Home » Modeling » Papyrus » Error during save
Error during save [message #674564] Fri, 27 May 2011 07:25 Go to next message
Hi !
I'm working with Papryrus 0.7.3,
on a class diagram, with a self made profile, and all my stereotype apply on Class or Dependencies.
And once again, i got this annoying problem, which prevent me to save my work.
Here are the details of the error :
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The object 'org.eclipse.uml2.uml.internal.impl.DependencyImpl@1827c16 (name: <unset>, visibility: <unset>)' is not contained in a resource.
I don't know what to do with this. Is it a bug ? Or did I made a big mistake ?
Any help or advice is welcome !
Re: Error during save [message #674581 is a reply to message #674564] Fri, 27 May 2011 08:25 Go to previous messageGo to next message
More Precision : You can get this message while creating a new Dependency, and hit CTRL Z to undo it, then try to save.
There is no problem if you delete it by right clic
Re: Error during save [message #675062 is a reply to message #674581] Mon, 30 May 2011 04:28 Go to previous messageGo to next message
A dependency did not have a uml Parent.
I seems that the bug can be done because of an undo of the creation of a dependency.
It is quite strange because this case is tested by a JUNIT test for the undo of the creation.
I will test on a version 7.3
Re: Error during save [message #675331 is a reply to message #675062] Tue, 31 May 2011 03:54 Go to previous message
It's not for any dependency, only for stereotyped dependency, and when you create it with a custom palette (if you create the dependency then add the stereotype it doesn't work)
I made a bug report about it, and now i know how to reproduce it, i know how to avoid it, so it's not a problem anymore for me.
Previous Topic:Class diagram observations
Next Topic:Diagram Question
Current Time: Sun Jul 20 17:54:06 EDT 2025
Powered by FUDForum. Page generated in 0.04812 seconds
