Home » Archived » M2M (model-to-model transformation) » [ATL] Executing ATL transformation using JAVA or ANT
[ATL] Executing ATL transformation using JAVA or ANT [message #671301] Tue, 17 May 2011 08:41 Go to next message
I am looking for a solution to launch 3 sucessive ATL transformations, that work correctly, whithout having to excecute all the ATL transformations manualy one after the other.
I saw that there are some solutions using some sort of JAVA class ?? or ANT file ??, but i am not sure that these are the best solutions, (or solutions at all) because i tried using some sort of solutions that i found in some earlier threads but whithout sucess.
Thank you for your time.
Re: [ATL] Executing ATL transformation using JAVA or ANT [message #671331 is a reply to message #671301] Tue, 17 May 2011 10:41 Go to previous messageGo to next message
Am 17.05.2011 14:41, schrieb Mehdi:
> other.
Take a look at http://opensource.urszeidler.de/ATLflow/
and
http://opensource.urszeidler.de/ATLflow/html_0.0.20/start_co nfiguration/start_configuration.html
greetings, Urs.
Re: [ATL] Executing ATL transformation using JAVA or ANT [message #671357 is a reply to message #671331] Tue, 17 May 2011 11:42 Go to previous message
Hi and thanks for the response,
i am more interested in the first solution : http://opensource.urszeidler.de/ATLflow/
but i need to download some packages :
org.eclipse.m2m.atl.engine.AtlEMFModelHandler;
org.eclipse.m2m.atl.engine.AtlLauncher;
org.eclipse.m2m.atl.engine.AtlModelHandler;
where can i download them ?
Previous Topic:[QVTO] Problem with debugging M2M transformations
Next Topic:Basics of ATL
Current Time: Sun Jul 20 15:12:28 EDT 2025
Powered by FUDForum. Page generated in 0.04003 seconds
