Home » Language IDEs » C / C++ IDE (CDT) » SIGSEGV causes eclipse CDT to crash at startup - (HotSpot Virtual Machine?)
icon4.gif  SIGSEGV causes eclipse CDT to crash at startup - (HotSpot Virtual Machine?) [message #657958] Fri, 04 March 2011 13:02 Go to next message
I am trying to setup a new eclipse CDT installation on a new SLES 11 Linux installation.
When I start eclipse I see the splash screen and then it crashes with SIGSEGV error.
I did some searching and found Bug 214092. While I think it is related, I'm not sure this is the same problem. According to Eclipse Project Release Notes for 3.6.2, My SLES 11 Linux environment with Java 5-22 was tested and should work.
I've tried all of the workarounds that were mentioned in Bug 214092. I tried the work around that was mentioned in the Eclipse Release for this problem, including disabling the compiler with the VM arg "-Xint". These didn't work.
I've tried upgrading to a newer version of Java (jdk-6u17 and jdk-6u24). this didn't help either.
I know this this probably isn't an eclipse problem, but does anybody here know anything that will help me?
The Error:
# An unexpected error has been detected by HotSpot Virtual Machine:
#  SIGSEGV (0xb) at pc=0x00007f872706b294, pid=21702, tid=140219353118464
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_22-b03 interpreted mode)
# Problematic frame:
# C  [libgdk-x11-2.0.so.0+0x67294]
My System Configuration:
SUSE Linux Enterprise Server 11 (2.6.32.27-0.2-default) x86_64
Eclipse 3.6.2
java -version
   java version "1.5.0_22"
   Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_22-b03)
   Java HotSpot(TM) 64-Bit Server VM (build 1.5.0_22-b03, mixed mode)
eclipse debug console:
marcoredev3 test/eclipse> ./eclipse -debug -console
Start VM: /users/oakesjc/test/jdk1.5.0_22/bin/java
-Xint
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx384m
-jar /net/users/oakesjc/test/eclipse//plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
-os linux
-ws gtk
-arch x86_64
-showsplash
-launcher /net/users/oakesjc/test/eclipse/eclipse
-name Eclipse
--launcher.library /net/users/oakesjc/test/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.2.R36x_v20101019_1345/eclipse_1310.so
-startup /net/users/oakesjc/test/eclipse//plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
-exitdata 3e8003
-product org.eclipse.epp.package.cpp.product
-debug
-console
-vm /users/oakesjc/test/jdk1.5.0_22/bin/java
-vmargs
-Xint
-Xms40m
-Xmx384m
Install location:
    file:/net/users/oakesjc/test/eclipse/
Configuration file:
    file:/net/users/oakesjc/test/eclipse/configuration/config.ini loaded
Configuration location:
Framework located:
    file:/net/users/oakesjc/test/eclipse/plugins/org.eclipse.osgi_3.6.2.R36x_v20110210.jar
Framework classpath:
Splash location:
    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.platform_3.6.2.v201102101200/splash.bmp
Debug options:
    file:/net/users/oakesjc/test/eclipse/.options not found
osgi> Time to load bundles: 77
Starting application: 7471
#  SIGSEGV (0xb) at pc=0x00007ffadb16c294, pid=21868, tid=140716295202560
# An error report file with more information is saved as hs_err_pid21868.log
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
The error log:
---------------  T H R E A D  ---------------
Current thread (0x0000000040116630):  JavaThread "main" [_thread_in_native, id=21702]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0x0000000000000438
Registers:
RAX=0x00007f87280d0000, RBX=0x0000000000000000, RCX=0x0000000000000057, RDX=0x00007f87280d0000
RSP=0x00007fffa14a8860, RBP=0x00007fffa14a8bc0, RSI=0x00007fffa14a8bc0, RDI=0x0000000000000000
R8 =0x00007f875c12f2a8, R9 =0x0000000000000cc4, R10=0x00007f875cbf7000, R11=0x00007f875c13fc90
R12=0x0000000000000000, R13=0x0000000000000000, R14=0x00007fffa14a8bc0, R15=0x00007f8728a861e0
RIP=0x00007f872706b294, EFL=0x0000000000010206, CSGSFS=0x0000000000000033, ERR=0x0000000000000004
  TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007fffa14a8860)
0x00007fffa14a8860:   00007f8728a861e0 0000000000000000
0x00007fffa14a8870:   00007f8728a81740 00007f87270600b7
0x00007fffa14a8880:   0000000040117248 00007fffa14a9530
0x00007fffa14a8890:   0000000040116630 00000000401bbd70
0x00007fffa14a88a0:   00007f872dd44d08 00007f874da7d5c8
0x00007fffa14a88b0:   00000000a14a8e30 00007f87280d0000
0x00007fffa14a88c0:   0000000000000000 0000000000000000
0x00007fffa14a88d0:   0000000000000000 0000000000000000
0x00007fffa14a88e0:   0000000000000000 0000000000000000
0x00007fffa14a88f0:   00007fffa14a8990 0000000040116630
0x00007fffa14a8900:   00007fffa14a89d0 00007fffa14a8b20
0x00007fffa14a8910:   00007fffa14a8920 00007f875be445f9
0x00007fffa14a8920:   00007fffa14a8940 00007f875bc5ec05
0x00007fffa14a8930:   0000000040116ed0 0000000040116ed0
0x00007fffa14a8940:   00007fffa14a8ab0 00007f875bc8c869
0x00007fffa14a8950:   00007f8728a87400 0000000500000000
0x00007fffa14a8960:   00007fffa14a8b20 0000000040116780
0x00007fffa14a8970:   0000000040116ed0 0000000000000000
0x00007fffa14a8980:   00007fffa14a89f0 0000000040116ec8
0x00007fffa14a8990:   00007f875c109950 0000000040116ed8
0x00007fffa14a89a0:   00000000a14a89f0 00007fffa14a8a00
0x00007fffa14a89b0:   0000000000000000 00007fffa14a89e0
0x00007fffa14a89c0:   0000000040116ed0 4037000000000000
0x00007fffa14a89d0:   4076f00000000000 00007f874da7d5c8
0x00007fffa14a89e0:   0000000000000000 00007f8728a86170
0x00007fffa14a89f0:   00007f87280caa40 0000000000000000
0x00007fffa14a8a00:   000000000000000c 00007f8728109340
0x00007fffa14a8a10:   00007f870000a700 0000000100000000
0x00007fffa14a8a20:   0000000000000000 0000000000000000
0x00007fffa14a8a30:   0000000000000000 00007f8724039977
0x00007fffa14a8a40:   00007fffa14a89d8 00007fffa14a8a1c
0x00007fffa14a8a50:   0000000800000005 0000000000000000
Instructions: (pc=0x00007f872706b294)
0x00007f872706b284:   f0 48 89 6c 24 f8 48 89 fb 48 83 ec 18 48 89 f5
0x00007f872706b294:   48 8b b7 38 04 00 00 48 8b bf 30 03 00 00 e8 19
Stack: [0x00007fffa12ae000,0x00007fffa14ae000),  sp=0x00007fffa14a8860,  free space=2026k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(JZ)Z+0
j  org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(JZ)Z+9
j  org.eclipse.swt.widgets.Display.readAndDispatch()Z+33
j  org.eclipse.jface.window.Window.runEventLoop(Lorg/eclipse/swt/widgets/Shell;)V+23
j  org.eclipse.jface.window.Window.open()I+49
j  org.eclipse.ui.internal.ide.ChooseWorkspaceDialog.prompt(Z)V+15
j  org.eclipse.ui.internal.ide.application.IDEApplication.promptForWorkspace(Lorg/eclipse/swt/widgets/Shell;Lorg/eclipse/ui/internal/ide/ChooseWorkspaceData;Z)Ljava/net/URL;+15
j  org.eclipse.ui.internal.ide.application.IDEApplication.checkInstanceLocation(Lorg/eclipse/swt/widgets/Shell;)Z+151
j  org.eclipse.ui.internal.ide.application.IDEApplication.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+44
j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
v  ~StubRoutines::call_stub
j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
j  org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V+10
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x00007f8728287cf0 JavaThread "Worker-JM" [_thread_blocked, id=21732]
  0x00007f8728286e40 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=21731]
  0x00000000406d3690 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=21728]
  0x00007f8728291820 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=21726]
  0x00007f8728214330 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=21724]
  0x00007f87281ba8d0 JavaThread "State Saver" [_thread_blocked, id=21723]
  0x00007f8728018b10 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=21718]
  0x00007f87280170b0 JavaThread "CompilerThread1" daemon [_thread_blocked, id=21717]
  0x00007f8728015d10 JavaThread "CompilerThread0" daemon [_thread_blocked, id=21716]
  0x00007f8728014940 JavaThread "AdapterThread" daemon [_thread_blocked, id=21715]
  0x00007f8728013680 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=21714]
  0x00007f87280008d0 JavaThread "Finalizer" daemon [_thread_blocked, id=21713]
  0x00000000401c3fe0 JavaThread "Reference Handler" daemon [_thread_blocked, id=21712]
=>0x0000000040116630 JavaThread "main" [_thread_in_native, id=21702]
Other Threads:
  0x00000000401b7330 VMThread [id=21711]
  0x00007f872801b480 WatcherThread [id=21719]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 PSYoungGen      total 12736K, used 2362K [0x00007f874d0f0000, 0x00007f874e110000, 0x00007f87550f0000)
  eden space 9088K, 10% used [0x00007f874d0f0000,0x00007f874d1e5350,0x00007f874d9d0000)
  from space 3648K, 37% used [0x00007f874d9e0000,0x00007f874db39630,0x00007f874dd70000)
  to   space 3712K, 0% used [0x00007f874dd70000,0x00007f874dd70000,0x00007f874e110000)
 PSOldGen        total 27328K, used 15230K [0x00007f873d0f0000, 0x00007f873eba0000, 0x00007f874d0f0000)
  object space 27328K, 55% used [0x00007f873d0f0000,0x00007f873dfcfb48,0x00007f873eba0000)
 PSPermGen       total 21248K, used 15928K [0x00007f872d0f0000, 0x00007f872e5b0000, 0x00007f873d0f0000)
  object space 21248K, 74% used [0x00007f872d0f0000,0x00007f872e07e308,0x00007f872e5b0000)
Dynamic libraries:
40000000-4000e000 r-xp 00000000 00:17 3788169                            /net/users/oakesjc/test/jdk1.5.0_22/bin/java
4010d000-40110000 rwxp 0000d000 00:17 3788169                            /net/users/oakesjc/test/jdk1.5.0_22/bin/java
40110000-406f5000 rwxp 00000000 00:00 0                                  [heap]
7f871d8d0000-7f871d8db000 r-xp 00000000 00:17 2245378                    /net/users/oakesjc/test/eclipse/configuration/org.eclipse.osgi/bundles/194/1/.cp/libswt-atk-gtk-3659.so
7f871d8db000-7f871d9da000 ---p 0000b000 00:17 2245378                    /net/users/oakesjc/test/eclipse/configuration/org.eclipse.osgi/bundles/194/1/.cp/libswt-atk-gtk-3659.so
7f871d9da000-7f871d9db000 rwxp 0000a000 00:17 2245378                    /net/users/oakesjc/test/eclipse/configuration/org.eclipse.osgi/bundles/194/1/.cp/libswt-atk-gtk-3659.so
7f871d9db000-7f871d9e2000 r-xp 00000000 08:01 147263                     /usr/lib64/gtk-2.0/2.10.0/immodules/im-xim.so
7f871d9e2000-7f871dbe1000 ---p 00007000 08:01 147263                     /usr/lib64/gtk-2.0/2.10.0/immodules/im-xim.so
7f871dbe1000-7f871dbe2000 r-xp 00006000 08:01 147263                     /usr/lib64/gtk-2.0/2.10.0/immodules/im-xim.so
7f871dbe2000-7f871dbe3000 rwxp 00007000 08:01 147263                     /usr/lib64/gtk-2.0/2.10.0/immodules/im-xim.so
7f871dbe3000-7f871dbe9000 r-xp 00000000 08:01 147269                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
7f871dbe9000-7f871dde8000 ---p 00006000 08:01 147269                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
7f871dde8000-7f871dde9000 r-xp 00005000 08:01 147269                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
7f871dde9000-7f871ddea000 rwxp 00006000 08:01 147269                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
7f871ddea000-7f871ddee000 r-xp 00000000 08:01 147276                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
7f871ddee000-7f871dfee000 ---p 00004000 08:01 147276                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
7f871dfee000-7f871dfef000 r-xp 00004000 08:01 147276                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
7f871dfef000-7f871dff0000 rwxp 00005000 08:01 147276                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
7f871e0f0000-7f871e0f2000 r-xp 00000000 08:01 141722                     /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
7f871e0f2000-7f871e2f1000 ---p 00002000 08:01 141722                     /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
7f871e2f1000-7f871e2f2000 r-xp 00001000 08:01 141722                     /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
7f871e2f2000-7f871e2f3000 rwxp 00002000 08:01 141722                     /usr/lib64/pango/1.6.0/modules/pango-basic-fc.so
7f871e2f3000-7f871e2fb000 r-xp 00000000 08:01 230882                     /lib64/librt-2.11.1.so
7f871e2fb000-7f871e4fa000 ---p 00008000 08:01 230882                     /lib64/librt-2.11.1.so
7f871e4fa000-7f871e4fb000 r-xp 00007000 08:01 230882                     /lib64/librt-2.11.1.so
7f871e4fb000-7f871e4fc000 rwxp 00008000 08:01 230882                     /lib64/librt-2.11.1.so
7f871e4fc000-7f871e501000 r-xp 00000000 08:01 141129                     /usr/lib64/libXtst.so.6.1.0
7f871e501000-7f871e701000 ---p 00005000 08:01 141129                     /usr/lib64/libXtst.so.6.1.0
7f871e701000-7f871e702000 r-xp 00005000 08:01 141129                     /usr/lib64/libXtst.so.6.1.0
7f871e702000-7f871e703000 rwxp 00006000 08:01 141129                     /usr/lib64/libXtst.so.6.1.0
7f871e703000-7f871e707000 r-xp 00000000 08:01 148873                     /usr/lib64/libgthread-2.0.so.0.2200.5
7f871e707000-7f871e906000 ---p 00004000 08:01 148873                     /usr/lib64/libgthread-2.0.so.0.2200.5
7f871e906000-7f871e907000 r-xp 00003000 08:01 148873                     /usr/lib64/libgthread-2.0.so.0.2200.5
7f871e907000-7f871e908000 rwxp 00004000 08:01 148873                     /usr/lib64/libgthread-2.0.so.0.2200.5
7f871e908000-7f871e90b000 ---p 00000000 00:00 0
7f871e90b000-7f871ea09000 rwxp 00000000 00:00 0
7f871ea13000-7f871ea3d000 r-xp 00000000 08:01 105033                     /usr/share/fonts/truetype/albwb.ttf
7f871ea3d000-7f871ea8a000 rwxp 00000000 00:00 0
7f871ea8a000-7f871eab4000 r-xp 00000000 08:01 105032                     /usr/share/fonts/truetype/albw.ttf
7f871eab4000-7f871eea6000 r-xs 00000000 00:17 2248283                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.workbench_3.6.2.M20110210-1200.jar
7f871eea6000-7f871eea9000 rwxp 00000000 00:00 0
7f871eea9000-7f871efa7000 rwxp 00000000 00:00 0
7f871efc5000-7f871f021000 r-xs 00000000 08:01 7644                       /var/cache/fontconfig/17090aa38d5c6f09fb8c5c354938f1d7-x86-64.cache-2
7f871f021000-7f871f02a000 r-xs 00000000 08:01 7666                       /var/cache/fontconfig/f80f85ff075af895657a2def80df3f56-x86-64.cache-2
7f871f02a000-7f871f058000 r-xs 00000000 08:01 7665                       /var/cache/fontconfig/8d4af663993b81a124ee82e610bb31f9-x86-64.cache-2
7f871f058000-7f871f0ca000 r-xp 00000000 00:17 2245368                    /net/users/oakesjc/test/eclipse/configuration/org.eclipse.osgi/bundles/194/1/.cp/libswt-pi-gtk-3659.so
7f871f0ca000-7f871f1c9000 ---p 00072000 00:17 2245368                    /net/users/oakesjc/test/eclipse/configuration/org.eclipse.osgi/bundles/194/1/.cp/libswt-pi-gtk-3659.so
7f871f1c9000-7f871f1cc000 rwxp 00071000 00:17 2245368                    /net/users/oakesjc/test/eclipse/configuration/org.eclipse.osgi/bundles/194/1/.cp/libswt-pi-gtk-3659.so
7f871f1cc000-7f871f1ce000 rwxp 00000000 00:00 0
7f871f1ce000-7f871f257000 r-xs 00000000 00:17 2245224                    /net/users/oakesjc/test/eclipse/plugins/org.mortbay.jetty.server_6.1.23.v201004211559.jar
7f871f257000-7f871f2ea000 r-xs 00000000 00:17 2245174                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.update.core_3.2.402.R36x_v20100629.jar
7f871f2ea000-7f871f34d000 r-xs 00000000 00:17 2245132                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.navigator_3.5.0.I20100601-0800.jar
7f871f34d000-7f871f399000 r-xs 00000000 00:17 2245243                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.intro_3.4.0.v20100427.jar
7f871f399000-7f871f5c9000 r-xs 00000000 00:17 2248372                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.ide_3.6.2.M20101201-0800.jar
7f871f5c9000-7f871f612000 r-xs 00000000 00:17 2245171                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.forms_3.5.2.r36_v20100702.jar
7f871f612000-7f871f633000 r-xs 00000000 00:17 2245120                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.externaltools_3.2.0.v20100427.jar
7f871f633000-7f871f6bb000 r-xs 00000000 00:17 2245165                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.editors_3.6.1.r361_v20100825-0800.jar
7f871f6bb000-7f871f70c000 r-xs 00000000 00:17 2245194                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.cheatsheets_3.4.0.v20100427.jar
7f871f70c000-7f871f732000 r-xs 00000000 00:17 2245257                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui_3.6.2.M20110203-1100.jar
7f871f732000-7f871f76f000 r-xs 00000000 00:17 2245191                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.text_3.5.0.v20100601-1300.jar
7f871f76f000-7f871f8cc000 r-xs 00000000 00:17 2245274                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.team.ui_3.5.102.R36x_v20110203-1036.jar
7f871f8cc000-7f871fa63000 r-xs 00000000 00:17 2245260                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.team.cvs.ui_3.3.302.R36x_v20110203-1036.jar
7f871fa63000-7f871faf1000 r-xs 00000000 00:17 2248420                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.team.cvs.core_3.3.301.R36x_v20110119-0815.jar
7f871faf1000-7f871fd44000 r-xs 00000000 00:17 2248280                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.swt.gtk.linux.x86_64_3.6.2.v3659b.jar
7f871fd44000-7f8720484000 r-xs 00000000 00:17 2245193                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.platform.doc.user_3.6.2.r362_v20101117-0800.jar
7f8720484000-7f87204a5000 r-xs 00000000 00:17 2248377                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.mediawiki.core_1.3.0.v20100608-0100-e3x.jar
7f87204a5000-7f87205d6000 r-xs 00000000 00:17 2248428                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.help.ui_1.3.0.v20100608-0100-e3x.jar
7f87205d6000-7f8720622000 r-xs 00000000 00:17 2245276                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.core_1.3.1.v20100823-0100-e3x.jar
7f8720622000-7f8720631000 r-xs 00000000 00:17 2245279                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.confluence.core_1.3.0.v20100608-0100-e3x.jar
7f8720631000-7f872064c000 r-xs 00000000 00:17 2248358                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.team.ui_3.4.3.v20110131-0100-e3x.jar
7f872064c000-7f87207d6000 r-xs 00000000 00:17 2245137                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.tasks.ui_3.4.3.v20110131-0100-e3x.jar
7f87207d6000-7f8720831000 r-xs 00000000 00:17 2245195                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.tasks.core_3.4.2.v20110131-0300-e3x.jar
7f8720831000-7f8720a35000 r-xs 00000000 00:17 2245116                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.help.ui_3.4.2.v20110131-0100-e3x.jar
7f8720a35000-7f8720a4e000 r-xs 00000000 00:17 2245258                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.discovery.ui_3.4.0.v20110131-0100-e3x.jar
7f8720a4e000-7f8720a62000 r-xs 00000000 00:17 2248423                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.discovery.core_3.4.0.v20110131-0100-e3x.jar
7f8720a62000-7f8720a9a000 r-xs 00000000 00:17 2245189                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.context.ui_3.4.2.v20110131-0100-e3x.jar
7f8720a9a000-7f8720ab5000 r-xs 00000000 00:17 2248262                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.context.core_3.4.1.v20100909-0100-e3x.jar
7f8720ab5000-7f8720abe000 r-xs 00000000 00:17 2245173                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.commons.xmlrpc_3.4.0.v20100608-0100-e3x.jar
7f8720abe000-7f8720b20000 r-xs 00000000 00:17 2248378                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.commons.ui_3.4.0.v20100608-0100-e3x.jar
7f8720b20000-7f8720b31000 r-xs 00000000 00:17 2245272                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.commons.net_3.4.1.v20100625-2100-e3x.jar
7f8720b31000-7f8720b38000 r-xs 00000000 00:17 2245288                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.commons.core_3.4.0.v20100608-0100-e3x.jar
7f8720b38000-7f8720b6a000 r-xs 00000000 00:17 2245169                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.bugzilla.ui_3.4.3.v20110131-0100-e3x.jar
7f8720b6a000-7f8720b6e000 r-xs 00000000 00:17 2248424                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.bugzilla.ide_3.4.1.v20110131-0100-e3x.jar
7f8720b6e000-7f8720ba3000 r-xs 00000000 00:17 2248271                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.bugzilla.core_3.4.2.v20100902-0100-e3x.jar
7f8720ba3000-7f8720ba6000 r-xs 00000000 00:17 2245287                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn_3.4.0.v20110131-0200-e3x.jar
7f8720ba6000-7f8720c16000 r-xs 00000000 00:17 2245175                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.5.0.v20100526-0800.jar
7f8720c16000-7f8720c65000 r-xs 00000000 00:17 2245231                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.5.101.r362_v20101117-0800.jar
7f8720c65000-7f8720c7b000 r-xs 00000000 00:17 2245280                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.jsch.ui_1.1.300.I20100505-1245.jar
7f8720c7b000-7f8720d6a000 r-xs 00000000 00:17 2248268                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.jface.text_3.6.1.r361_v20100825-0800.jar
7f8720d6a000-7f8720dac000 r-xs 00000000 00:17 2245233                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.jface.databinding_1.4.0.I20100601-0800.jar
7f8720dac000-7f8720eb2000 r-xs 00000000 00:17 2245266                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.jface_3.6.2.M20110210-1200.jar
7f8720eb5000-7f8720f11000 r-xs 00000000 08:01 7643                       /var/cache/fontconfig/df311e82a1a24c41a75c2c930223552e-x86-64.cache-2
7f8720f11000-7f8720f14000 r-xs 00000000 08:01 7132754                    /var/cache/fontconfig/43759d6532d7c8fa2377cba0d6368316-x86-64.cache-2
7f8720f14000-7f8720f32000 r-xs 00000000 08:01 7667                       /var/cache/fontconfig/7ef2298fde41cc6eeb7af42e48b7d293-x86-64.cache-2
7f8720f32000-7f8720fb0000 r-xp 00000000 00:17 2245367                    /net/users/oakesjc/test/eclipse/configuration/org.eclipse.osgi/bundles/194/1/.cp/libswt-gtk-3659.so
7f8720fb0000-7f87210af000 ---p 0007e000 00:17 2245367                    /net/users/oakesjc/test/eclipse/configuration/org.eclipse.osgi/bundles/194/1/.cp/libswt-gtk-3659.so
7f87210af000-7f87210b6000 rwxp 0007d000 00:17 2245367                    /net/users/oakesjc/test/eclipse/configuration/org.eclipse.osgi/bundles/194/1/.cp/libswt-gtk-3659.so
7f87210b6000-7f87210b9000 rwxp 00000000 00:00 0
7f87210b9000-7f87210d5000 r-xs 00000000 00:17 2245168                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.preferences_3.3.0.v20100503.jar
7f87210df000-7f87210e9000 r-xs 00000000 08:01 7661                       /var/cache/fontconfig/77e41c5059666d75f92e318d4be8c21e-x86-64.cache-2
7f87210e9000-7f8721116000 r-xs 00000000 00:17 2245106                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.ds_1.2.1.R36x_v20100803.jar
7f8721116000-7f8721127000 r-xs 00000000 00:17 2245259                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.p2.core_2.0.3.R36x_v20110111.jar
7f8721127000-7f872112f000 r-xs 00000000 00:17 2248264                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.p2.directorywatcher_1.0.203.R36x_v20101220.jar
7f872112f000-7f872113a000 r-xs 00000000 00:17 2245136                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.p2.reconciler.dropins_1.1.2.R36x_v20110114.jar
7f872113a000-7f8721151000 r-xs 00000000 00:17 2245230                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.core.runtime.compatibility_3.2.100.v20100505.jar
7f8721151000-7f8721163000 r-xs 00000000 00:17 2245135                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.core.runtime_3.6.0.v20100505.jar
7f8721163000-7f8721178000 r-xs 00000000 00:17 2248422                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.app_1.3.1.R36x_v20100803.jar
7f8721178000-7f8721191000 r-xs 00000000 00:17 2245245                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.common_3.6.0.v20100503.jar
7f8721191000-7f87211af000 r-xs 00000000 00:17 2248425                    /net/users/oakesjc/test/eclipse/plugins/org.sat4j.pb_2.2.0.v20100429.jar
7f87211af000-7f87211df000 r-xs 00000000 00:17 2248370                    /net/users/oakesjc/test/eclipse/plugins/org.sat4j.core_2.2.0.v20100429.jar
7f87211df000-7f872120f000 r-xs 00000000 00:17 2248379                    /net/users/oakesjc/test/eclipse/plugins/org.mortbay.jetty.util_6.1.23.v201004211559.jar
7f872120f000-7f872128b000 r-xs 00000000 00:17 2245107                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.update.ui_3.2.300.v20100512.jar
7f872128b000-7f8721293000 r-xs 00000000 00:17 2245166                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.update.scheduler_3.2.300.v20100512.jar
7f8721293000-7f8721296000 ---p 00000000 00:00 0
7f8721296000-7f8721394000 rwxp 00000000 00:00 0
7f8721395000-7f87213ac000 r-xs 00000000 00:17 2245161                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.core.jobs_3.5.1.R36x_v20100824.jar
7f87213ac000-7f87213c7000 r-xs 00000000 00:17 2245289                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.core.commands_3.6.0.I20100512-1500.jar
7f87213c7000-7f87213f4000 r-xs 00000000 00:17 2245181                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.registry_3.5.0.v20100503.jar
7f87213f4000-7f87213f7000 ---p 00000000 00:00 0
7f87213f7000-7f87214f5000 rwxp 00000000 00:00 0
7f87214f6000-7f872150f000 r-xs 00000000 00:17 2248373                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.update.configurator_3.3.100.v20100512.jar
7f872150f000-7f872151f000 r-xs 00000000 00:17 2248261                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.resources.ui_3.4.1.v20100909-0100-e3x.jar
7f8721522000-7f87215b0000 r-xs 00000000 00:17 2245290                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.6.1.r361_v20100714-0800.jar
7f87215b0000-7f87215ca000 r-xs 00000000 00:17 2248394                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3.5.100.I20100509-0800.jar
7f87215ca000-7f87215ec000 r-xs 00000000 00:17 2248357                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.views.log_1.0.100.v20110210_r362.jar
7f87215ec000-7f8721614000 r-xs 00000000 00:17 2245123                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.console_3.5.0.v20100526.jar
7f8721614000-7f8721643000 r-xs 00000000 00:17 2245277                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.browser_3.3.1.r36_20101216.jar
7f8721643000-7f87216a2000 r-xs 00000000 00:17 2245204                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.team.core_3.5.101.R36x_v20110203-1036.jar
7f87216a2000-7f8721714000 r-xs 00000000 00:17 2245183                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.search_3.6.0.v20100520-0800.jar
7f8721714000-7f872171a000 r-xs 00000000 00:17 2245207                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.osgi.util_3.2.100.v20100503.jar
7f872171a000-7f872172b000 r-xs 00000000 00:17 2245162                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.osgi.services_3.2.100.v20100503.jar
7f872172b000-7f872178e000 r-xs 00000000 00:17 2245284                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.ui_1.3.0.v20100608-0100-e3x.jar
7f872178e000-7f8721797000 r-xs 00000000 00:17 2248388                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.jsch.core_1.1.200.I20100505-1245.jar
7f8721797000-7f87217ad000 r-xs 00000000 00:17 2245160                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.views_3.5.1.M20110202-0800.jar
7f87217ad000-7f87217b9000 r-xs 00000000 00:17 2245209                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.twiki.core_1.3.0.v20100608-0100-e3x.jar
7f87217b9000-7f87217c8000 r-xs 00000000 00:17 2245134                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.tracwiki.core_1.3.0.v20100608-0100-e3x.jar
7f87217c8000-7f87217cb000 ---p 00000000 00:00 0
7f87217cb000-7f87218c9000 rwxp 00000000 00:00 0
7f87218c9000-7f87218cc000 ---p 00000000 00:00 0
7f87218cc000-7f87219ca000 rwxp 00000000 00:00 0
7f87219ca000-7f87219cd000 ---p 00000000 00:00 0
7f87219cd000-7f8721acb000 rwxp 00000000 00:00 0
7f8721acb000-7f8721ad2000 r-xp 00000000 00:17 3788759                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libnio.so
7f8721ad2000-7f8721bd1000 ---p 00007000 00:17 3788759                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libnio.so
7f8721bd1000-7f8721bd3000 rwxp 00006000 00:17 3788759                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libnio.so
7f8721bd3000-7f8721be5000 r-xp 00000000 00:17 3788758                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libnet.so
7f8721be5000-7f8721ce4000 ---p 00012000 00:17 3788758                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libnet.so
7f8721ce4000-7f8721ce7000 rwxp 00011000 00:17 3788758                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libnet.so
7f8721ce7000-7f8721e00000 r-xs 00000000 00:17 2245128                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.osgi_3.6.2.R36x_v20110210.jar
7f8721e00000-7f8721e63000 rwxp 00000000 00:00 0
7f8721e63000-7f8721e67000 r-xp 00000000 08:01 147268                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7f8721e67000-7f8722066000 ---p 00004000 08:01 147268                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7f8722066000-7f8722067000 r-xp 00003000 08:01 147268                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7f8722067000-7f8722068000 rwxp 00004000 08:01 147268                     /usr/lib64/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
7f872206c000-7f8722073000 r-xs 00000000 08:01 7646                       /var/cache/fontconfig/d62e99ef547d1d24cdb1bd22ec1a2976-x86-64.cache-2
7f8722073000-7f872208c000 r-xs 00000000 00:17 2245270                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.200.I20100517-1500.jar
7f872208c000-7f8722099000 r-xs 00000000 00:17 2248269                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.monitor.ui_3.4.1.v20110131-0100-e3x.jar
7f872209a000-7f87220b8000 r-xs 00000000 00:17 2248418                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.navigator.resources_3.4.202.M20101124-0800.jar
7f87220b8000-7f87220c7000 r-xs 00000000 00:17 2245196                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.textile.core_1.3.0.v20100608-0100-e3x.jar
7f87220c7000-7f87220d7000 r-xs 00000000 00:17 2248386                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.tasks.ui_1.3.1.v20100823-0100-e3x.jar
7f87220d7000-7f87220e8000 r-xs 00000000 00:17 2248286                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.tasks.search_3.4.0.v20100608-0100-e3x.jar
7f87220e8000-7f87220fe000 r-xs 00000000 00:17 2248391                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.tasks.bugs_3.4.1.v20100823-0100-e3x.jar
7f87220fe000-7f8722107000 r-xs 00000000 00:17 2245185                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.ide.ui_3.4.0.v20100608-0100-e3x.jar
7f8722107000-7f8722168000 rwxp 00000000 00:00 0
7f8722168000-7f8722171000 r-xp 00000000 08:01 146417                     /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7f8722171000-7f8722371000 ---p 00009000 08:01 146417                     /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7f8722371000-7f8722372000 r-xp 00009000 08:01 146417                     /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7f8722372000-7f8722373000 rwxp 0000a000 08:01 146417                     /usr/lib64/gtk-2.0/2.10.0/engines/libpixmap.so
7f8722373000-7f872239b000 r-xp 00000000 08:01 147249                     /usr/lib64/gtk-2.0/2.10.0/engines/libclearlooks.so
7f872239b000-7f872259a000 ---p 00028000 08:01 147249                     /usr/lib64/gtk-2.0/2.10.0/engines/libclearlooks.so
7f872259a000-7f872259b000 r-xp 00027000 08:01 147249                     /usr/lib64/gtk-2.0/2.10.0/engines/libclearlooks.so
7f872259b000-7f872259c000 rwxp 00028000 08:01 147249                     /usr/lib64/gtk-2.0/2.10.0/engines/libclearlooks.so
7f872259c000-7f87226b9000 r-xp 00000000 08:01 19146                      /usr/lib/locale/en_US.utf8/LC_COLLATE
7f87226b9000-7f87226d7000 r-xp 00000000 08:01 143490                     /usr/lib64/libatk-1.0.so.0.2809.1
7f87226d7000-7f87228d6000 ---p 0001e000 08:01 143490                     /usr/lib64/libatk-1.0.so.0.2809.1
7f87228d6000-7f87228d8000 r-xp 0001d000 08:01 143490                     /usr/lib64/libatk-1.0.so.0.2809.1
7f87228d8000-7f87228d9000 rwxp 0001f000 08:01 143490                     /usr/lib64/libatk-1.0.so.0.2809.1
7f87228d9000-7f8722cd0000 r-xp 00000000 08:01 146435                     /usr/lib64/libgtk-x11-2.0.so.0.1800.9
7f8722cd0000-7f8722ecf000 ---p 003f7000 08:01 146435                     /usr/lib64/libgtk-x11-2.0.so.0.1800.9
7f8722ecf000-7f8722ed6000 r-xp 003f6000 08:01 146435                     /usr/lib64/libgtk-x11-2.0.so.0.1800.9
7f8722ed6000-7f8722eda000 rwxp 003fd000 08:01 146435                     /usr/lib64/libgtk-x11-2.0.so.0.1800.9
7f8722eda000-7f8722edc000 rwxp 00000000 00:00 0
7f8722edc000-7f8722ef8000 r-xp 00000000 08:01 230819                     /lib64/libselinux.so.1
7f8722ef8000-7f87230f7000 ---p 0001c000 08:01 230819                     /lib64/libselinux.so.1
7f87230f7000-7f87230f8000 r-xp 0001b000 08:01 230819                     /lib64/libselinux.so.1
7f87230f8000-7f87230f9000 rwxp 0001c000 08:01 230819                     /lib64/libselinux.so.1
7f87230f9000-7f87230fa000 rwxp 00000000 00:00 0
7f87230fa000-7f872310d000 r-xp 00000000 08:01 230808                     /lib64/libresolv-2.11.1.so
7f872310d000-7f872330d000 ---p 00013000 08:01 230808                     /lib64/libresolv-2.11.1.so
7f872330d000-7f872330e000 r-xp 00013000 08:01 230808                     /lib64/libresolv-2.11.1.so
7f872330e000-7f872330f000 rwxp 00014000 08:01 230808                     /lib64/libresolv-2.11.1.so
7f872330f000-7f8723311000 rwxp 00000000 00:00 0
7f8723311000-7f8723338000 r-xp 00000000 08:01 230810                     /lib64/libexpat.so.1.5.2
7f8723338000-7f8723538000 ---p 00027000 08:01 230810                     /lib64/libexpat.so.1.5.2
7f8723538000-7f872353a000 r-xp 00027000 08:01 230810                     /lib64/libexpat.so.1.5.2
7f872353a000-7f872353b000 rwxp 00029000 08:01 230810                     /lib64/libexpat.so.1.5.2
7f872353b000-7f8723562000 r-xp 00000000 08:01 143123                     /usr/lib64/libpangoft2-1.0.so.0.2600.2
7f8723562000-7f8723762000 ---p 00027000 08:01 143123                     /usr/lib64/libpangoft2-1.0.so.0.2600.2
7f8723762000-7f8723763000 r-xp 00027000 08:01 143123                     /usr/lib64/libpangoft2-1.0.so.0.2600.2
7f8723763000-7f8723764000 rwxp 00028000 08:01 143123                     /usr/lib64/libpangoft2-1.0.so.0.2600.2
7f8723764000-7f8723767000 r-xp 00000000 08:01 155667                     /usr/lib64/libgmodule-2.0.so.0.2200.5
7f8723767000-7f8723966000 ---p 00003000 08:01 155667                     /usr/lib64/libgmodule-2.0.so.0.2200.5
7f8723966000-7f8723967000 r-xp 00002000 08:01 155667                     /usr/lib64/libgmodule-2.0.so.0.2200.5
7f8723967000-7f8723968000 rwxp 00003000 08:01 155667                     /usr/lib64/libgmodule-2.0.so.0.2200.5
7f8723968000-7f8723a0d000 r-xp 00000000 08:01 141056                     /usr/lib64/libgio-2.0.so.0.2200.5
7f8723a0d000-7f8723c0c000 ---p 000a5000 08:01 141056                     /usr/lib64/libgio-2.0.so.0.2200.5
7f8723c0c000-7f8723c0e000 r-xp 000a4000 08:01 141056                     /usr/lib64/libgio-2.0.so.0.2200.5
7f8723c0e000-7f8723c0f000 rwxp 000a6000 08:01 141056                     /usr/lib64/libgio-2.0.so.0.2200.5
7f8723c0f000-7f8723c10000 rwxp 00000000 00:00 0
7f8723c10000-7f8723c2a000 r-xp 00000000 08:01 143131                     /usr/lib64/libgdk_pixbuf-2.0.so.0.1800.9
7f8723c2a000-7f8723e2a000 ---p 0001a000 08:01 143131                     /usr/lib64/libgdk_pixbuf-2.0.so.0.1800.9
7f8723e2a000-7f8723e2b000 r-xp 0001a000 08:01 143131                     /usr/lib64/libgdk_pixbuf-2.0.so.0.1800.9
7f8723e2b000-7f8723e2c000 rwxp 0001b000 08:01 143131                     /usr/lib64/libgdk_pixbuf-2.0.so.0.1800.9
7f8723e2c000-7f8723e2e000 r-xp 00000000 08:01 148557                     /usr/lib64/libXau.so.6.0.0
7f8723e2e000-7f872402e000 ---p 00002000 08:01 148557                     /usr/lib64/libXau.so.6.0.0
7f872402e000-7f872402f000 r-xp 00002000 08:01 148557                     /usr/lib64/libXau.so.6.0.0
7f872402f000-7f8724030000 rwxp 00003000 08:01 148557                     /usr/lib64/libXau.so.6.0.0
7f8724030000-7f872404b000 r-xp 00000000 08:01 155781                     /usr/lib64/libxcb.so.1.0.0
7f872404b000-7f872424a000 ---p 0001b000 08:01 155781                     /usr/lib64/libxcb.so.1.0.0
7f872424a000-7f872424b000 r-xp 0001a000 08:01 155781                     /usr/lib64/libxcb.so.1.0.0
7f872424b000-7f872424c000 rwxp 0001b000 08:01 155781                     /usr/lib64/libxcb.so.1.0.0
7f872424c000-7f872424d000 r-xp 00000000 08:01 143412                     /usr/lib64/libxcb-xlib.so.0.0.0
7f872424d000-7f872444c000 ---p 00001000 08:01 143412                     /usr/lib64/libxcb-xlib.so.0.0.0
7f872444c000-7f872444d000 r-xp 00000000 08:01 143412                     /usr/lib64/libxcb-xlib.so.0.0.0
7f872444d000-7f872444e000 rwxp 00001000 08:01 143412                     /usr/lib64/libxcb-xlib.so.0.0.0
7f872444e000-7f8724585000 r-xp 00000000 08:01 141221                     /usr/lib64/libX11.so.6.2.0
7f8724585000-7f8724785000 ---p 00137000 08:01 141221                     /usr/lib64/libX11.so.6.2.0
7f8724785000-7f8724786000 r-xp 00137000 08:01 141221                     /usr/lib64/libX11.so.6.2.0
7f8724786000-7f872478b000 rwxp 00138000 08:01 141221                     /usr/lib64/libX11.so.6.2.0
7f872478b000-7f87247a0000 r-xp 00000000 08:01 230791                     /lib64/libz.so.1.2.3
7f87247a0000-7f872499f000 ---p 00015000 08:01 230791                     /lib64/libz.so.1.2.3
7f872499f000-7f87249a0000 r-xp 00014000 08:01 230791                     /lib64/libz.so.1.2.3
7f87249a0000-7f87249a1000 rwxp 00015000 08:01 230791                     /lib64/libz.so.1.2.3
7f87249a1000-7f87249aa000 r-xp 00000000 08:01 146296                     /usr/lib64/libXrender.so.1.3.0
7f87249aa000-7f8724ba9000 ---p 00009000 08:01 146296                     /usr/lib64/libXrender.so.1.3.0
7f8724ba9000-7f8724baa000 r-xp 00008000 08:01 146296                     /usr/lib64/libXrender.so.1.3.0
7f8724baa000-7f8724bab000 rwxp 00009000 08:01 146296                     /usr/lib64/libXrender.so.1.3.0
7f8724bab000-7f8724bb2000 r-xp 00000000 08:01 155278                     /usr/lib64/libxcb-render.so.0.0.0
7f8724bb2000-7f8724db2000 ---p 00007000 08:01 155278                     /usr/lib64/libxcb-render.so.0.0.0
7f8724db2000-7f8724db3000 r-xp 00007000 08:01 155278                     /usr/lib64/libxcb-render.so.0.0.0
7f8724db3000-7f8724db4000 rwxp 00008000 08:01 155278                     /usr/lib64/libxcb-render.so.0.0.0
7f8724db4000-7f8724db7000 r-xp 00000000 08:01 141136                     /usr/lib64/libxcb-render-util.so.0.0.0
7f8724db7000-7f8724fb6000 ---p 00003000 08:01 141136                     /usr/lib64/libxcb-render-util.so.0.0.0
7f8724fb6000-7f8724fb7000 r-xp 00002000 08:01 141136                     /usr/lib64/libxcb-render-util.so.0.0.0
7f8724fb7000-7f8724fb8000 rwxp 00003000 08:01 141136                     /usr/lib64/libxcb-render-util.so.0.0.0
7f8724fb8000-7f8724fdf000 r-xp 00000000 08:01 157155                     /usr/lib64/libpng12.so.0.31.0
7f8724fdf000-7f87251de000 ---p 00027000 08:01 157155                     /usr/lib64/libpng12.so.0.31.0
7f87251de000-7f87251df000 r-xp 00026000 08:01 157155                     /usr/lib64/libpng12.so.0.31.0
7f87251df000-7f87251e0000 rwxp 00027000 08:01 157155                     /usr/lib64/libpng12.so.0.31.0
7f87251e0000-7f8725210000 r-xp 00000000 08:01 143439                     /usr/lib64/libfontconfig.so.1.3.0
7f8725210000-7f8725410000 ---p 00030000 08:01 143439                     /usr/lib64/libfontconfig.so.1.3.0
7f8725410000-7f8725411000 r-xp 00030000 08:01 143439                     /usr/lib64/libfontconfig.so.1.3.0
7f8725411000-7f8725412000 rwxp 00031000 08:01 143439                     /usr/lib64/libfontconfig.so.1.3.0
7f8725412000-7f8725491000 r-xp 00000000 08:01 148163                     /usr/lib64/libfreetype.so.6.3.18
7f8725491000-7f8725691000 ---p 0007f000 08:01 148163                     /usr/lib64/libfreetype.so.6.3.18
7f8725691000-7f8725696000 r-xp 0007f000 08:01 148163                     /usr/lib64/libfreetype.so.6.3.18
7f8725696000-7f8725697000 rwxp 00084000 08:01 148163                     /usr/lib64/libfreetype.so.6.3.18
7f8725697000-7f87256ed000 r-xp 00000000 08:01 148046                     /usr/lib64/libpixman-1.so.0.16.0
7f87256ed000-7f87258ed000 ---p 00056000 08:01 148046                     /usr/lib64/libpixman-1.so.0.16.0
7f87258ed000-7f87258f0000 r-xp 00056000 08:01 148046                     /usr/lib64/libpixman-1.so.0.16.0
7f87258f0000-7f87258f1000 rwxp 00059000 08:01 148046                     /usr/lib64/libpixman-1.so.0.16.0
7f87258f1000-7f872596c000 r-xp 00000000 08:01 157066                     /usr/lib64/libcairo.so.2.10800.8
7f872596c000-7f8725b6c000 ---p 0007b000 08:01 157066                     /usr/lib64/libcairo.so.2.10800.8
7f8725b6c000-7f8725b6e000 r-xp 0007b000 08:01 157066                     /usr/lib64/libcairo.so.2.10800.8
7f8725b6e000-7f8725b6f000 rwxp 0007d000 08:01 157066                     /usr/lib64/libcairo.so.2.10800.8
7f8725b6f000-7f8725b74000 r-xp 00000000 08:01 148864                     /usr/lib64/libXfixes.so.3.1.0
7f8725b74000-7f8725d73000 ---p 00005000 08:01 148864                     /usr/lib64/libXfixes.so.3.1.0
7f8725d73000-7f8725d74000 r-xp 00004000 08:01 148864                     /usr/lib64/libXfixes.so.3.1.0
7f8725d74000-7f8725d75000 rwxp 00005000 08:01 148864                     /usr/lib64/libXfixes.so.3.1.0
7f8725d75000-7f8725d77000 r-xp 00000000 08:01 147125                     /usr/lib64/libXdamage.so.1.1.0
7f8725d77000-7f8725f76000 ---p 00002000 08:01 147125                     /usr/lib64/libXdamage.so.1.1.0
7f8725f76000-7f8725f77000 r-xp 00001000 08:01 147125                     /usr/lib64/libXdamage.so.1.1.0
7f8725f77000-7f8725f78000 rwxp 00002000 08:01 147125                     /usr/lib64/libXdamage.so.1.1.0
7f8725f78000-7f8725f89000 r-xp 00000000 08:01 157084                     /usr/lib64/libXext.so.6.4.0
7f8725f89000-7f8726188000 ---p 00011000 08:01 157084                     /usr/lib64/libXext.so.6.4.0
7f8726188000-7f8726189000 r-xp 00010000 08:01 157084                     /usr/lib64/libXext.so.6.4.0
7f8726189000-7f872618a000 rwxp 00011000 08:01 157084                     /usr/lib64/libXext.so.6.4.0
7f872618a000-7f872618c000 r-xp 00000000 08:01 141208                     /usr/lib64/libXcomposite.so.1.0.0
7f872618c000-7f872638b000 ---p 00002000 08:01 141208                     /usr/lib64/libXcomposite.so.1.0.0
7f872638b000-7f872638c000 r-xp 00001000 08:01 141208                     /usr/lib64/libXcomposite.so.1.0.0
7f872638c000-7f872638d000 rwxp 00002000 08:01 141208                     /usr/lib64/libXcomposite.so.1.0.0
7f872638d000-7f8726397000 r-xp 00000000 08:01 157101                     /usr/lib64/libXcursor.so.1.0.2
7f8726397000-7f8726596000 ---p 0000a000 08:01 157101                     /usr/lib64/libXcursor.so.1.0.2
7f8726596000-7f8726597000 r-xp 00009000 08:01 157101                     /usr/lib64/libXcursor.so.1.0.2
7f8726597000-7f8726598000 rwxp 0000a000 08:01 157101                     /usr/lib64/libXcursor.so.1.0.2
7f8726598000-7f87265a0000 r-xp 00000000 08:01 143459                     /usr/lib64/libXrandr.so.2.2.0
7f87265a0000-7f872679f000 ---p 00008000 08:01 143459                     /usr/lib64/libXrandr.so.2.2.0
7f872679f000-7f87267a0000 r-xp 00007000 08:01 143459                     /usr/lib64/libXrandr.so.2.2.0
7f87267a0000-7f87267a1000 rwxp 00008000 08:01 143459                     /usr/lib64/libXrandr.so.2.2.0
7f87267a1000-7f87267aa000 r-xp 00000000 08:01 147154                     /usr/lib64/libXi.so.6.0.0
7f87267aa000-7f87269a9000 ---p 00009000 08:01 147154                     /usr/lib64/libXi.so.6.0.0
7f87269a9000-7f87269aa000 r-xp 00008000 08:01 147154                     /usr/lib64/libXi.so.6.0.0
7f87269aa000-7f87269ab000 rwxp 00009000 08:01 147154                     /usr/lib64/libXi.so.6.0.0
7f87269ab000-7f87269ad000 r-xp 00000000 08:01 147155                     /usr/lib64/libXinerama.so.1.0.0
7f87269ad000-7f8726bac000 ---p 00002000 08:01 147155                     /usr/lib64/libXinerama.so.1.0.0
7f8726bac000-7f8726bad000 r-xp 00001000 08:01 147155                     /usr/lib64/libXinerama.so.1.0.0
7f8726bad000-7f8726bae000 rwxp 00002000 08:01 147155                     /usr/lib64/libXinerama.so.1.0.0
7f8726bae000-7f8726bf6000 r-xp 00000000 08:01 148225                     /usr/lib64/libpango-1.0.so.0.2600.2
7f8726bf6000-7f8726df5000 ---p 00048000 08:01 148225                     /usr/lib64/libpango-1.0.so.0.2600.2
7f8726df5000-7f8726df7000 r-xp 00047000 08:01 148225                     /usr/lib64/libpango-1.0.so.0.2600.2
7f8726df7000-7f8726df8000 rwxp 00049000 08:01 148225                     /usr/lib64/libpango-1.0.so.0.2600.2
7f8726df8000-7f8726e03000 r-xp 00000000 08:01 141219                     /usr/lib64/libpangocairo-1.0.so.0.2600.2
7f8726e03000-7f8727002000 ---p 0000b000 08:01 141219                     /usr/lib64/libpangocairo-1.0.so.0.2600.2
7f8727002000-7f8727003000 r-xp 0000a000 08:01 141219                     /usr/lib64/libpangocairo-1.0.so.0.2600.2
7f8727003000-7f8727004000 rwxp 0000b000 08:01 141219                     /usr/lib64/libpangocairo-1.0.so.0.2600.2
7f8727004000-7f87270ac000 r-xp 00000000 08:01 5967224                    /usr/lib64/libgdk-x11-2.0.so.0.1800.9
7f87270ac000-7f87272ab000 ---p 000a8000 08:01 5967224                    /usr/lib64/libgdk-x11-2.0.so.0.1800.9
7f87272ab000-7f87272af000 r-xp 000a7000 08:01 5967224                    /usr/lib64/libgdk-x11-2.0.so.0.1800.9
7f87272af000-7f87272b1000 rwxp 000ab000 08:01 5967224                    /usr/lib64/libgdk-x11-2.0.so.0.1800.9
7f87272b1000-7f87272e0000 r-xp 00000000 08:01 155644                     /usr/lib64/libpcre.so.0.0.1
7f87272e0000-7f87274df000 ---p 0002f000 08:01 155644                     /usr/lib64/libpcre.so.0.0.1
7f87274df000-7f87274e0000 r-xp 0002e000 08:01 155644                     /usr/lib64/libpcre.so.0.0.1
7f87274e0000-7f87274e1000 rwxp 0002f000 08:01 155644                     /usr/lib64/libpcre.so.0.0.1
7f87274e1000-7f87275a5000 r-xp 00000000 08:01 142335                     /usr/lib64/libglib-2.0.so.0.2200.5
7f87275a5000-7f87277a4000 ---p 000c4000 08:01 142335                     /usr/lib64/libglib-2.0.so.0.2200.5
7f87277a4000-7f87277a5000 r-xp 000c3000 08:01 142335                     /usr/lib64/libglib-2.0.so.0.2200.5
7f87277a5000-7f87277a6000 rwxp 000c4000 08:01 142335                     /usr/lib64/libglib-2.0.so.0.2200.5
7f87277a6000-7f87277a7000 rwxp 00000000 00:00 0
7f87277a7000-7f87277e9000 r-xp 00000000 08:01 147138                     /usr/lib64/libgobject-2.0.so.0.2200.5
7f87277e9000-7f87279e8000 ---p 00042000 08:01 147138                     /usr/lib64/libgobject-2.0.so.0.2200.5
7f87279e8000-7f87279e9000 r-xp 00041000 08:01 147138                     /usr/lib64/libgobject-2.0.so.0.2200.5
7f87279e9000-7f87279ea000 rwxp 00042000 08:01 147138                     /usr/lib64/libgobject-2.0.so.0.2200.5
7f87279ea000-7f87279eb000 rwxp 00000000 00:00 0
7f87279ec000-7f87279ef000 r-xs 00000000 00:17 2245214                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry_3.3.0.v20100520/runtime_registry_compatibility.jar
7f87279f5000-7f8727a05000 r-xs 00000000 00:17 2248274                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.ide.application_1.0.201.M20100707-0800.jar
7f8727a05000-7f8727a0c000 r-xs 00000000 00:17 2245211                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.300.I20100526-0800.jar
7f8727a0c000-7f8727a11000 r-xs 00000000 00:17 2248380                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.swt_3.6.2.v3659c.jar
7f8727a11000-7f8727a15000 r-xs 00000000 00:17 2245256                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.rcp_3.6.0.v201102101200.jar
7f8727a15000-7f8727a18000 r-xs 00000000 00:17 2245210                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.twiki.ui_1.3.0.v20100608-0100-e3x.jar
7f8727a18000-7f8727a1b000 r-xs 00000000 00:17 2245282                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.mediawiki.ui_1.3.0.v20100608-0100-e3x.jar
7f8727a1b000-7f8727a1e000 r-xs 00000000 00:17 2245188                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.confluence.ui_1.3.0.v20100608-0100-e3x.jar
7f8727a1e000-7f8727a1f000 r-xp 00000000 08:01 20041                      /usr/lib/locale/en_US.utf8/LC_MONETARY
7f8727a1f000-7f8727a20000 r-xp 00000000 08:01 19899                      /usr/lib/locale/en_US.utf8/LC_MESSAGES/SYS_LC_MESSAGES
7f8727a20000-7f8727a21000 r-xp 00000000 08:01 19455                      /usr/lib/locale/en_US.utf8/LC_PAPER
7f8727a21000-7f8727a22000 r-xp 00000000 08:01 19337                      /usr/lib/locale/en_US.utf8/LC_NAME
7f8727a22000-7f8727a23000 r-xp 00000000 08:01 20039                      /usr/lib/locale/en_US.utf8/LC_ADDRESS
7f8727a23000-7f8727a24000 r-xp 00000000 08:01 19905                      /usr/lib/locale/en_US.utf8/LC_TELEPHONE
7f8727a24000-7f8727a25000 r-xp 00000000 08:01 19800                      /usr/lib/locale/en_US.utf8/LC_MEASUREMENT
7f8727a25000-7f8727a26000 r-xp 00000000 08:01 20040                      /usr/lib/locale/en_US.utf8/LC_IDENTIFICATION
7f8727a26000-7f8727a35000 r-xp 00000000 00:17 2245141                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.2.R36x_v20101019_1345/eclipse_1310.so
7f8727a35000-7f8727b34000 ---p 0000f000 00:17 2245141                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.2.R36x_v20101019_1345/eclipse_1310.so
7f8727b34000-7f8727b36000 rwxp 0000e000 00:17 2245141                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.2.R36x_v20101019_1345/eclipse_1310.so
7f8727b36000-7f8727bfc000 r-xs 00000000 00:17 3818588                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/ext/localedata.jar
7f8727bfc000-7f8727bfd000 ---p 00000000 00:00 0
7f8727bfd000-7f8727cfd000 rwxp 00000000 00:00 0
7f8727cfd000-7f8727d00000 ---p 00000000 00:00 0
7f8727d00000-7f8727dfe000 rwxp 00000000 00:00 0
7f8727dfe000-7f8727e01000 ---p 00000000 00:00 0
7f8727e01000-7f8727eff000 rwxp 00000000 00:00 0
7f8727eff000-7f8727f02000 ---p 00000000 00:00 0
7f8727f02000-7f8728000000 rwxp 00000000 00:00 0
7f8728000000-7f8728ae2000 rwxp 00000000 00:00 0
7f8728ae2000-7f872c000000 ---p 00000000 00:00 0
7f872c000000-7f872c003000 r-xs 00000000 00:17 2248364                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.workbench.compatibility_3.2.100.I20100511-0800/compatibility.jar
7f872c003000-7f872c00f000 r-xs 00000000 00:17 2245129                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.ui.net_1.2.100.I20100505-1245.jar
7f872c00f000-7f872c012000 r-xs 00000000 00:17 2245114                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.tracwiki.ui_1.3.0.v20100608-0100-e3x.jar
7f872c012000-7f872c015000 r-xs 00000000 00:17 2245133                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.wikitext.textile.ui_1.3.0.v20100608-0100-e3x.jar
7f872c015000-7f872c01e000 r-xs 00000000 00:17 2245281                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.monitor.core_3.4.0.v20100608-0100-e3x.jar
7f872c01e000-7f872c049000 r-xs 00000000 00:17 3788743                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/ext/sunpkcs11.jar
7f872c049000-7f872c070000 r-xs 00000000 00:17 3788744                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/ext/sunjce_provider.jar
7f872c070000-7f872c07c000 r-xs 00000000 00:17 2245238                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
7f872c07c000-7f872c07f000 ---p 00000000 00:00 0
7f872c07f000-7f872c17d000 rwxp 00000000 00:00 0
7f872c17d000-7f872c180000 ---p 00000000 00:00 0
7f872c180000-7f872c27e000 rwxp 00000000 00:00 0
7f872c27e000-7f872c2bd000 r-xp 00000000 08:01 19145                      /usr/lib/locale/en_US.utf8/LC_CTYPE
7f872c2bd000-7f872c2c0000 ---p 00000000 00:00 0
7f872c2c0000-7f872c3be000 rwxp 00000000 00:00 0
7f872c3be000-7f872c3c1000 ---p 00000000 00:00 0
7f872c3c1000-7f872c4bf000 rwxp 00000000 00:00 0
7f872c4bf000-7f872c4c0000 ---p 00000000 00:00 0
7f872c4c0000-7f872c6a7000 rwxp 00000000 00:00 0
7f872c6a7000-7f872c6a8000 ---p 00000000 00:00 0
7f872c6a8000-7f872c7a8000 rwxp 00000000 00:00 0
7f872c7a8000-7f872c7a9000 ---p 00000000 00:00 0
7f872c7a9000-7f872c8a9000 rwxp 00000000 00:00 0
7f872c8a9000-7f872c8aa000 ---p 00000000 00:00 0
7f872c8aa000-7f872c9aa000 rwxp 00000000 00:00 0
7f872c9aa000-7f872c9ab000 ---p 00000000 00:00 0
7f872c9ab000-7f872caab000 rwxp 00000000 00:00 0
7f872caab000-7f872caac000 ---p 00000000 00:00 0
7f872caac000-7f872cbac000 rwxp 00000000 00:00 0
7f872cbac000-7f872cbad000 ---p 00000000 00:00 0
7f872cbad000-7f872ccad000 rwxp 00000000 00:00 0
7f872ccad000-7f872ccae000 ---p 00000000 00:00 0
7f872ccae000-7f872cdae000 rwxp 00000000 00:00 0
7f872cdae000-7f872cdaf000 ---p 00000000 00:00 0
7f872cdaf000-7f872ceba000 rwxp 00000000 00:00 0
7f872ceba000-7f872cf2f000 rwxp 00000000 00:00 0
7f872cf2f000-7f872cf3d000 rwxp 00000000 00:00 0
7f872cf3d000-7f872cfaf000 rwxp 00000000 00:00 0
7f872cfaf000-7f872cfba000 rwxp 00000000 00:00 0
7f872cfba000-7f872d02f000 rwxp 00000000 00:00 0
7f872d02f000-7f872d03d000 rwxp 00000000 00:00 0
7f872d03d000-7f872d0af000 rwxp 00000000 00:00 0
7f872d0af000-7f872d0b8000 rwxp 00000000 00:00 0
7f872d0b8000-7f872d0ef000 rwxp 00000000 00:00 0
7f872d0ef000-7f872e5b0000 rwxp 00000000 00:00 0
7f872e5b0000-7f873d0f0000 rwxp 00000000 00:00 0
7f873d0f0000-7f873eba0000 rwxp 00000000 00:00 0
7f873eba0000-7f874d0f0000 rwxp 00000000 00:00 0
7f874d0f0000-7f874e110000 rwxp 00000000 00:00 0
7f874e110000-7f87550f0000 rwxp 00000000 00:00 0
7f87550f2000-7f87550f9000 r-xs 00000000 08:01 142586                     /usr/lib64/gconv/gconv-modules.cache
7f87550f9000-7f8755103000 rwxp 00000000 00:00 0
7f8755103000-7f87551b9000 rwxp 00000000 00:00 0
7f87551b9000-7f8755429000 rwxp 00000000 00:00 0
7f8755429000-7f87581b9000 rwxp 00000000 00:00 0
7f87581b9000-7f8758a36000 r-xs 00000000 00:17 3818587                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/charsets.jar
7f8758a36000-7f8758abb000 r-xs 00000000 00:17 3818586                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/jsse.jar
7f8758abb000-7f875b11a000 r-xs 00000000 00:17 3818585                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/rt.jar
7f875b11a000-7f875b128000 r-xp 00000000 00:17 3788768                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libzip.so
7f875b128000-7f875b22a000 ---p 0000e000 00:17 3788768                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libzip.so
7f875b22a000-7f875b22e000 rwxp 00010000 00:17 3788768                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libzip.so
7f875b22e000-7f875b252000 r-xp 00000000 00:17 3788779                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libjava.so
7f875b252000-7f875b352000 ---p 00024000 00:17 3788779                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libjava.so
7f875b352000-7f875b358000 rwxp 00024000 00:17 3788779                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libjava.so
7f875b358000-7f875b365000 r-xp 00000000 00:17 3788762                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libverify.so
7f875b365000-7f875b464000 ---p 0000d000 00:17 3788762                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libverify.so
7f875b464000-7f875b467000 rwxp 0000c000 00:17 3788762                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/libverify.so
7f875b467000-7f875b47c000 r-xp 00000000 08:01 230877                     /lib64/libnsl-2.11.1.so
7f875b47c000-7f875b67b000 ---p 00015000 08:01 230877                     /lib64/libnsl-2.11.1.so
7f875b67b000-7f875b67c000 r-xp 00014000 08:01 230877                     /lib64/libnsl-2.11.1.so
7f875b67c000-7f875b67d000 rwxp 00015000 08:01 230877                     /lib64/libnsl-2.11.1.so
7f875b67d000-7f875b67f000 rwxp 00000000 00:00 0
7f875b67f000-7f875b6d4000 r-xp 00000000 08:01 230912                     /lib64/libm-2.11.1.so
7f875b6d4000-7f875b8d3000 ---p 00055000 08:01 230912                     /lib64/libm-2.11.1.so
7f875b8d3000-7f875b8d4000 r-xp 00054000 08:01 230912                     /lib64/libm-2.11.1.so
7f875b8d4000-7f875b8d5000 rwxp 00055000 08:01 230912                     /lib64/libm-2.11.1.so
7f875b8d5000-7f875bfb2000 r-xp 00000000 00:17 3788784                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/server/libjvm.so
7f875bfb2000-7f875c0b1000 ---p 006dd000 00:17 3788784                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/server/libjvm.so
7f875c0b1000-7f875c22e000 rwxp 006dc000 00:17 3788784                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/server/libjvm.so
7f875c22e000-7f875c25d000 rwxp 00000000 00:00 0
7f875c25d000-7f875c3b1000 r-xp 00000000 08:01 230931                     /lib64/libc-2.11.1.so
7f875c3b1000-7f875c5b1000 ---p 00154000 08:01 230931                     /lib64/libc-2.11.1.so
7f875c5b1000-7f875c5b5000 r-xp 00154000 08:01 230931                     /lib64/libc-2.11.1.so
7f875c5b5000-7f875c5b6000 rwxp 00158000 08:01 230931                     /lib64/libc-2.11.1.so
7f875c5b6000-7f875c5bb000 rwxp 00000000 00:00 0
7f875c5bb000-7f875c5bd000 r-xp 00000000 08:01 230769                     /lib64/libdl-2.11.1.so
7f875c5bd000-7f875c7bd000 ---p 00002000 08:01 230769                     /lib64/libdl-2.11.1.so
7f875c7bd000-7f875c7be000 r-xp 00002000 08:01 230769                     /lib64/libdl-2.11.1.so
7f875c7be000-7f875c7bf000 rwxp 00003000 08:01 230769                     /lib64/libdl-2.11.1.so
7f875c7bf000-7f875c7d6000 r-xp 00000000 08:01 230772                     /lib64/libpthread-2.11.1.so
7f875c7d6000-7f875c9d6000 ---p 00017000 08:01 230772                     /lib64/libpthread-2.11.1.so
7f875c9d6000-7f875c9d7000 r-xp 00017000 08:01 230772                     /lib64/libpthread-2.11.1.so
7f875c9d7000-7f875c9d8000 rwxp 00018000 08:01 230772                     /lib64/libpthread-2.11.1.so
7f875c9d8000-7f875c9dc000 rwxp 00000000 00:00 0
7f875c9dc000-7f875c9fa000 r-xp 00000000 08:01 230938                     /lib64/ld-2.11.1.so
7f875c9fa000-7f875c9ff000 r-xs 00000000 00:17 2248265                    /net/users/oakesjc/test/eclipse/plugins/org.eclipse.mylyn.team.cvs_3.4.2.v20110131-0100-e3x.jar
7f875c9ff000-7f875ca00000 r-xp 00000000 08:01 19106                      /usr/lib/locale/en_US.utf8/LC_NUMERIC
7f875ca00000-7f875ca28000 rwxp 00000000 00:00 0
7f875ca28000-7f875ca3d000 r-xs 00000000 00:17 3817539                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/jce.jar
7f875ca3d000-7f875caa7000 rwxp 00000000 00:00 0
7f875caa7000-7f875caaf000 rwxs 00000000 08:01 1535757                    /tmp/hsperfdata_oakesjc/21702
7f875caaf000-7f875cab6000 r-xp 00000000 00:17 3788770                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/native_threads/libhpi.so
7f875cab6000-7f875cbb7000 ---p 00007000 00:17 3788770                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/native_threads/libhpi.so
7f875cbb7000-7f875cbba000 rwxp 00008000 00:17 3788770                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/amd64/native_threads/libhpi.so
7f875cbba000-7f875cbbe000 rwxp 00000000 00:00 0
7f875cbbe000-7f875cbbf000 r-xp 00000000 08:01 20042                      /usr/lib/locale/en_US.utf8/LC_TIME
7f875cbbf000-7f875cbc2000 r-xs 00000000 00:17 3788741                    /net/users/oakesjc/test/jdk1.5.0_22/jre/lib/ext/dnsns.jar
7f875cbc2000-7f875cbf7000 r-xs 00000000 08:01 1526690                    /var/run/nscd/passwd
7f875cbf7000-7f875cbf8000 rwxp 00000000 00:00 0
7f875cbf8000-7f875cbf9000 r-xp 00000000 00:00 0
7f875cbf9000-7f875cbfa000 rwxp 00000000 00:00 0
7f875cbfa000-7f875cbfb000 r-xp 0001e000 08:01 230938                     /lib64/ld-2.11.1.so
7f875cbfb000-7f875cbfc000 rwxp 0001f000 08:01 230938                     /lib64/ld-2.11.1.so
7f875cbfc000-7f875cbfd000 rwxp 00000000 00:00 0
7fffa12ae000-7fffa12b1000 ---p 00000000 00:00 0
7fffa12b2000-7fffa14ae000 rwxp 00000000 00:00 0                          [stack]
7fffa1549000-7fffa154a000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 000000
Re: SIGSEGV causes eclipse CDT to crash at startup - (HotSpot Virtual Machine?) [message #668058 is a reply to message #657958] Tue, 03 May 2011 10:52 Go to previous messageGo to next message
Hi Oakes,
i've got the same error. Did you find a resolution for that issue?
best regards,
Re: SIGSEGV causes eclipse CDT to crash at startup - (HotSpot Virtual Machine?) [message #674100 is a reply to message #668058] Wed, 25 May 2011 16:28 Go to previous messageGo to next message
No, I still have not resolved this problem. I gave up on it hoping to retry once the next version comes out.
Have you gotten any further?
Re: SIGSEGV causes eclipse CDT to crash at startup - (HotSpot Virtual Machine?) [message #718824 is a reply to message #657958] Thu, 25 August 2011 08:47 Go to previous messageGo to next message
BUMP.
I'm revisiting this install. I am still unable to get eclipse working.
I have installed Java 1.6.0_17.
I have installed Eclipse CDT Indigo
I still get the same error
Any thoughts or Suggestions?
(no subject) [message #718873 is a reply to message #718824] Thu, 25 August 2011 10:28 Go to previous messageGo to next message
From your earlier post the crash is in libgdk-x11-2.0.so, not inside the
Java VM. Please try to use a different version of libgdk.
Ubuntu bug references to libgdk-x11-2.0.so:
https://bugs.launchpad.net/ubuntu/+source/gtk+2.0/+bug/703756
https://bugs.launchpad.net/ubuntu/+source/gtk+2.0/+bug/391398
Re: (no subject) [message #718958 is a reply to message #718873] Thu, 25 August 2011 12:34 Go to previous message
Ok thanks. I'll see what happens when I update Gtk.
On a side note, I did determine that this may be an issue with using Hummingbird Exceed to get to my linux machine. I switched over to cygwin and the error went away.
~J
Previous Topic:_va_start compile problem
Next Topic:using cxxSource handler for all *.c file type
Current Time: Sun Jul 20 09:14:51 EDT 2025
Powered by FUDForum. Page generated in 0.04705 seconds
