New Editor? [message #674529] |
Fri, 27 May 2011 05:20  |
Hi all,
as said I am trying to extend the default XML editors with some features.
Yesterday I downloaded the source code from repositoy "webtools", okay.
But, to start a new project based on the default XML editor shouldn't I create a new Plug-in Development Project and use the Editor template?
I am a little bit confused about this.
Marco
Re: (no subject) [message #677215 is a reply to message #675988] |
Tue, 07 June 2011 16:38  |
On 6/2/2011 5:37 AM, MarcoGT wrote:
> Ok, in these days I studied the editor.
> I would like to add some features to the content assist, for example.
> I tried to start a new plugin project using the template but this has
> less features than the "default" one, for example no outline, no tag
> folding and so on.
> So, my plan is to check-out sources that build up the standard XML
> editor and start to implement my features from there.
> Is it a good point?
Yes, just be conscious of which branch of CVS you check out from
compared to what version of Eclipse you're working in. HEAD is intended
to be our 3.3 release on top of Eclipse 3.7 while Helios is 3.2.x on top
of Eclipse 3.6.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
FUDForum. Page generated in 0.06796 seconds
