Home » Eclipse Projects » DSDP - Target Management » Possible to use SystemRemoteFileDialog/SystemRemoteFolderDialog without RSE open
Possible to use SystemRemoteFileDialog/SystemRemoteFolderDialog without RSE open [message #575355] Wed, 18 June 2008 15:32 Go to next message
Originally posted by: zengland.us.ibm.com
Is it possible to make use of the
SystemRemoteFileDialog/SystemRemoteFolderDialog classes without being in
or possibly even activating the Remote systems view or Remote Systems
Explorer perspective?
I have another perspective and view from which I need to browse a remote
system for which I already have the host name/address and a
userid/password.
I started out trying some code like below but ran into a number of issues
with the bundle not being loaded and values not being initialized.
new RSECorePlugin();
IRSESystemType[] systemTypes =
RSECorePlugin.getTheCoreRegistry().getSystemTypes();
if(systemTypes != null)
System.out.println(systemTypes);
Host host = null;
SystemProfile prof = null;
prof = new SystemProfile(hostAddress, true);
host = new Host(prof);
IRSESystemType type =
RSECoreRegistry.getInstance().getSystemTypeById(IRSESystemTy pe.SYSTEMTYPE_SSH_ONLY_ID);
ISubSystemConfigurator sub[] = null;
SystemRegistry reg = SystemRegistry.getInstance();
try {
reg.createHost("builtIn", type , hostName, hostName, id, remoteHost, 0,
sub );
} catch (Exception e1) {
e1.printStackTrace();
diag = new SystemRemoteFileDialog(l_Form.getShell(), "browse remote file
system", host);
diag.open();
Object o = diag.getSelectedObject();
Is this type of usage even possible?
Re: Possible to use SystemRemoteFileDialog/SystemRemoteFolderDialog without RSE open [message #683954 is a reply to message #575355] Tue, 14 June 2011 14:27 Go to previous messageGo to next message
Indeed, I successfully do:
SystemRemoteFileDialog dialog = new SystemRemoteFileDialog(SystemBasePlugin.getActiveWorkbenchShell());
dialog.open();
Object o = dialog.getSelectedObject();
System.out.println("Selected object: " + o.toString());
Thanks for you post though ... it helped me figure out I had to do a ".open()" Smile
// Samuel
[Updated on: Tue, 14 June 2011 14:28] by Moderator
Re: Possible to use SystemRemoteFileDialog/SystemRemoteFolderDialog without RSE open [message #683967 is a reply to message #683954] Tue, 14 June 2011 15:05 Go to previous message
Or even better, change the two last lines to use "IRemoteFile", and you will have the proper convenience methods, such as for getting the path, etc:
IRemoteFile file = (IRemoteFile) dialog.getSelectedObject();
System.out.println("Selected file's abs path: " + file.getAbsolutePath());
[Updated on: Tue, 14 June 2011 15:06] by Moderator
Previous Topic:Command to start a telnet terminal view on a specific machine
Next Topic:A newcomer to RSE seeks feedback
Current Time: Sun Jul 20 15:38:12 EDT 2025
Powered by FUDForum. Page generated in 0.04320 seconds
