Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF.Edit] removeCommand (exception when using removecommand to edit an EMF model)
[EMF.Edit] removeCommand [message #675409] Tue, 31 May 2011 08:41 Go to next message
I built my ecore metamodel (GGraph metamodel) and built a model instance (myModel) using plugins generated by genmodel (edit, editor, ...)
I tried now to edit my model (remove and add elements).
I created a popup menue plugin to add a new label in the model contextual menue (when right clicking on model) "editing model". this is part of the code that executes when select the model:
public void run(IAction action)
updateSelectedEObject();
selectedElement=getSelectedEObject();
List<GIMPLE_Node> all_nodes =selectedElement.getNodes();
GIMPLE_Node n= all_nodes.get(1);
remove_node(selectedElement, n);
public void remove_node(GIMPLE_Graph gg, GIMPLE_Node gn)
EditingDomain ed = AdapterFactoryEditingDomain.getEditingDomainFor(gg);
Command cmd= RemoveCommand.create(ed, gn);
ed.getCommandStack().execute(cmd);
the node that I try to remove is well removed but when I try to save the model (ctrl s) I get this exception:
org.eclipse.emf.ecore.xmi.DanglingHREFException: The object 'GGraph.impl.GIMPLE_State_CondImpl@1baeec3 (name: S_COND1, label: L1) (kind: eq_exp)' is not contained in a resource.
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.handleDanglingHREF(XMLHelperImpl.java:760)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getURIFragment(XMLHelperImpl.java:731)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getIDREF(XMLHelperImpl.java:753)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveIDRefMany(XMLSaveImpl.java:2003)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLSaveImpl.java:1355)
any idea ? did I miss some thing ?
Thank you very much
Asma
Re: [EMF.Edit] removeCommand [message #675479 is a reply to message #675409] Tue, 31 May 2011 12:24 Go to previous messageGo to next message
The problem comes from the fact that the node to remove is referenced by other classes in the same model.
in fact Command cmd= RemoveCommand.create(ed, gn); is the same than
Command cmd = new RemoveCommand(ed,gn.eContainer(),GGraphPackage.eINSTANCE.getGIMPLE_Graph_Nodes(),gn);
it removes only references betwwen the element and its container but did not check other references!!!!
when I removed manually the other references of the element to remove, The exception disappear and I can save my model.
I am wondering what is the role of the ItemProvider, the AdapterFactory, and other classes generated by EMF if we should remove manually all the references of the element to remove.
I think that I miss some thing. any idea ? should I call explicitly the adapters, notifychange,etc ?
thank you very much.
Asma
Re: [EMF.Edit] removeCommand [message #675495 is a reply to message #675479] Tue, 31 May 2011 12:40 Go to previous messageGo to next message
Asma,
It sounds like you want the effect of a DeleteCommand, which cleans up
all references using RemoveCommand and SetCommand, depending on
multiplicity.
charfi asma wrote:
> Hello,
> by other classes in the same model. in fact Command cmd=
> Command cmd = new
> Asma
Re: [EMF.Edit] removeCommand [message #675682 is a reply to message #675495] Wed, 01 June 2011 03:53 Go to previous message
Hello Ed,
yes, I want the effect of the DeleteCommand !! I was not aware of the existing of such command Smile thank you very much for your help.
Asma
Previous Topic:[EMF Compare] Inverse use of EMF Compare
Next Topic:[EEF] Label of Group widget is not generated
Current Time: Sun Jul 20 04:11:39 EDT 2025
Powered by FUDForum. Page generated in 0.04859 seconds
