Home » Archived » BIRT » relative path reference in html?
relative path reference in html? [message #682268] Fri, 10 June 2011 14:18 Go to next message
I have the following code in a Text control:
<div id="twisty_01" style="cursor:pointer"
onclick='if (document.getElementById("content_01").style.display == "none")
document.getElementById("twisty_01").innerHTML = "<img src=\"WebContent/report/images/CollapseInfoIcon.gif\" alt=\"Angry face\" />";
document.getElementById("content_01").style.display = "block";
} else {
document.getElementById("twisty_01").innerHTML = "<img src=\"WebContent/report/images/ExpandInfoIcon.gif\" alt=\"Angry face\" />";
document.getElementById("content_01").style.display = "none";
}' > <img src="WebContent/report/images/ExpandInfoIcon.gif" alt="Angry face" /> </div>
<div id="content_01" style="display:none;" >
Stuff goes here...
</div>
The issue is that the two image references in red (inside the onclick script) do not find the image at the relative path. To make these work I must put in the fully qualified path which is not desirable for obvious reasons!
The exact same relative path works fine in the last image specification (in blue).
Sorry if this is just an HTML question rather than a BIRT question but it is hard to tell how this is all being parsed and resolved under all these layers Wink
So how the heck can I find the images for the tags in red without specifying the fully qualified path?
Mike
(no subject) [message #682321 is a reply to message #682268] Fri, 10 June 2011 16:32 Go to previous message
Mike,
I added an image to a text element like:
<div id="testimg">
<img id="myimg"
src=<VALUE-OF>reportContext.getHttpServletRequest().getContextPath()
+"/webcontent/birt/images/Go.gif"</VALUE-OF> alt="Angry face" />
</div>
I then added a script to another text element that changed the image like:
<script>
var img = document.getElementById("myimg");
var cur = img.src;
var newsrc = cur.replace("Go.gif", "Up.gif");
img.src = newsrc;
</script>
And this worked
Jason
> "none") {
> } else {
> face" /> </div>
> Stuff goes here...
> </div>
> reasons!
> (in blue).
> these layers ;)
> Mike
Previous Topic:Hour and Minutes formating
Next Topic:Embedded Report - JavaScript Error
Current Time: Sun Jul 20 19:03:46 EDT 2025
Powered by FUDForum. Page generated in 0.03734 seconds
