Home » Archived » XML Schema Definition (XSD) » Problem while serializing xsd schema
Problem while serializing xsd schema [message #68306] Fri, 09 June 2006 03:13 Go to next message
Originally posted by: gjx.sdb.cnic.cn
Hi all
I want to construct a schema and save it
My code like this:
saveFile.addSelectionListener(new SelectionListener()
public void widgetSelected(SelectionEvent e)
FileDialog fd = new FileDialog(getShell(), SWT.SAVE);
String filename = fd.open();
if (filename == null)
return;
URI fileURI = URI.createPlatformResourceURI(filename);
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(fileURI);
resource.getContents().add(newSchema);
try
resource.save(Collections.EMPTY_MAP);
catch (Exception ex)
ex.printStackTrace();
but when I run the application, I get the following error message:
java.io.IOException: The path '/xxx/xxx.xsd' is unmapped
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createP latformResourceO
utputStream(URIConverterImpl.java:376)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createO utputStream(URIC
onverterImpl.java:306)
at DropTargetTree$5.widgetSelected(DropTargetTree.java:193)
what's the problem?
Re: Problem while serializing xsd schema [message #68318 is a reply to message #68306] Fri, 09 June 2006 07:17 Go to previous message
Jason,
You asked the same question in the EMF newsgroup. It's best when
posting the same question to multiple newsgroups to post a single
message to all groups at once rather than separate messages. With the
former approach, any reply on any newsgroup will appear in all
newsgroups and so creates less work for those answering the questions by
avoiding duplication...
Jason wrote:
> Hi all
> My code like this:
> return;
> try
> at
> at
> what's the problem?
Re: Problem while serializing xsd schema [message #598181 is a reply to message #68306] Fri, 09 June 2006 07:17 Go to previous message
Jason,
Jason wrote:
> Hi all
> My code like this:
> return;
> try
> at
> at
> what's the problem?
Previous Topic:Problem while serializing xsd schema
Next Topic:XSD root element
Current Time: Sun Jul 20 08:41:31 EDT 2025
Powered by FUDForum. Page generated in 0.20760 seconds
