Home » Modeling » EMF » dependencies between 2 packages
dependencies between 2 packages [message #683893] Tue, 14 June 2011 11:51 Go to next message
I would like create the dependencies between 2 packages by using dynamic EMF.
My first package called "modelPurchase". And then, I want to build a second package called "modelSupplier" by creating a dependency between the packages one-way from modelSupplier to modelPurchase dynamically. I have already create a dependency between their MANIFEST.MF, but I cannot see the Eclass from modelPurchase in my method that allows to build the modelSupplier.
How to proceed it ?
Thank you in advance ?
Ben
Re: dependencies between 2 packages [message #687200 is a reply to message #683893] Tue, 14 June 2011 11:56 Go to previous message
Ben,
Comments below.
ben wrote:
> dynamic EMF.
Keep in mind that statically generated models cannot be modified
dynamically.
> dynamically.
So you're going to build a while new package instance on the fly?
This is not sounding dynamic to me.
In the Ecore editor, you can use Load Resource... to load the model for
modelPurchase into the editor so that its classes are available as choices.
> How to proceed it ?
> Ben
Previous Topic:(no subject)
Next Topic:(no subject)
Current Time: Sun Jul 20 07:11:10 EDT 2025
Powered by FUDForum. Page generated in 0.02961 seconds
