Home » Eclipse Projects » EclipseLink » @NamedStoredProcedureQuery and StoredProcedureCall problem
@NamedStoredProcedureQuery and StoredProcedureCall problem [message #671755] Wed, 18 May 2011 17:34 Go to next message
Hi, I have a simple stored procedure like this:
CREATE PROCEDURE zzzSP
  @x           int,
  @y           int,
  @z    varchar(10),
  @message     varchar(255)  output
AS
if @x=1
begin
   select @message = 'ok'
end
else
begin
   select @message = 'not ok'
end
The stored procedure itself works if I call it directly in database tool.
and I tried to use @NamedStoredProcedureQuery and StoredProcedureCall to call it, and both didn't work.and I've been struggling with this for a couple of days. Any thought would be appreciated!
For @NamedStoredProcedureQuery, I have the following
@NamedStoredProcedureQueries (
    @NamedStoredProcedureQuery(name="zzzSP", procedureName="zzzSP",
                  parameters ={
            @StoredProcedureParameter(queryParameter="x", type=Integer.class),
            @StoredProcedureParameter(queryParameter="y", type=Integer.class),
            @StoredProcedureParameter(queryParameter="z", type=String.class),
            @StoredProcedureParameter(queryParameter="message ",direction=Direction.OUT, type=String.class)
Caling code:
Query q = getEntityManager().createNamedQuery("zzzSP");
q.setParameter("x", inputInteger1);
q.setParameter("y", inputInteger2);
q.setParameter("z", "my_input_string");
return (String)q.getSingleResult();
Exception seen in log:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.sybase.jdbc3.jdbc.SybSQLException: Operand type clash: VARCHAR is incompatible with VOID TYPE
Error Code: 206
Call: EXECUTE zzzSP @x = ?, @y = ?, @z = ?, @message = ? OUTPUT
bind => [4 parameters bound]
Query: DataReadQuery(name="zzzSP" ) at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:798)
at org.eclipse.persistence.platform.database.SybasePlatform.executeStoredProcedure(SybasePlatform.java:251)
For the StoredProcedureCall
        PLSQLStoredProcedureCall spcall = new PLSQLStoredProcedureCall();
        spcall.setProcedureName("zzzSP");
        spcall.addNamedArgument("x", JDBCTypes.INTEGER_TYPE);
        spcall.addNamedArgument("y",JDBCTypes.INTEGER_TYPE);
        spcall.addNamedArgument("z",JDBCTypes.VARCHAR_TYPE, 10);
        spcall.addNamedOutputArgument("message",JDBCTypes.VARCHAR_TYPE, 255);
        DataReadQuery query = new DataReadQuery();
        query.addArgument("x");
        query.addArgument("y");
        query.addArgument("z");
        query.addArgument("message");
        query.setCall(spcall);
        List args = new ArrayList();
        args.add(Integer.valueOf(111));
        args.add(Integer.valueOf(222));
        args.add("myStr");
        args.add("");
        query.addArgumentValues(args);
    List results = (List)   session.executeQuery(query
Error seen in log:
Caused by: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: JZ0SB: Parameter index out of range: 1.
Error Code: 0
Call:
DECLARE
x_TARGET INTEGER := :1;
y_TARGET INTEGER := :2;
z_TARGET VARCHAR(10) := :3;
message_TARGET VARCHAR(255);
BEGIN
zzzSP(x=>x_TARGET, y=>y_TARGET, z=>z_TARGET, message=>message_TARGET);
:4 := message_TARGET;
END;
bind => [:1 => 111, :2 => 222, :3 => my_stringdses, message => :4]
Query: DataModifyQuery()
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:333)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:684)
Re: @NamedStoredProcedureQuery and StoredProcedureCall problem [message #672007 is a reply to message #671755] Thu, 19 May 2011 10:50 Go to previous messageGo to next message
See,
http://www.coderanch.com/t/538133/ORM/java/output-parameter-stored-procedure-Operand#2443181
Also, for the PLSQL procedure, PLSQL is specific to Oracle, this will not work with Sybase.
Re: @NamedStoredProcedureQuery and StoredProcedureCall problem [message #672045 is a reply to message #672007] Thu, 19 May 2011 13:14 Go to previous message
got the @NamedStoredProcedureQuery work. thanks.
Previous Topic:eclipselink does two inserts and one update when using cyclic references
Next Topic:Passing parameters to be used in Customizer
Current Time: Sun Jul 20 15:06:05 EDT 2025
Powered by FUDForum. Page generated in 0.03457 seconds
