Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [JS4EMF] goal of JS4EMF
[JS4EMF] goal of JS4EMF [message #683806] Tue, 14 June 2011 09:06 Go to next message
Hi all sorry if this question has been already asked.
What are the difference between JS4EMF and previous projects for script integration like Eclipse Monkey ?
Re: [JS4EMF] goal of JS4EMF [message #683918 is a reply to message #683806] Tue, 14 June 2011 12:21 Go to previous messageGo to next message
I think the significant difference is that JS4EMF allows you to write
JavaScript both inside and outside EMF.
The inside-EMF exploits the EMF delegates capabilities, currently used
by OCL, to allow programmed definition of operation bodies, property
values and class constraints.
This potentially gives users a choice of OCL or JS as their working
language.
Ed Willink
On 14/06/2011 14:06, Tristan FAURE wrote:
> Eclipse Monkey
Re: [JS4EMF] goal of JS4EMF [message #683953 is a reply to message #683806] Tue, 14 June 2011 14:12 Go to previous message
I believe Eclipse Monkey is for scripting the Eclipse workbench and
utilizing Eclipse API's in Javascript, whereas JS4EMF is "limited" to
EMF, and as such, independent of Eclipse. As Ed Willink writes, JS and
OCL both supports "internal" scripting, by embedding script code in
Ecore models and utilizing the delegate mechanism. In addition, JS4EMF
supports using Javascript for manipulating Ecore objects in general,
e.g. for ad-hoc queries, editing, transformations etc. Finally, we want
to integrate EMF UIs with scripting, e.g. support Javascript-based
content and label providers, so more of an EMF-based application can be
configured with scripts and models, rather than with generated and
modified Java-code.
Hallvard
Previous Topic:Re: [Teneo] Need ClassMetadata but it's not present
Next Topic:[TEXO] Adding functions to util.ext
Current Time: Sun Jul 20 09:54:33 EDT 2025
Powered by FUDForum. Page generated in 0.24722 seconds
