Home » Modeling » M2T (model-to-text transformation) » [ACCELEO] Overwriting existing files?(Can Acceleo be configured to overwrite exsisting files?)
icon5.gif  [ACCELEO] Overwriting existing files? [message #670330] Fri, 13 May 2011 10:29 Go to next message
Can Acceleo be configured to overwrite exsisting files? I've tried the UML to Java example of Acceleo 3. It does not rewrite existing Java files.
Harri
Re: [ACCELEO] Overwriting existing files? [message #670911 is a reply to message #670330] Mon, 16 May 2011 03:36 Go to previous messageGo to next message
What does it do then ? It generate a new copy of the java file ? send an error ?
Acceleo usually rewrite the file, it will just no remove a old generated file if you have changed the file name in your template.
There is also a [protected /] option to prevent rewriting piece of code.
Re: [ACCELEO] Overwriting existing files? [message #670918 is a reply to message #670911] Mon, 16 May 2011 04:03 Go to previous message
If you generate a file and then relaunch your generation, the old file will be overwritten. If the old file is not generated anymore, we won't delete it.
If you have a piece of code in a protected area, this code will be protected from the overwriting. The same apply for a piece of code with a JMerge tag (like @generated NOT) in the documentation if you are generating Java.
If you have deleted from your generator the protected, the code inside of the protected area of a previously generated file that would be overwritten will be saved in a ".lost" file.
You can see part of this behavior in the video n°8 starting at 7min28s here.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
[Updated on: Mon, 16 May 2011 04:06] by Moderator
Previous Topic:[ACCELEO] new metamodel
Next Topic:Acceleo Remove Annotation Error
Current Time: Sat Jul 19 19:08:16 EDT 2025
Powered by FUDForum. Page generated in 0.03780 seconds
