Home » Modeling » GMF (Graphical Modeling Framework) » Enabling drag-n-drop from palette
Enabling drag-n-drop from palette [message #685925] Mon, 20 June 2011 15:21 Go to next message
I found this discussion on enabling DND from the palette in GMF generated editor. Changes work, but when I drag a palette item over any edit part in the editor feedback always shows that drop is permitted, even if particular edit part does not accept object being created. Is this expected behavior?
Alex
Re: Enabling drag-n-drop from palette [message #685980 is a reply to message #685925] Tue, 21 June 2011 04:59 Go to previous message
Hi Alex,
take a look at the [XYZ]DiagramItemSemanticEditPolicy: here, in the getCreateCommand(CreateElementRequest req) method, you can disable the creation of unwanted objects simply returning "null"; this way, you have the "forbidden" cursor icon.
HTH, bye
Giovanni
Previous Topic:Resizing subclasses of LabelEditPart
Next Topic:GMF Databaseconnection Issue
Current Time: Sun Jul 20 12:24:01 EDT 2025
Powered by FUDForum. Page generated in 0.05368 seconds
