Home » Eclipse Projects » EGit / JGit » Problems importing project using "New Projects" wizard
Problems importing project using "New Projects" wizard [message #677340] Wed, 08 June 2011 04:46 Go to next message
Using Eclipse Helios SR2, and Egit 0.12.1 on Windows 7 I have problems importing a GIT project into my workspace -- the resulting project is mostly empty and not connected to GIT.
I want to add the "jline2" project to my Eclipse workspace, to be found at github.com (I am not allowed to post URLs...?!)
After cloning the repository, I use the 'File' / 'Import...' / 'Git' / 'Projects from Git' wizard.
I choose my local repository, then select "Use the New Projects wizard" in step 2.
A new wizard pops up labelled "New Project", I select "Java Project". Next. Type in "jline2" as the project name. Hit Finish.
BOTH wizards close, and the project created is mostly empty and not connected to the git repository.
Nothing has been written to the ".metadata" log file.
Re: Problems importing project using "New Projects" wizard [message #684202 is a reply to message #677340] Wed, 15 June 2011 04:10 Go to previous messageGo to next message
A week has passed without a reply.. Can anybody reproduce that problem at least?
Re: Problems importing project using "New Projects" wizard [message #684231 is a reply to message #684202] Wed, 15 June 2011 05:11 Go to previous messageGo to next message
AFAIR there was a problem with importing projects and using the New Projects wizard.
You could try to upgrade to a newer version of EGit (don't know, if 1.0 is already in the update site), or use the Import as General project wizard, and after that, convert the project to a Java project
Re: Problems importing project using "New Projects" wizard [message #684261 is a reply to message #684231] Wed, 15 June 2011 06:00 Go to previous messageGo to next message
Dummy post #1
Re: Problems importing project using "New Projects" wizard [message #684262 is a reply to message #684261] Wed, 15 June 2011 06:01 Go to previous messageGo to next message
Dummy post #2 -- soon I will be able to post links...
Re: Problems importing project using "New Projects" wizard [message #684263 is a reply to message #684262] Wed, 15 June 2011 06:01 Go to previous messageGo to next message
Getting there...
Re: Problems importing project using "New Projects" wizard [message #684264 is a reply to message #684263] Wed, 15 June 2011 06:01 Go to previous message
Sorry, I should have checked the bugs database first.. There is actually an issue (still open) for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=324145
My eclipse doesn't report any available updates, and since the bug is not marked as resolved, I shall wait a while.
Previous Topic:401 Authorization Required
Next Topic:Error installing 1.0 on RC3
Current Time: Sun Jul 20 10:05:34 EDT 2025
Powered by FUDForum. Page generated in 0.06910 seconds
