Home » Language IDEs » C / C++ IDE (CDT) » Eclipse Debugger Events
Eclipse Debugger Events [message #677542] Wed, 08 June 2011 14:59 Go to next message
In my Eclipse plugin, I would like to be notified on debugger events (e.g. when stepping or a breakpoint is hit). I've managed to get this working in a JDT environment by subscribing to debug events using this code:
DebugPlugin.getDefault().addDebugEventListener(this);
Which gives this event handler:
public void handleDebugEvents(DebugEvent[] events)
In JDT this is fired on Breakpoint or Suspend events and I was hoping the behaviour would be the same in CDT. However, it is not. I only get two Create events at the start of the debug session:
DebugEvent[org.eclipse.cdt.dsf.gdb.launching.GDBProcess@ae0aae, CREATE, UNSPECIFIED] DebugEvent[org.eclipse.debug.core.model.RuntimeProcess@920d5d, CREATE, UNSPECIFIED]
Is there a generic solution that wouldn't require specific dependencies on JDT or CDT?
Thanks, Alan
Re: Eclipse Debugger Events [message #682016 is a reply to message #677542] Fri, 10 June 2011 04:48 Go to previous message
I did find a solution. Here it is in case it helps others:
You can use the method outlined above to listen for debug events when the session is created and terminated.
For any stepping events, one way I found was to register an IExecutionListener to be notified of all commands that take place in the Eclipse workspace. You can register an execution listener by getting hold of an ICommandService as follows:
ICommandService commandService = (ICommandService)PlatformUI.getWorkbench().getService(ICommandService.class)
Then add an execution listener:
commandService.addExecutionListener(this);
This will give you various event handlers (notHandled, postExecuteFailure, postExecuteSuccess, preExecute) from which you can filter by the commandId value.
I hope this helps someone else.
Alan
Previous Topic:Objective C support
Next Topic:Help on loading a core
Current Time: Sat Jul 19 11:28:43 EDT 2025
Powered by FUDForum. Page generated in 0.02954 seconds
