Home » Modeling » EMF » [CDO] How to configure the server side negotiator/client side to work with my user manager
[CDO] How to configure the server side negotiator/client side to work with my user manager [message #686782] |
Wed, 18 May 2011 13:43  |
To get the authentication working I have to have a negotiator tag in my cdo-server.xml. I was wondering how I could get
this to work so that the negotiator would use my user manager. I tried the below but it did not work (get npe in net4j
somewhere).
- I extended the ChallengeNegotiatorConfigurer and in this subclass I set my own usermanager in the Negotiator
- in plugin.xml I have this:
<extension point="org.eclipse.net4j.util.elementProcessors">
<elementProcessor class="myGreat.ChallengeProcessor"/>
</extension>
- and in the repository tag I have this:
<userManager type="MyUserManager" description="MyUserManager"/>
my processor gets called and my user manager gets set in the negotiator.
On the client I have this:
IPasswordCredentialsProvider credentialsProvider = new
PasswordCredentialsProvider(new
PasswordCredentials(uid,pass.toCharArray()));
sessionConfiguration.getAuthenticator().setCredentialsProvider(credentialsProvider);
Am I missing something, on the client or server side?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] How to configure the server side negotiator/client side to work with my user manager [message #686785 is a reply to message #686784] |
Wed, 18 May 2011 16:55   |
Yes I think that I am confusing things also :-). I have a UserManager extending the RepositoryManager. I have it
correctly defined in the cdo-server.xml and it gets instantiated. What should I do on the client and server to make use
of this UserManager?
gr. Martin
On 05/18/2011 10:48 PM, Eike Stepper wrote:
> Am 18.05.2011 19:43, schrieb Martin Taal:
>> Hi,
>> get this to work so that the negotiator would use my user manager. I tried the below but it did not work (get npe in
>> net4j somewhere).
> Sorry, looking again, I'm a little confused. What negotiator are you referring to?
> I have a vague feeling that you're messing up Net4j IConnector negotiation (valid for all IChannels of that IConnector)
> with CDOSession authentication (part of the CDO-specific protocol that is associated with a single IChannel). The latter
> is newer and usually preferred in CDO. You need no <negotiator> element nested in your <acceptor> element of your
> cdo-server.xml.
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> </extension>
The Netherlands
Re: [CDO] How to configure the server side negotiator/client side to work with my user manager [message #686802 is a reply to message #686785] |
Thu, 19 May 2011 09:44   |
Found it :-), the description attribute of the userManager tag in the cdo-server.xml needs to be the same as the
repository name....
<userManager type="MyUserManager" description="repo1"/>
gr. Martin
> gr. Martin
>>> Hi,
>>> net4j somewhere).
>> cdo-server.xml.
>> Cheers
>> /Eike
>>> </extension>
The Netherlands
Re: [CDO] How to configure the server side negotiator/client side to work with my user manager [message #686806 is a reply to message #686802] |
Thu, 19 May 2011 12:09  |
Am 19.05.2011 15:44, schrieb Martin Taal:
> Found it :-), the description attribute of the userManager tag in the cdo-server.xml needs to be the same as the repository name....
From the perspective of the (generic) IManagedContainer the description attribute distinguishes and identifies container elements that have the same product group and factory type.
From the perspective of the identified container element (or better its IFactory) the description attribute maybe used in an arbitrary way to influence the element creation process.
Yes, because in your case the IUserManager (== product group) is a subclass of RepositoryUserManager (== factory type), which interprets and uses the decsription as the name of the target repository ;-)
Cheers
/Eike
> gr. Martin
>> gr. Martin
>>>> Hi,
>>>> net4j somewhere).
>>> cdo-server.xml.
>>> Cheers
>>> /Eike
>>>> </extension>
Re: [CDO] How to configure the server side negotiator/client side to work with my user manager [message #686956 is a reply to message #686782] |
Wed, 18 May 2011 16:40  |
I think that looks not too bad. Have you tried it? I didn't use auth for a while and rely on the test *that* it works.
Cheers
/Eike
> To get the authentication working I have to have a negotiator tag in my cdo-server.xml. I was wondering how I could get this to work so that the negotiator would use my user manager. I tried the below but it did not work (get npe in net4j somewhere).
> </extension>
Re: [CDO] How to configure the server side negotiator/client side to work with my user manager [message #686957 is a reply to message #686782] |
Wed, 18 May 2011 16:48  |
I have a vague feeling that you're messing up Net4j IConnector negotiation (valid for all IChannels of that IConnector) with CDOSession authentication (part of the CDO-specific protocol that is associated with a single IChannel). The latter is newer and usually preferred in CDO. You need no <negotiator> element nested in your <acceptor> element of your cdo-server.xml.
Cheers
/Eike
> </extension>
Re: [CDO] How to configure the server side negotiator/client side to work with my user manager [message #686958 is a reply to message #686784] |
gr. Martin
>> Hi,
>> net4j somewhere).
> cdo-server.xml.
> Cheers
> /Eike
>> </extension>
The Netherlands
Re: [CDO] How to configure the server side negotiator/client side to work with my user manager [message #686977 is a reply to message #686785] |
repository name....
gr. Martin
> gr. Martin
>>> Hi,
>>> net4j somewhere).
>> cdo-server.xml.
>> Cheers
>> /Eike
>>> </extension>
The Netherlands
Re: [CDO] How to configure the server side negotiator/client side to work with my user manager [message #686982 is a reply to message #686802] |
Cheers
/Eike
> gr. Martin
>> gr. Martin
>>>> Hi,
>>>> net4j somewhere).
>>> cdo-server.xml.
>>> Cheers
>>> /Eike
>>>> </extension>
Current Time: Sat Jul 19 07:45:27 EDT 2025
Powered by FUDForum. Page generated in 0.30293 seconds
