM, No real name wrote:
> Hi Folks,
> Cheers,
> mike
The Netherlands
Re: [Hibernate] HQL statement for one-to-many [message #687453 is a reply to message #683500] Tue, 14 June 2011 00:12 Go to previous messageGo to next message
Hi Mike,
gr. Martin
> Hi Folks,
> Cheers,
> mike
The Netherlands
Re: [Hibernate] HQL statement for one-to-many [message #688553 is a reply to message #687453] Fri, 24 June 2011 18:42 Go to previous messageGo to next message
Hi Martin,
Just getting caught up from other business and returning to this. I didn't see your Jun 10th post until a few days ago. Very strange.
Anyway, the
mp.Name='Vodafone'
query seems to return the count of MobileProvider entrys matching Name='Vodafone'. As you may recall I'm trying to count the number of instances where the last member/entry of Asset.StateInfo.MobileProvider.Name equals a given string. Here's a breakdown of the references
Asset--[one-to-many]-->StateInfo--[one-to-one]-->MobileProvider
The documentation for "elements" appears to be a bit brief from what I found on jboss.org.
Any suggestions would be greatly appreciated.
mike
Re: [Hibernate] HQL statement for one-to-many [message #688559 is a reply to message #688553] Fri, 24 June 2011 18:56 Go to previous message
Just figured it out. This works for me
select count(ID) from Asset as asset where asset.StateInfo[ maxindex(asset.StateInfo) ].MobileProvider.Name='%s'
Much more simple too!
mike
Previous Topic:(no subject)
Next Topic:(no subject)
Current Time: Sat Jul 19 13:51:44 EDT 2025
Powered by FUDForum. Page generated in 0.04449 seconds
