Home » Eclipse Projects » Rich Client Platform (RCP) » Disable whole menu (not a separate menu item)
Disable whole menu (not a separate menu item) [message #671967] Thu, 19 May 2011 09:37 Go to next message
I have a menu. I would like to disable it programmatically. I know it is possible for a separate menu item, but haven't find how to disable the whole menu.
I am trying the following code:
IWorkbenchWindow window = Workbench.getInstance().getActiveWorkbenchWindow();
MenuManager menuManager = ((WorkbenchWindow)window).getMenuManager();
MenuManager fixActionsMenu = (MenuManager)menuManager.find("my menu id");
fixActionsMenu.getMenu().setEnabled( false);
It doesn't work. Can anybody help ?
Thank you,
Arkady.
Re: Disable whole menu (not a separate menu item) [message #671980 is a reply to message #671967] Thu, 19 May 2011 09:56 Go to previous messageGo to next message
I'll just mention that your code is hacking into eclipse internals, and while it might currently work in 3.6 and possibly even 3.7, it won't work in Eclipse 4.0 or 4.1.
You are also trying to bypass the MenuManager's possible handling of its SWT widget. It can be disposed or re-created based on the algorithms used in the main menu bar.
MenuManager does allow for making its Menu disappear. That might be a better bet for you, using MenuManager.setVisible(false)
How did you contribute this menu in the first place? In your ActionBarAdvisor?
PW
Re: Disable whole menu (not a separate menu item) [message #672240 is a reply to message #671980] Fri, 20 May 2011 08:35 Go to previous messageGo to next message
Paul, thank you for answer.
I contributed by menu first in plugin.xml
I don't have ActionBarAdvisor in this plug-in (I have ActionBarAdvisor in the "main" plugin for my RCP application and this "main" plugin doesn't know nothing about all the rest plugins).
I don't want to hide the menu, I want to enable/disable it programmatically according to some conditions. This is demand of my customer. But if you say it is impossible, I can try to persuade the customer.
My Eclipse is:
Eclipse SDK
Version: 3.6.2
Build id: M20110210-1200
Thank you,
Arkady.
Re: Disable whole menu (not a separate menu item) [message #672253 is a reply to message #672240] Fri, 20 May 2011 09:03 Go to previous messageGo to next message
It's impossible to do it while using any of the API or standard RCP mechanisms in eclipse. You can hack part way there in 3.x, but then that won't work when you finally move to 4.x.
If you cannot convince your customer, there is potentially another option. Use org.eclipse.ui.menus and the <dynamic/> menu contribution in place of the <menu/> element.
You can write your own org.eclipse.jface.action.ContributionItem (painful, but you get to provide either a SWT MenuItem with an SWT Menu or a disabled one with a label) or use org.eclipse.ui.actions.CompoundContributionItem (and alternately provide a MenuManager or a disabled action in an ActionContributionItem) ... these are both hacks. But potentially more reliable then what you are trying to do.
PW
Re: Disable whole menu (not a separate menu item) [message #672277 is a reply to message #672253] Fri, 20 May 2011 10:09 Go to previous messageGo to next message
I have another idea:
I have just saw <menu/> element has "commandid" attribute. So, I can create a command with empty handler (i.e it's "execute" function doesn't do nothing), assign this command to menu, and enable/disable command's handler by a variable using org.eclipse.ui.services
Will try next week and let you know.
Thank you for your time anyway.
Arkady.
Re: Disable whole menu (not a separate menu item) [message #672283 is a reply to message #672277] Fri, 20 May 2011 10:19 Go to previous message
arkadyz wrote on Fri, 20 May 2011 10:09
That command ID is just to identify a shortcut for menus that can be opened separately. Ex, ALT+SHIFT+T opens a local refactor context menu and so should be listed on the main context menu. It won't do what you expect.
PW
Previous Topic:Standalone view not resizable
Next Topic:How to enable the "Save" Command in the EMF Editor
Current Time: Sat Jul 19 09:26:44 EDT 2025
Powered by FUDForum. Page generated in 0.06026 seconds
