Home » Eclipse Projects » Virgo » Could not load driverClass oracle.jdbc.OracleDriver(Could not load driverClass oracle.jdbc.OracleDriver)
Could not load driverClass oracle.jdbc.OracleDriver [message #674610] |
Fri, 27 May 2011 10:47  |
Hello all,
I have a multiple bundle web app deployed on Virgo 2.1.0.
I am using com.mchange.v2.c3p0.ComboPooledDataSource in a bundle that is accessed by other bundles when they need to get a cached Datasource to perform database querying.
Here is a snippet from my service that creates the connection pool:
DataSource createDataSource(JdbcURL jdbcURL) throws DatasourceException {
ComboPooledDataSource dataSource = new ComboPooledDataSource();
dataSource.setJdbcUrl(jdbcURL.getUrl());
dataSource.setMinPoolSize(minConnections);
dataSource.setMaxPoolSize(maxConnections);
dataSource.setDriverClass("oracle.jdbc.OracleDriver");
return dataSource;
Other services take this dataSource, create a JdbcTemplate (new JdbcTemplate(dataSource)) and attempt to exectue queries and stored procedures.
However, they throw the below stacktrace (this is a snippet I have attached fuller logs).
Everything works fine if I use a SimpleDriverDataSource instead of ComboPooledDataSource. Additionally, I can use this ComboPooledDataSource and successfully perform queries in JUnit tests outside of the OSGI.
2011-05-26 15:40:57.568] pool-1-thread-1 com.mchange.v2.c3p0.impl.AbstractPoolBackedDataSource Initializing c3p0 pool... com.mchange.v2.c3p0.ComboPooledDataSource [ acquireIncrement -> 3, acquireRetryAttempts -> 30, acquireRetryDelay -> 1000, autoCommitOnClose -> false, automaticTestTable -> null, breakAfterAcquireFailure -> false, checkoutTimeout -> 0, connectionCustomizerClassName -> null, connectionTesterClassName -> com.mchange.v2.c3p0.impl.DefaultConnectionTester, dataSourceName -> 2so7yk8gcrv70a193od6o|a0ebc2, debugUnreturnedConnectionStackTraces -> false, description -> null, driverClass -> oracle.jdbc.OracleDriver, factoryClassLocation -> null, forceIgnoreUnresolvedTransactions -> false, identityToken -> 2so7yk8gcrv70a193od6o|a0ebc2, idleConnectionTestPeriod -> 0, initialPoolSize -> 3, jdbcUrl -> jdbc:oracle:thin:[actual connection url removed by supercube], maxAdministrativeTaskTime -> 0, maxConnectionAge -> 0, maxIdleTime -> 0, maxIdleTimeExcessConnections -> 0, maxPoolSize -> 15, maxStatements -> 0, maxStatementsPerConnection -> 0, minPoolSize -> 1, numHelperThreads -> 3, numThreadsAwaitingCheckoutDefaultUser -> 0, preferredTestQuery -> null, properties -> {}, propertyCycle -> 0, testConnectionOnCheckin -> false, testConnectionOnCheckout -> false, unreturnedConnectionTimeout -> 0, usesTraditionalReflectiveProxies -> false ]
[2011-05-26 15:40:57.584] chronousRunner$PoolThread-#0 com.mchange.v2.c3p0.DriverManagerDataSource Could not load driverClass oracle.jdbc.OracleDriver org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: oracle.jdbc.OracleDriver in KernelBundleClassLoader: [bundle=c3p0-0.9.1.2_0.0.0]
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:139)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at com.mchange.v2.c3p0.DriverManagerDataSource.ensureDriverLoaded(DriverManagerDataSource.java:100)
at com.mchange.v2.c3p0.DriverManagerDataSource.getConnection(DriverManagerDataSource.java:117)
at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:143)
at com.mchange.v2.c3p0.WrapperConnectionPoolDataSource.getPooledConnection(WrapperConnectionPoolDataSource.java:132)
at com.mchange.v2.c3p0.impl.C3P0PooledConnectionPool$1PooledConnectionResourcePoolManager.acquireResource(C3P0PooledConnectionPool.java:137)
at com.mchange.v2.resourcepool.BasicResourcePool.doAcquire(BasicResourcePool.java:1014)
at com.mchange.v2.resourcepool.BasicResourcePool.access$800(BasicResourcePool.java:32)
at com.mchange.v2.resourcepool.BasicResourcePool$AcquireTask.run(BasicResourcePool.java:1810)
at com.mchange.v2.async.ThreadPoolAsynchronousRunner$PoolThread.run(ThreadPoolAsynchronousRunner.java:547)
Caused by: java.lang.ClassNotFoundException: oracle.jdbc.OracleDriver
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:135)
... 12 common frames omitted
Re: Could not load driverClass oracle.jdbc.OracleDriver [message #674676 is a reply to message #674610] |
Fri, 27 May 2011 16:32   |
I've found my self in similar condition, following is the solution I used...
Bundles which you need are:
- Oracle JDBC Driver Bundle, there was Oracle JDBC version 10.2.0.2 from EBR, but now it's gone. Other alternative is to wrap your Oracle JDBC Driver using bundlor utilities
- C3P0 Bundle, I use com.springsource.com.mchange.v2.c3p0 from EBR
- a Pooling DataSource service Bundle, with the following item on its META-INF/MANIFEST.MF
Fragment-Host: com.springsource.com.mchange.v2.c3p0
Import-Package: com.mchange.v2.c3p0;version="[0.9.1.2, 0.9.1.2]",javax
.sql;version="0",oracle.jdbc.driver
Hope this help
Abbas
Re: Could not load driverClass oracle.jdbc.OracleDriver [message #677533 is a reply to message #674676] |
Wed, 08 June 2011 14:38  |
Thanks for the help.
My bundle has several imported packages as shown below.
When I added the format host line I got lots of constraint conflicts as shown below.
My solution was to modify the C3P0 jar file's Manifest.mf directly, including my oracle driver package in the "Import Packages" section - I was surprised that it was not included there already. I do see it in the Apache Commons connection pooling jar.
Excerpt from my manifest.mf:
Import-Package: org.hibernate.validator;version="${hibernate.validator.version.range}",
oracle.jdbc
Import-Template: ...,org.springframework.*;version="${spring.version.range}"
Import-Bundle: org.springframework.core;version="${spring.version.range}"
Excerpt from stack trace after including Fragment-Host in manifest.mf:
Cannot satisfy constraints for bundle 'com.cme.star.service.datasource' version '2.0.0.SNAPSHOT'. Cannot resolve: com.cme.star.service.datasource
Resolver report:
The fragment could not be resolved because of a constraint conflict with a host, possibly because the host is already resolved. The affected fragment is com.cme.star.service.datasource_2.0.0.SNAPSHOT
Possible hosts:
c3p0-0.9.1.2_0.0.0 (resolved)
Constraint conflict:
Import-Package: javax.annotation; version="0.0.0"
Possible hosts:
Import-Package: org.apache.commons.pool.impl; version="0.0.0"
Possible hosts:
Import-Package: org.springframework.beans.factory.annotation; version="[3.0.0,3.1.0)"
Possible hosts:
Import-Package: com.cme.star.common; version="[2.0.0,2.1.0)"
Possible hosts:
Import-Package: org.apache.commons.jocl; version="0.0.0"
Possible hosts:
Current Time: Sun Jul 20 16:12:44 EDT 2025
Powered by FUDForum. Page generated in 0.03271 seconds
