Home » Modeling » Papyrus » Alignment on sequence diagrams.
Alignment on sequence diagrams. [message #684443] Wed, 15 June 2011 11:15 Go to next message
Create 4 lifelines in a sequence diagram and align them across the page.
Create an Action Execution Specification on each lifeline and purposely put each one at a different height on the lifeline.
Select all 4 Action Execution Specifications and select Diagram->Alignment->Align Top from the menus bar. Nothing happens. Is alignment supposed to work here?
Papyrus 0.8.0.v201106100302.
Re: Alignment on sequence diagrams. [message #690247 is a reply to message #684443] Wed, 29 June 2011 05:18 Go to previous messageGo to next message
Indeed, that's odd. Maybe it's the specific locator for Execution Specifications which is not compatible with the alignment tool. Or special change bounds treatments which fail with this command...
You may post a bug on the eclipse bugzilla.
Re: Alignment on sequence diagrams. [message #690539 is a reply to message #690247] Wed, 29 June 2011 12:50 Go to previous message
Done. Bug #350726
Previous Topic:Sync model with code
Next Topic:Importing packages
Current Time: Sat Jul 19 09:13:04 EDT 2025
Powered by FUDForum. Page generated in 0.02971 seconds
