Home » Modeling » TMF (Xtext) » Expression Language Problem(Combine bool and arithmetic expressions with grouping (parenthesis))
Expression Language Problem [message #686037] Tue, 21 June 2011 09:19 Go to next message
I want to create a grammar which combines bool and arithmetic expressions with grouping (parenthesis) like:
( 1 == 2 and ( 1 < ( 1+2) ) and not(2 > 3) ).
My actual grammar (based on the example in the docu for Expression + Expression) has the problem that '1 AND 2' would be valid, too.
Is there a way to fix this in the grammar or is an additional validation like the IConcretSytaxValidator required? What about the content-proposal if the 'additional' validator must be used?
I found several similar grammars in the forum but it seems they have the same 'problem'...
//short version with combined expressions for and|or and +|-|*|/ ...
ExpressionBoolBinary returns OperationBool:
    ExpressionBoolUnary ({OperationBool.left=current}
    op=('AND'|'OR')
    right=ExpressionBoolBinary)?
ExpressionBoolUnary returns OperationBool:
    ('NOT')? unary=TerminalExpressionBool
//would be the terminal if bool only...
TerminalExpressionBool returns Operation:
    ExpressionBoolCompare |
    {BoolLiteral}  value = ('TRUE'|'FALSE')
ExpressionBoolCompare returns Operation:
    Expression ({Operation.left=current}
    op=('=='|'<'|'>')
    right=ExpressionBoolCompare)?
Expression returns Operation:
    TerminalExpression ({Operation.left=current}
    op=('+'|'-'|'*'|'/')
    right=Expression)?
TerminalExpression returns Operation:
  '(' ExpressionBoolBinary ')' |
  {Function} func=('sin'|'cos') '(' param=IntLiteral ')'|
  literal=IntLiteral
IntLiteral: value = INT;
many thanks
gerit
Re: Expression Language Problem [message #686040 is a reply to message #686037] Tue, 21 June 2011 09:29 Go to previous messageGo to next message
this would be something for a type system (Validator), not for a grammar. e.g http://code.google.com/a/eclipselabs.org/p/xtext-typesystem/
~Christian
Re: Expression Language Problem [message #686632 is a reply to message #686040] Wed, 22 June 2011 12:18 Go to previous messageGo to next message
Hi Christian and thanks for the answer but if I understand the idea behind the typesystem right this could 'only' help me to write the additional validator.
But the additional validation has still the disadvantage of 'wrong' content proposals like:
1 + 1 {openContentPropasal:[ AND|OR|NOT|+|-... ]} and not only [+|-|*|/|...].
thanks, gerit
Re: Expression Language Problem [message #691372 is a reply to message #686632] Fri, 01 July 2011 06:22 Go to previous message
i'm using something to validate code very similar to the one you wrote in the first post.
the following code is simplyfied to only support INT values, in my case i could be almost anything (calculations have a standalone rule in my DSL).
BinaerOp		: '==' | '>=' | '<=' | '<' | '>' | '//' | '!=';
BoolOp			: '&' | '|';
// If-Conditions
Condition:	SimpleCondition | CapsulatedConditionSequence;
SimpleCondition: (op1+=ConditionElement BinaerOp op2+=ConditionElement) | {ecore} INT; // | {ecore} Variable | Calculation [...] simplyfied here
ConditionElement: {ecore} INT; // again, very simplyfied
ConditionSequence: base=Condition sequence+=(ConditionConcatenation)*;
ConditionConcatenation: BoolOp Condition;
CapsulatedConditionSequence: '(' ConditionSequence ')';
i didn't test it after simplifying, maybe you have to tweak it a bit.
using my grammar, the following code has a syntax error at the last '&'
if (1==1 & (1==2 | (1==1 & 2==2)) & 1 & 2) then {};
good luck Smile
Previous Topic:Eclipse editor gets slow as hell...
Next Topic:Showing Details/Descriptions in Content Assist
Current Time: Sun Jul 20 16:03:07 EDT 2025
Powered by FUDForum. Page generated in 0.03808 seconds
