Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Null pointer exception using profiles(Null pointer using profiles)
[Acceleo] Null pointer exception using profiles [message #673770] Tue, 24 May 2011 13:25 Go to next message
hi all,
I have a simple transformation on a model written using papyrus. The model has only two classes, one of which has applied a stereotype with two tagged values. The profile was written using papyrus.
When I run the transformation a Null pointer exception is raised.
The simple transformation is :
[comment encoding = UTF-8 /]
[module generate('http://www.eclipse.org/uml2/3.0.0/UML')/]
[query public hasStereotype(e : Element, stereoTypeName: String) : Boolean  =
	not self.getAppliedStereotype(stereoTypeName).oclIsUndefined()/]
[query public getTaggedValue(e:Element, stereoTypeName: String, propName :String) : String =
	e.getValue(e.getAppliedStereotype(stereoTypeName), propName)
[template public generate(aClass : Class)]
	[comment @main /]
	[file ('test.txt', true, 'UTF-8')]
[if (aClass.hasStereotype('profile::Store'))]
	Class with stereotype: [aClass.name/]
[/if]
	[/file]
[/template]
The stack trace is :
at org.eclipse.acceleo.engine.internal.environment.DynamicModulesURIConverter.dynamicNormalize(DynamicModulesURIConverter.java:303)
at org.eclipse.acceleo.engine.internal.environment.DynamicModulesURIConverter.normalize(DynamicModulesURIConverter.java:77)
at org.eclipse.uml2.common.util.CacheAdapter$InverseCrossReferencer.normalizeURI(CacheAdapter.java:68)
at org.eclipse.uml2.common.util.CacheAdapter$InverseCrossReferencer.addProxy(CacheAdapter.java:101)
at org.eclipse.uml2.common.util.CacheAdapter.selfAdapt(CacheAdapter.java:526)
at org.eclipse.emf.ecore.util.ECrossReferenceAdapter.notifyChanged(ECrossReferenceAdapter.java:430)
at org.eclipse.uml2.common.util.CacheAdapter.notifyChanged(CacheAdapter.java:342)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:380)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.unload(ResourceImpl.java:1646)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.postGenerate(AbstractAcceleoGenerator.java:453)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:145)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.doGenerate(AbstractAcceleoGenerator.java:120)
at profileTestAcceleo2.files.Generate.doGenerate(Generate.java:148)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoLaunchOperation.run(AcceleoLaunchOperation.java:119)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1975)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1957)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java:225)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java:128)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchDelegate.launch(AcceleoLaunchDelegate.java:53)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:702)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:923)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1126)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
What is wrong?
Thank in advance.
P.S. The output file is generated as expected.
Re: [Acceleo] Null pointer exception using profiles [message #673821 is a reply to message #673770] Tue, 24 May 2011 16:41 Go to previous messageGo to next message
Hi all,
I've found that when I do not use query I do not see any exception. This is very strange for me.
Can some one explain why?
Any help is appreciated
(no subject) [message #673825 is a reply to message #673770] Tue, 24 May 2011 16:41 Go to previous messageGo to next message
Originally posted by: <forums-noreply
Hi all,
Re: (no subject) [message #675136 is a reply to message #673821] Mon, 30 May 2011 07:58 Go to previous messageGo to next message
When we are unloading the resources, the UML cross referencer is notified and it calls the normalize method but this method has been created for EObject contained in a resource. I have modified "normalize" to make sure that the NPE does not appear anymore for EObjects without a resource. Thanks for reporting this. I don't know why this would only be called with a query.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: (no subject) [message #675556 is a reply to message #675136] Tue, 31 May 2011 16:35 Go to previous messageGo to next message
Thank you for the response.
What version of eclipse Acceleo has this patch?
How can I use it?
Re: (no subject) [message #675689 is a reply to message #675556] Wed, 01 June 2011 04:12 Go to previous message
You can grab the latest Release Candidate of Acceleo with this update site: http://download.eclipse.org/modeling/m2t/acceleo/updates/milestones/3.1
You should find this problem fixed in Acceleo 3.1 RC3
Don't hesitate to tell us if this has not fixed your issue.
Previous Topic:[Acceleo] Workspace ecore models URI resolution
Next Topic:org.eclipse.emf.mwe.core.ConfigurationException: Couldn't find an interface ...
Current Time: Sun Jul 20 17:01:41 EDT 2025
Powered by FUDForum. Page generated in 0.04970 seconds
