Home » Archived » BIRT » IHTMLImageHandler not used when rendering images embedded using <IMAGE> tag
IHTMLImageHandler not used when rendering images embedded using <IMAGE> tag [message #670841] Sun, 15 May 2011 16:16 Go to next message
Originally posted by:
I'm using HTMLServerImageHandler to create urls for images in the
report. While this works fine for charts and Image items using embedded
images, it doesn't work when I use <IMAGE name="my_image"/> tag while
defining Text item. To be more precise, it works in web viewer but not
when I use my own code.
Here is my code (I use BIRT 2.6):
IRunAndRenderTask task = engine.createRunAndRenderTask(reportDesign);
HTMLServerImageHandler imageHandler = new HTMLServerImageHandler();
HTMLRenderOption option = new HTMLRenderOption();
option.setOutputFileName(outputFile.getAbsolutePath());
option.setBaseImageURL(baseImageUrl);
option.setImageDirectory(imageDir);
option.setImageHandler(imageHandler);
task.setRenderOption(option);
task.run();
This part of report renders correctly:
<image id="8">
<property name="source">embed</property>
<property name="imageName">my_image</property>
</image>
This does not:
<text id="9">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<IMAGE
name="my_image"/>]]></text-property>
</text>
The HTML produced looks like this:
<img src="file:/tmp/img6647447909864980190.jpg"></img>
Why BIRT doesn't use provided image handler in this case?
What's in the web viewer's code that's not in mine? (I browsed it but
couldn't find any important difference)
Michal
Re: IHTMLImageHandler not used when rendering images embedded using &lt;IMAGE&gt; tag [message #671041 is a reply to message #670841] Mon, 16 May 2011 11:37 Go to previous messageGo to next message
I just tried this in 2.6.1 and it worked fine. Is my_image an embedded
image? If so can you email me the report or a small report with just
the embedded image and the text element?
Jason
Re: IHTMLImageHandler not used when rendering images embedded using &lt;IMAGE&gt; tag [message #671076 is a reply to message #671041] Mon, 16 May 2011 13:02 Go to previous messageGo to next message
> image? If so can you email me the report or a small report with just the
> Jason
Yes, my_image is an embedded image.
When I launch report from Eclipse inside the output I get
<div id="AUTOGENBOOKMARK_1">This works:</div>
<div>
<img id="AUTOGENBOOKMARK_2"
src=" /viewer/preview?__sessionId=20110516_185956_273&amp;__im ageid=design6ff106ab12ff9b42ef115 "
alt="" style="display: block;"></img>
</div>
<div id="AUTOGENBOOKMARK_3">This does not:</div>
<div><img
src=" /viewer/preview?__sessionId=20110516_185956_273&amp;__im ageid=file6ff106ab12ff9b42ef116.tmp "></img>
</div>
However when I run it from my code inside the output I get
<div>
src=" /dashboard?custom_service_handler=report_img1&amp;image= design62ade1b612ff9ba70a61 "
</div>
<div><img src="file:/tmp/img1769066392404117955.tmp"></img>
</div>
The first image is displayed fine, the second (for obvious reasons) is not.
Here is the report:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.2.r262_v20110209 Build &lt;2.6.2.v20110214-1523></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">81</property>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<label id="7">
<text-property name="text">This works:</text-property>
</label>
<image id="8">
</image>
<label id="10">
<text-property name="text">This does not:</text-property>
</label>
<text id="9">
</text>
</body>
<list-property name="images">
<structure>
<property name="name">my_image</property>
<property name="data">
/9j/4AAQSkZJRgABAgAAZABkAAD/7AARRHVja3kAAQAEAAAAZAAA/+4ADkFk b2JlAGTAAAAAAf/bAIQA
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQIC AgICAgICAgICAwMDAwMD
AwMDAwEBAQEBAQECAQECAgIBAgIDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMD AwMDAwMDAwMDAwMDAwMD
AwMDAwMDAwMD/8AAEQgASABIAwERAAIRAQMRAf/EAJgAAQAABgMBAQAAAAAA AAAAAAACBAYHCAkBBQoD
CwEBAAIDAQEAAAAAAAAAAAAAAAEEAgUGAwcQAAAGAgIBAwIEBwEAAAAAAAEC AwQFBgAHEQgSIRMUMUFR
cdEJkbHBIjIWChgRAAICAQMCBAQEAwkAAAAAAAECABEDIRIEMQVBUWET8IEi FHGRMgahwdGx4fFCYnIj
MxX/2gAMAwEAAhEDEQA/APfxiIxEYiMRGIjERiIxEYiMRGIjERiIxEYiMRGI jERiIxEfT1H0xEllHaCX
+RwAfzzIKTE+JZJqYeAUL/EP6ZPtvV1IuThFCKByUwDmJBEmR5ERiIxEYiSj x80j0fkvV02rcDFIdwsI
kQSE3PiZdYQ9tBMRDjzOJS+QgHPIgA5Ij5G2oLbyHX5Dx+USnHs2JjJmbCVd kqn5++gYqhQTN/aRdI6Y
mK4ROf0ECcmAeOAN9vdMOn1aNAsnaP1X8fHlrNXfeb9wmI6htXKznXthuztq 3cKKNW08xrPCqPu+2U6r
6NkwI3cABRA4FFUAHkUvESibrOy9hHcED5MgQN0AXdpp/qAv0szN/tcGMtny OclXtRQ9ehYuou7ugwHr
NaOgP+iTQl6vkJRN+0ic6xOLQ4h29duVlt0ZbtZCpOtEncKpZrUpCUmVq0dN FdI/EkVIpaKBJYq7l22b
gZUNpyf2pkVC3FYZtpN0KOnXS21HiN1+ABNCanB3FMhC5QcbGqvo11qPkfw8 b1no0q93+ScUHAmSWRUM
gskqAlUSVIYQMmchvUpyiUfT65xvI4e3VdbFzY3Rrxl4WjtNyQDFMAiP4Dz9 g+/09c1TKVOsyk3mMRiJ
wI8AI/XjETBncXYO803YFgq0RZtdRkZHBEig1nI7US0sj82CjJBYHTizd3tQ Tx/ccPDmT9+ux/CYlAvv
pgRyt9G7D+1+3dw7Xi5vIw8t8r7rKNyQpp2XQY+08pOi61nfW72m0XmO4d25 XG5j4EfCuMVowxE6qCb3
czE3jeuNdOlimOM209szwwNNfxb2zLsJmubYeX1LQHU3d+/JydvTNjNsNVMI Swdb977N0DrKVpsutGTE
jH311ao60tXRSGGF8FlG/v8A+UeJ3DMuNUCYfaKLyuTx8J2EK2TaObx+Jnfe fcVGw4EONhQOTRn3Pbe6
ZV4y8gshyOpRtuJnUgkg/wDW+cLYoMVy7ipOq7iJoC7Mh2r7B6f0lYv/ABns PczHYvWuzbJ3TvUdj7pp
CGptp2HYGyau7otdi6VsAvXyCe9eK/QkJeReXGHs5LieebLcR6JDEcdDx+Av B7tyOCHHHGHLiXHiyZuF
7uS8aNreNXyDISQPaoISF+o4zNW/chl4aZxWQujksmPMEUi7NFmKbCKO4jcw Lf5qNiz9Rb5YFt4r2ajb
9bN61/zya5qMT/q3YSOpEY62DVen3WWNZ0SXZ0xvBydtjlJpCUJJtpZeRqMm 4RMZeOUL7YEpZMGbBxca
ors576yHc+IsT7mUVZSg52ge4unVqAIEs4uTx3yC2XXgXorjQkG9OmhoA34e RM3b6f2N2E68dTtWSDrX
LSH1/pj9pnTt/kLls6y7Nslxnu0zKpTMLVqApspCTjdEbAayzylwkK9g2KTW wO31uQdNHDZJAqK1Idt4
nM5J42bIzcw93bB7Qbj7vYFbnKhTlVgNznNRxWhBUswlkck7R9Q2HEGLFWq/ 9zaaaAL+rXTpUzssvZHb
VW2AgZCXp9X1q72PragtIXa2j9+0K8rPbBWLcK0ZTdhSdmmtQb6dXKSp7yYa OK0nFKVqK+O3lWqhnBHm
ajH2Lh5bwOGycnZka8WfBkQKrpqyqPcxFAwU+5e9rKH6Sp9sebcq2fosD9LL 1A0G4ix42LAHzMynS3Fc
Bup4hnDT0vBOL5Bwkas01LfY6Ib1Jw1XayFkfbSmn5aLaWcm7eNHzBeHImVN EDNhI5OJlU+YPCw+zuZl
GXYSRvW92mgQfUpGoO4+unSe4Jv0/l/W/jpeTrZx75QES8Dxz/L9c1bLtmcm sxidNMMl3LUxGTduq4OP
gHynCrdumXwOIKn9lFZRQCnAA8CgUR5/yD6564mVW+snb6Cz/L85I6zVp3p6 f1PelMlYO0QsNOy84yNH
N/lRYFYyzFsczpWCl2xV1nEnXAMscxyrnVIioYioF8g8Tdv+2u+fY8gZAt8c WGUnqGBHWhRIsDTpY6Tq
OwZ+CS3G7gN2DIm0nxFm9y2QNK1BIDKStruseDHtl+3zvLq5PzMO/wBT2ed1 e8kPnRdhgK06mo1ZvWTP
DsBuMdAtHDf51USOchJQ6B404KgdBch1VG6X0nH9ryF9/hsuXDV3oGUeTLoV PnptPgTOZ7l+0e79tZjw
1fk9rNH3MN5FrWvcVLZDQv8A5VW9GoEkC3HVb9unsB3VtsdAai0e+/1F7KN1 rJt200p7BamqaJjJ/Il5
i4vopCOk5Bu2J7iUbHHdyrvxAqSAhyYuq7j3bj8VDiDA5fIV6CwPyFzU4eK6 0cgYLWn5dP7h868P0C+v
3RnXuvqnqiqSjJC9NdNat1TqihvbJCRRFouI1VVnNaj5dNoxbIsgnJYZF24X cGIdUpnAkKcCAUM4PP3Z
sCNi45KKzMxonUt169BoNBpLwUHUjy/h8f46zN6D63aqa2dteRo8Aa2tV1nb OdVYpqPWDt0oks5dsPPl
Fi7dKoEOoqkQiihigJhEc0ebu3KfGcO9vaPhfhPQBR0HWVkw0PqOOsqFxa0G soWdtIOpdCYQjUUnKMs/
Kcr+URKQCooyL4FB95YpAUVH1MIj65UfuHMyIcbZGKEVXp4SNqjw1l2yJkTD ghQAMpkk9ZlI8iJCcTFI
YSE8zAA+JOQL5G+wCYfQoCP1H7ZI669IlLjV2qwv30gUsjKyCQJLOFCgBEWi QidCKYlEB+PHpHETCX6q
qmFQ4iIgAWPuGAVE+nGv8T4k+v8AYNBJRmRtwOsocNXMGQlOyUcN1hE51l2q yjdVZZZUy7hUxkTJiPuL
qGMHr6BwH2yz9+7fqA2+XkPKW/vs5H1UT+EmyUn3Tpi5UcOvaH+z5ThdyJfy Fwoqbj1/HnJPM0oUPkJU
di5s/wBJW8ZBt2JSgBCh48enAfbj9Mp5MzPManfgAFDgA4DPCTOcRGIjERiI xEYiMRGIjERiIxEYiMRG
IjERiIxEYiMRGIn/2Q==
</property>
</structure>
</list-property>
</report>
Re: IHTMLImageHandler not used when rendering images embedded using &lt;IMAGE&gt; tag [message #671083 is a reply to message #671076] Mon, 16 May 2011 13:30 Go to previous messageGo to next message
Can you try the attached report?
Jason
id="1">
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<label id="7">
</label>
<image id="8">
<property name="imageName">my_image.png</property>
</image>
<label id="10">
</label>
<text id="9">
name="my_image.png"/>]]></text-property>
</text>
</body>
<structure>
<property name="name">my_image.png</property>
<property name="type">image/png</property>
</property>
</structure>
</list-property>
</report>
> id="1">
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> <body>
> <label id="7">
> </label>
> <image id="8">
> </image>
> <label id="10">
> </label>
> <text id="9">
> </text>
> </body>
> <structure>
> </property>
> </structure>
> </list-property>
> </report>
Re: IHTMLImageHandler not used when rendering images embedded using &lt;IMAGE&gt; tag [message #671085 is a reply to message #671083] Mon, 16 May 2011 13:56 Go to previous messageGo to next message
> Jason
I can see your point. Unfortunately it didn't help, even when I changed
png to jpg and image/png to image/jpeg (the image was jpeg).
The second url still points to a file on disk whereas it should be
generated by HTMLServerImageHandler (which unfortunately is only called
for the first image).
Somehow however it works when run from Eclipse. I'd say it's my code
that lacks something, not the report.
Michal
> id="1">
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <label id="7">
> </label>
> <image id="8">
> </image>
> <label id="10">
> </label>
> <text id="9">
> </text>
> </body>
> <structure>
> </property>
> </structure>
> </list-property>
> </report>
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> <styles>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <label id="7">
>> </label>
>> <image id="8">
>> </image>
>> <label id="10">
>> </label>
>> <text id="9">
>> </text>
>> </body>
>> <structure>
>> </property>
>> </structure>
>> </list-property>
>> </report>
Re: IHTMLImageHandler not used when rendering images embedded using &lt;IMAGE&gt; tag [message #671089 is a reply to message #671085] Mon, 16 May 2011 14:13 Go to previous messageGo to next message
This is the code I used and it worked for me:
package REAPI;
import java.io.ByteArrayOutputStream;
import java.io.InputStream;
import java.util.Collection;
import java.util.HashMap;
import java.util.Iterator;
import java.util.List;
import java.util.Locale;
import java.util.Map;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IPDFRenderOption;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTa sk;
import org.eclipse.birt.report.engine.api.IParameterSelectionChoice ;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.RenderOption;
import org.eclipse.birt.report.engine.api.IParameterDefnBase;
import org.eclipse.birt.report.model.api.DesignElementHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.SlotHandle;
public class RunAndRenderTask {
public void runReport() throws EngineException
IRunAndRenderTask task=null;
IReportEngine engine=null;
EngineConfig config = null;
try{
//System.setProperty("java.io.tmpdir", "c:/temp/test/testsampledb");
config = new EngineConfig( );
config.setBIRTHome(" C:\\birt\\birt-runtime-2_6_2\\birt-runtime-2_6_2\\ReportEngi ne ");
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/myimage.rptdesign");
//design = engine.openReportDesign("Reports/remotelib.rptdesign");
//design = engine.openReportDesign("Reports/JsInclude.rptdesign");
ReportDesignHandle rdh = (ReportDesignHandle)design.getDesignHandle();
//Create task to run and render the report,
task = engine.createRunAndRenderTask(design);
//task.setProgressMonitor(new MyProgressMonitor());
task.setLocale(new Locale("en", "US"));
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName("output/resample/myimage.html");
options.setOutputFormat("HTML");
options.setImageDirectory("C:\\apps\\apache-tomcat-5.5.20\\webapps\\image\\images ");
//ImageHandlerTest
// options.setImageHandler(new MyImageHandler());
options.setImageHandler(new HTMLServerImageHandler());
//options.setImageHandler(new HTMLCompleteImageHandler());
options.setBaseImageURL("http://localhost:8080/image/images/");
task.setRenderOption(options);
task.run();
task.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
finally
if ( !task.getErrors( ).isEmpty( ) )
for ( Object e : task.getErrors( ) )
( (Exception) e ).printStackTrace( );
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTask ex = new RunAndRenderTask( );
ex.runReport();
catch ( Exception e )
e.printStackTrace();
private class CancelReport extends Thread
private IRunAndRenderTask rTask;
public CancelReport( String threadName, IRunAndRenderTask task){
super(threadName);
rTask = task;
public void run()
try{
Thread.currentThread().sleep( 100 );
rTask.cancel();
System.out.println("######Report Cancelled#######");
catch(Exception e)
You could look at implementing your own image handler and debugging it.
Here is an example of an imagehandler
package REAPI;
import java.io.File;
import java.io.FileInputStream;
import java.io.IOException;
import java.io.OutputStream;
import java.util.logging.Logger;
import org.eclipse.birt.report.engine.api.HTMLImageHandler;
import org.eclipse.birt.report.engine.api.IImage;
import org.eclipse.birt.report.engine.api.IRenderOption;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.script.IReportContext;
import org.eclipse.birt.report.engine.i18n.MessageConstants;
* Default implementation for writing images in a form that is used in a
* web-application.
public class MyImageHandler extends HTMLImageHandler
private String handlerId;
private int count = 0;
private static HashMap map = new HashMap( );
* dummy constructor
public MyImageHandler( )
String codePart = Integer.toHexString( this.hashCode( ) );
String timePart = Long.toHexString( System.currentTimeMillis( ) );
handlerId = codePart + timePart;
public String onDesignImage( IImage image, Object context )
return handleImage( image, context, "design", true ); //$NON-NLS-1$
public String onDocImage( IImage image, Object context )
// TODO Auto-generated method stub
return null;
public String onURLImage( IImage image, Object context )
assert ( image != null );
String uri = image.getID( );
if (uri.startsWith( "http:" ) || uri.startsWith( "https:" ))
return uri;
return handleImage( image, context, "uri", true ); //$NON-NLS-1$
public String onCustomImage( IImage image, Object context )
return handleImage( image, context, "custom", false ); //$NON-NLS-1$
* returns a unique file name based on a directory and name prefix
* @param imageDir
* directory to store the image
* @param prefix
* prefix for the file name
* @return a file name
protected String createUniqueFileName( String imageDir, String prefix )
return createUniqueFileName( imageDir, prefix, null );
* creates a unique tempoary file to store an image
* @param imageDir
* directory to put image into
* @param prefix
* file name prefix
* @param postfix
* file name postfix
* @return a Java File Object
protected String createUniqueFileName( String imageDir, String prefix,
String postfix )
File file = null;
postfix = ( postfix == null ? "" : postfix );
String uniCount = null;
do
uniCount = genUniqueCount( );
file = new File( imageDir + "/" + prefix + uniCount + postfix );
//$NON-NLS-1$
} while ( file.exists( ) );
return prefix + uniCount + postfix;
* Generating unique string which contains following parts
* <li> the hashcode of the image handler
* <li> creation time of the image handler
* <li> image count created by the image handler
* @return return the unique count for filename
synchronized private String genUniqueCount( )
count++;
return handlerId + count;
public String onFileImage( IImage image, Object context )
return handleImage( image, context, "file", true ); //$NON-NLS-1$
* handles an image report item and returns an image URL
* @param image
* represents the image design information
* @param context
* context information
* @param prefix
* image prefix in URL
* @param needMap
* whether image map is needed
* @return URL for the image
protected String handleImage( IImage image, Object context, String prefix,
boolean needMap )
String mapID = null;
if ( needMap )
mapID = getImageMapID( image );
if ( map.containsKey( mapID ) )
return (String) map.get( mapID );
String ret = null;
//if ( context != null && ( context instanceof HTMLRenderOption ) )
if ( context != null )
HTMLRenderContext myContext = (HTMLRenderContext) context;
//IRenderOption rotest = image.getRenderOption();
//HTMLRenderOption ro = (HTMLRenderOption)image.getRenderOption();
String imageURL = myContext.getBaseImageURL( );
String imageDir = myContext.getImageDirectory( );
if ( imageURL == null || imageURL.length( ) == 0
|| imageDir == null || imageDir.length( ) == 0 )
System.out.println("Error in image settings");
return null;
String fileName;
File file;
String extension = image.getExtension( );
if ( extension != null && extension.length( ) > 0 )
fileName = createUniqueFileName( imageDir, prefix, extension );
//$NON-NLS-1$
else
fileName = createUniqueFileName( imageDir, prefix );
file = new File( imageDir, fileName ); //$NON-NLS-1$
try
image.writeImage( file );
catch ( IOException e )
// servlet mode
if ( imageURL.indexOf( "?" ) > 0 ) //$NON-NLS-1$
ret = imageURL + fileName + "&specialid=test";
else if ( imageURL.endsWith( "/" ) ) //$NON-NLS-1$
ret = imageURL + fileName;
else
ret = imageURL + "/" + fileName; //$NON-NLS-1$
if ( needMap )
map.put( mapID, ret );
else
ret = handleTempImage( image, prefix, needMap );
return ret;
protected String handleTempImage( IImage image, String prefix,
boolean needMap )
try
File imageFile = File.createTempFile( prefix, ".img" );
image.writeImage( imageFile );
String fileName = imageFile.getAbsolutePath( );
if ( needMap )
String mapID = getImageMapID( image );
map.put( mapID, fileName );
return fileName;
return "unknow.img";
* returns the unique identifier for the image
* @param image
* the image object
* @return the image id
protected String getImageMapID( IImage image )
if ( image.getReportRunnable( ) != null )
return image.getReportRunnable( ).hashCode( ) + image.getID( );
return image.getID( );
Jason
>> Jason
> Michal
>> id="1">
>> <styles>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <label id="7">
>> </label>
>> <image id="8">
>> </image>
>> <label id="10">
>> </label>
>> <text id="9">
>> </text>
>> </body>
>> <structure>
>> </property>
>> </structure>
>> </list-property>
>> </report>
>>> id="1">
>>> <styles>
>>> </style>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <label id="7">
>>> </label>
>>> <image id="8">
>>> </image>
>>> <label id="10">
>>> </label>
>>> <text id="9">
>>> </text>
>>> </body>
>>> <structure>
>>> </property>
>>> </structure>
>>> </list-property>
>>> </report>
Re: IHTMLImageHandler not used when rendering images embedded using &lt;IMAGE&gt; tag [message #671090 is a reply to message #671085] Mon, 16 May 2011 14:13 Go to previous messageGo to next message
package REAPI;
try{
//ImageHandlerTest
task.run();
task.close();
engine.destroy();
finally
* @param args
try
ex.runReport();
super(threadName);
rTask = task;
public void run()
try{
rTask.cancel();
catch(Exception e)
package REAPI;
* web-application.
* dummy constructor
return null;
return uri;
* @param imageDir
* @param prefix
* @param imageDir
* @param prefix
* file name prefix
* @param postfix
* file name postfix
String postfix )
File file = null;
do
//$NON-NLS-1$
count++;
* @param image
* @param context
* @param prefix
* @param needMap
boolean needMap )
if ( needMap )
String ret = null;
return null;
String fileName;
File file;
//$NON-NLS-1$
else
try
// servlet mode
else
if ( needMap )
else
return ret;
boolean needMap )
try
if ( needMap )
return fileName;
* @param image
* the image object
Jason
>> Jason
> Michal
>> id="1">
>> <styles>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <label id="7">
>> </label>
>> <image id="8">
>> </image>
>> <label id="10">
>> </label>
>> <text id="9">
>> </text>
>> </body>
>> <structure>
>> </property>
>> </structure>
>> </list-property>
>> </report>
>>> id="1">
>>> <styles>
>>> </style>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <label id="7">
>>> </label>
>>> <image id="8">
>>> </image>
>>> <label id="10">
>>> </label>
>>> <text id="9">
>>> </text>
>>> </body>
>>> <structure>
>>> </property>
>>> </structure>
>>> </list-property>
>>> </report>
Re: IHTMLImageHandler not used when rendering images embedded using &lt;IMAGE&gt; tag [message #671138 is a reply to message #671089] Mon, 16 May 2011 17:04 Go to previous message
Debugging your code I discovered that the IResourceLocator
implementation I use (that I thought was not worth mentioning) was
incomplete. Everything works now.
Thanks for help!
Michal
> package REAPI;
> try{
> //ImageHandlerTest
> task.run();
> task.close();
> engine.destroy();
> finally
> * @param args
> public static void main(String[] args) {
> try
> ex.runReport();
> super(threadName);
> rTask = task;
> public void run()
> try{
> rTask.cancel();
> catch(Exception e)
> package REAPI;
> * web-application.
> * dummy constructor
> return null;
> return uri;
> * @param imageDir
> * @param prefix
> * @param imageDir
> * @param prefix
> * file name prefix
> * @param postfix
> * file name postfix
> String postfix )
> File file = null;
> do
> //$NON-NLS-1$
> count++;
> * @param image
> * @param context
> * @param prefix
> * @param needMap
> boolean needMap )
> if ( needMap )
> String ret = null;
> return null;
> String fileName;
> File file;
> //$NON-NLS-1$
> else
> try
> // servlet mode
> else
> if ( needMap )
> else
> return ret;
> boolean needMap )
> try
> if ( needMap )
> return fileName;
> * @param image
> * the image object
> Jason
>>> Jason
>> Michal
>>> id="1">
>>> <styles>
>>> </style>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <label id="7">
>>> </label>
>>> <image id="8">
>>> </image>
>>> <label id="10">
>>> </label>
>>> <text id="9">
>>> </text>
>>> </body>
>>> <structure>
>>> </property>
>>> </structure>
>>> </list-property>
>>> </report>
>>>> version="3.2.22"
>>>> id="1">
>>>> <styles>
>>>> </style>
>>>> </style>
>>>> </style>
>>>> </styles>
>>>> <page-setup>
>>>> <page-footer>
>>>> <text id="3">
>>>> </text>
>>>> </page-footer>
>>>> </page-setup>
>>>> <body>
>>>> <label id="7">
>>>> </label>
>>>> <image id="8">
>>>> </image>
>>>> <label id="10">
>>>> </label>
>>>> <text id="9">
>>>> </text>
>>>> </body>
>>>> <structure>
>>>> </property>
>>>> </structure>
>>>> </list-property>
>>>> </report>
Previous Topic:Which occurs first
Next Topic:view as pdf, the layout is distorted seriously
Current Time: Sun Jul 20 03:30:26 EDT 2025
Powered by FUDForum. Page generated in 0.48535 seconds
