Problem with migrating bundles to Virgo [message #667167] |
Wed, 27 April 2011 04:13  |
Hi, I'm new to Virgo and I'm trying to get some of my already existing OSGi-Bundles to run. After installing the SpringSource dm Server Tools in Eclipse, I was able to add a Virgo web-server instance to my workspace (I'm running virgo-web-server-2.1.1.RELEASE).
Afterwards I selected "Add OSGi Bundle Project Nature" from the "Spring Tools" menu of the bundle-projects to be able to publish the bundles to Virgo. After deployment, Virgo tells me, the bundle is started, but it always states the bundle version is 0.0.0, even if the MANIFEST.MF specifies another Bundle-Version, also all the Import-Bundles and Export-Bundles are empty - it looks like my MANIFEST.MF is ignored?
Any hints in getting my bundles to run?
Re: Problem with migrating bundles to Virgo [message #672009 is a reply to message #667167] |
Thu, 19 May 2011 10:55  |
The OSGi support of the dm Server tooling is slightly different from the "normal" PDE tooling for OSGi that you can find in Eclipse. But I agree that this is sometimes confusing and should be unified or simplified in the future. At a minimum, you should be able to deploy PDE as well as Bundlor-based projects easily into your Virgo runtime server. And that is definitely a point on our list to work on for the Virgo IDE (the dm Server tooling that moved to the Virgo project).
So stay tuned for improvements in this area...
-Martin
FUDForum. Page generated in 0.04879 seconds
