Home » Modeling » EMF » (no subject)
(no subject) [message #687104] Mon, 30 May 2011 18:18 Go to next message
the last days, I tried to understand the NET4J framework, to implement
an own protocol.
Now I found one point, which I dont understand.
There are some factories and element processors, which a implemented
inside the org.eclipse.net4j.util plugin.
The factory will be registered but now inside the
org.eclipse.emf.cdo.server plugin
Exactly this are:
<extension point="org.eclipse.net4j.util.factories">
<factory
productGroup="org.eclipse.net4j.Negotiators"
type="challenge"
class="org.eclipse.net4j.util.security.ChallengeNegotiatorFactory"
</extension>
and:
<extension point="org.eclipse.net4j.util.elementProcessors">
<elementProcessor
class="org.eclipse.net4j.util.security.ChallengeNegotiatorConfigurer"
</extension>
Do this was forgotten and it is a bug, or is there a specific reason?
Greetings
Heiko
(no subject) [message #687129 is a reply to message #687104] Thu, 02 June 2011 06:56 Go to previous messageGo to next message
Hi Heiko,
Unfortunately I do not remember excatly why that has been changed. I think it was related with the fact that you normally want to provide your own implementations. Note that you can easily contribute the factories of your choice from your own bundle.
Cheers
/Eike
http://www.esc-net.de
Am 31.05.2011 00:18, schrieb Heiko Ahlig:
> the last days, I tried to understand the NET4J framework, to implement an own protocol.
> There are some factories and element processors, which a implemented inside the org.eclipse.net4j.util plugin.
> The factory will be registered but now inside the org.eclipse.emf.cdo.server plugin
> Exactly this are:
> <factory
> type="challenge"
> </extension>
> and:
> <elementProcessor class="org.eclipse.net4j.util.security.ChallengeNegotiatorConfigurer"
> </extension>
> Greetings
> Heiko
(no subject) [message #687156 is a reply to message #687129] Tue, 07 June 2011 17:36 Go to previous message
Hi Eike
thanks for your answer.
I've looked into the old versions of net4j and CDO inside the svn
repository and since CDO 2.0 there are this combination.
If I do understand right the net4j framework with his IContainer system
and the factories, it is impossible to create a ChallengeNegotiator over
the container method
container.getElement(NegotiatorFactory.PRODUCT_GROUP, type, description);
as there will not used the cdo server plugin.
Greetings
Heiko
Am 02.06.2011 12:56, schrieb Eike Stepper:
> Hi Heiko,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hi,
>> an own protocol.
>> Exactly this are:
>> <factory
>> type="challenge"
>> </extension>
>> and:
>> <elementProcessor
>> </extension>
>> Greetings
>> Heiko
(no subject) [message #687366 is a reply to message #687104] Thu, 02 June 2011 06:56 Go to previous message
Hi Heiko,
Cheers
/Eike
> Exactly this are:
> <factory
> type="challenge"
> </extension>
> and:
> </extension>
> Greetings
> Heiko
(no subject) [message #687405 is a reply to message #687129] Tue, 07 June 2011 17:36 Go to previous message
Hi Eike
Greetings
Heiko
> Hi Heiko,
> Cheers
> /Eike
>> Hi,
>> an own protocol.
>> Exactly this are:
>> <factory
>> type="challenge"
>> </extension>
>> and:
>> <elementProcessor
>> </extension>
>> Greetings
>> Heiko
Previous Topic:(no subject)
Next Topic:(no subject)
Current Time: Sat Jul 19 08:44:38 EDT 2025
Powered by FUDForum. Page generated in 0.06510 seconds
