Home » Archived » BIRT » IHTMLImageHandler not used when rendering images embedded using <IMAGE> tag
IHTMLImageHandler not used when rendering images embedded using <IMAGE> tag [message #670841] |
Sun, 15 May 2011 16:16  |
Originally posted by:
I'm using HTMLServerImageHandler to create urls for images in the
report. While this works fine for charts and Image items using embedded
images, it doesn't work when I use <IMAGE name="my_image"/> tag while
defining Text item. To be more precise, it works in web viewer but not
when I use my own code.
Here is my code (I use BIRT 2.6):
IRunAndRenderTask task = engine.createRunAndRenderTask(reportDesign);
HTMLServerImageHandler imageHandler = new HTMLServerImageHandler();
HTMLRenderOption option = new HTMLRenderOption();
option.setOutputFileName(outputFile.getAbsolutePath());
option.setBaseImageURL(baseImageUrl);
option.setImageDirectory(imageDir);
option.setImageHandler(imageHandler);
task.setRenderOption(option);
task.run();
This part of report renders correctly:
<image id="8">
<property name="source">embed</property>
<property name="imageName">my_image</property>
</image>
This does not:
<text id="9">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<IMAGE
name="my_image"/>]]></text-property>
</text>
The HTML produced looks like this:
<img src="file:/tmp/img6647447909864980190.jpg"></img>
Why BIRT doesn't use provided image handler in this case?
What's in the web viewer's code that's not in mine? (I browsed it but
couldn't find any important difference)
Michal
Re: IHTMLImageHandler not used when rendering images embedded using <IMAGE> tag [message #671089 is a reply to message #671085] |
Mon, 16 May 2011 14:13   |
This is the code I used and it worked for me:
package REAPI;
import java.io.ByteArrayOutputStream;
import java.io.InputStream;
import java.util.Collection;
import java.util.HashMap;
import java.util.Iterator;
import java.util.List;
import java.util.Locale;
import java.util.Map;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IPDFRenderOption;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTa sk;
import org.eclipse.birt.report.engine.api.IParameterSelectionChoice ;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.RenderOption;
import org.eclipse.birt.report.engine.api.IParameterDefnBase;
import org.eclipse.birt.report.model.api.DesignElementHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.SlotHandle;
public class RunAndRenderTask {
public void runReport() throws EngineException
IRunAndRenderTask task=null;
IReportEngine engine=null;
EngineConfig config = null;
try{
//System.setProperty("java.io.tmpdir", "c:/temp/test/testsampledb");
config = new EngineConfig( );
config.setBIRTHome(" C:\\birt\\birt-runtime-2_6_2\\birt-runtime-2_6_2\\ReportEngi ne ");
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/myimage.rptdesign");
//design = engine.openReportDesign("Reports/remotelib.rptdesign");
//design = engine.openReportDesign("Reports/JsInclude.rptdesign");
ReportDesignHandle rdh = (ReportDesignHandle)design.getDesignHandle();
//Create task to run and render the report,
task = engine.createRunAndRenderTask(design);
//task.setProgressMonitor(new MyProgressMonitor());
task.setLocale(new Locale("en", "US"));
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName("output/resample/myimage.html");
options.setOutputFormat("HTML");
options.setImageDirectory("C:\\apps\\apache-tomcat-5.5.20\\webapps\\image\\images ");
//ImageHandlerTest
// options.setImageHandler(new MyImageHandler());
options.setImageHandler(new HTMLServerImageHandler());
//options.setImageHandler(new HTMLCompleteImageHandler());
options.setBaseImageURL("http://localhost:8080/image/images/");
task.setRenderOption(options);
task.run();
task.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
finally
if ( !task.getErrors( ).isEmpty( ) )
for ( Object e : task.getErrors( ) )
( (Exception) e ).printStackTrace( );
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTask ex = new RunAndRenderTask( );
ex.runReport();
catch ( Exception e )
e.printStackTrace();
private class CancelReport extends Thread
private IRunAndRenderTask rTask;
public CancelReport( String threadName, IRunAndRenderTask task){
super(threadName);
rTask = task;
public void run()
try{
Thread.currentThread().sleep( 100 );
rTask.cancel();
System.out.println("######Report Cancelled#######");
catch(Exception e)
You could look at implementing your own image handler and debugging it.
Here is an example of an imagehandler
package REAPI;
import java.io.File;
import java.io.FileInputStream;
import java.io.IOException;
import java.io.OutputStream;
import java.util.logging.Logger;
import org.eclipse.birt.report.engine.api.HTMLImageHandler;
import org.eclipse.birt.report.engine.api.IImage;
import org.eclipse.birt.report.engine.api.IRenderOption;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.script.IReportContext;
import org.eclipse.birt.report.engine.i18n.MessageConstants;
* Default implementation for writing images in a form that is used in a
* web-application.
public class MyImageHandler extends HTMLImageHandler
private String handlerId;
private int count = 0;
private static HashMap map = new HashMap( );
* dummy constructor
public MyImageHandler( )
String codePart = Integer.toHexString( this.hashCode( ) );
String timePart = Long.toHexString( System.currentTimeMillis( ) );
handlerId = codePart + timePart;
public String onDesignImage( IImage image, Object context )
return handleImage( image, context, "design", true ); //$NON-NLS-1$
public String onDocImage( IImage image, Object context )
// TODO Auto-generated method stub
return null;
public String onURLImage( IImage image, Object context )
assert ( image != null );
String uri = image.getID( );
if (uri.startsWith( "http:" ) || uri.startsWith( "https:" ))
return uri;
return handleImage( image, context, "uri", true ); //$NON-NLS-1$
public String onCustomImage( IImage image, Object context )
return handleImage( image, context, "custom", false ); //$NON-NLS-1$
* returns a unique file name based on a directory and name prefix
* @param imageDir
* directory to store the image
* @param prefix
* prefix for the file name
* @return a file name
protected String createUniqueFileName( String imageDir, String prefix )
return createUniqueFileName( imageDir, prefix, null );
* creates a unique tempoary file to store an image
* @param imageDir
* directory to put image into
* @param prefix
* file name prefix
* @param postfix
* file name postfix
* @return a Java File Object
protected String createUniqueFileName( String imageDir, String prefix,
String postfix )
File file = null;
postfix = ( postfix == null ? "" : postfix );
String uniCount = null;
do
uniCount = genUniqueCount( );
file = new File( imageDir + "/" + prefix + uniCount + postfix );
//$NON-NLS-1$
} while ( file.exists( ) );
return prefix + uniCount + postfix;
* Generating unique string which contains following parts
* <li> the hashcode of the image handler
* <li> creation time of the image handler
* <li> image count created by the image handler
* @return return the unique count for filename
synchronized private String genUniqueCount( )
count++;
return handlerId + count;
public String onFileImage( IImage image, Object context )
return handleImage( image, context, "file", true ); //$NON-NLS-1$
* handles an image report item and returns an image URL
* @param image
* represents the image design information
* @param context
* context information
* @param prefix
* image prefix in URL
* @param needMap
* whether image map is needed
* @return URL for the image
protected String handleImage( IImage image, Object context, String prefix,
boolean needMap )
String mapID = null;
if ( needMap )
mapID = getImageMapID( image );
if ( map.containsKey( mapID ) )
return (String) map.get( mapID );
String ret = null;
//if ( context != null && ( context instanceof HTMLRenderOption ) )
if ( context != null )
HTMLRenderContext myContext = (HTMLRenderContext) context;
//IRenderOption rotest = image.getRenderOption();
//HTMLRenderOption ro = (HTMLRenderOption)image.getRenderOption();
String imageURL = myContext.getBaseImageURL( );
String imageDir = myContext.getImageDirectory( );
if ( imageURL == null || imageURL.length( ) == 0
|| imageDir == null || imageDir.length( ) == 0 )
System.out.println("Error in image settings");
return null;
String fileName;
File file;
String extension = image.getExtension( );
if ( extension != null && extension.length( ) > 0 )
fileName = createUniqueFileName( imageDir, prefix, extension );
//$NON-NLS-1$
else
fileName = createUniqueFileName( imageDir, prefix );
file = new File( imageDir, fileName ); //$NON-NLS-1$
try
image.writeImage( file );
catch ( IOException e )
// servlet mode
if ( imageURL.indexOf( "?" ) > 0 ) //$NON-NLS-1$
ret = imageURL + fileName + "&specialid=test";
else if ( imageURL.endsWith( "/" ) ) //$NON-NLS-1$
ret = imageURL + fileName;
else
ret = imageURL + "/" + fileName; //$NON-NLS-1$
if ( needMap )
map.put( mapID, ret );
else
ret = handleTempImage( image, prefix, needMap );
return ret;
protected String handleTempImage( IImage image, String prefix,
boolean needMap )
try
File imageFile = File.createTempFile( prefix, ".img" );
image.writeImage( imageFile );
String fileName = imageFile.getAbsolutePath( );
if ( needMap )
String mapID = getImageMapID( image );
map.put( mapID, fileName );
return fileName;
return "unknow.img";
* returns the unique identifier for the image
* @param image
* the image object
* @return the image id
protected String getImageMapID( IImage image )
if ( image.getReportRunnable( ) != null )
return image.getReportRunnable( ).hashCode( ) + image.getID( );
return image.getID( );
Jason
On 5/16/2011 1:56 PM, Michał Tkacz wrote:
> On 05/16/2011 07:30 PM, Jason Weathersby wrote:
>> Can you try the attached report?
>> Jason
> I can see your point. Unfortunately it didn't help, even when I changed
> png to jpg and image/png to image/jpeg (the image was jpeg).
> The second url still points to a file on disk whereas it should be
> generated by HTMLServerImageHandler (which unfortunately is only called
> for the first image).
> Somehow however it works when run from Eclipse. I'd say it's my code
> that lacks something, not the report.
> Michal
>> <?xml version="1.0" encoding="UTF-8"?>
>> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
>> id="1">
>> <property name="createdBy">Eclipse BIRT Designer Version
>> 2.6.2.r262_v20110209 Build <2.6.2.v20110214-1523></property>
>> <property name="units">in</property>
>> <property name="iconFile">/templates/blank_report.gif</property>
>> <property name="bidiLayoutOrientation">ltr</property>
>> <property name="imageDPI">81</property>
>> <styles>
>> <style name="report" id="4">
>> <property name="fontFamily">sans-serif</property>
>> <property name="fontSize">10pt</property>
>> </style>
>> <style name="crosstab-cell" id="5">
>> <property name="borderBottomColor">#CCCCCC</property>
>> <property name="borderBottomStyle">solid</property>
>> <property name="borderBottomWidth">1pt</property>
>> <property name="borderLeftColor">#CCCCCC</property>
>> <property name="borderLeftStyle">solid</property>
>> <property name="borderLeftWidth">1pt</property>
>> <property name="borderRightColor">#CCCCCC</property>
>> <property name="borderRightStyle">solid</property>
>> <property name="borderRightWidth">1pt</property>
>> <property name="borderTopColor">#CCCCCC</property>
>> <property name="borderTopStyle">solid</property>
>> <property name="borderTopWidth">1pt</property>
>> </style>
>> <style name="crosstab" id="6">
>> </style>
>> </styles>
>> <page-setup>
>> <simple-master-page name="Simple MasterPage" id="2">
>> <page-footer>
>> <text id="3">
>> <text-property name="content"><![CDATA[<value-of>new
>> Date()</value-of>]]></text-property>
>> </text>
>> </page-footer>
>> </simple-master-page>
>> </page-setup>
>> <body>
>> <label id="7">
>> <text-property name="text">This works:</text-property>
>> </label>
>> <image id="8">
>> <property name="imageName">my_image.png</property>
>> </image>
>> <label id="10">
>> <text-property name="text">This does not:</text-property>
>> </label>
>> <text id="9">
>> name="my_image.png"/>]]></text-property>
>> </text>
>> </body>
>> <list-property name="images">
>> <structure>
>> <property name="name">my_image.png</property>
>> <property name="type">image/png</property>
>> <property name="data">
>> /9j/4AAQSkZJRgABAgAAZABkAAD/7AARRHVja3kAAQAEAAAAZAAA/+4ADkFk b2JlAGTAAAAAAf/bAIQA
>> AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQIC AgICAgICAgICAwMDAwMD
>> AwMDAwEBAQEBAQECAQECAgIBAgIDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMD AwMDAwMDAwMDAwMDAwMD
>> AwMDAwMDAwMD/8AAEQgASABIAwERAAIRAQMRAf/EAJgAAQAABgMBAQAAAAAA AAAAAAACBAYHCAkBBQoD
>> CwEBAAIDAQEAAAAAAAAAAAAAAAEEAgUGAwcQAAAGAgIBAwIEBwEAAAAAAAEC AwQFBgAHEQgSIRMUMUFR
>> cdEJkbHBIjIWChgRAAICAQMCBAQEAwkAAAAAAAECABEDIRIEMQVBUWET8IEi FHGRMgahwdGx4fFCYnIj
>> MxX/2gAMAwEAAhEDEQA/APfxiIxEYiMRGIjERiIxEYiMRGIjERiIxEYiMRGI jERiIxEfT1H0xEllHaCX
>> +RwAfzzIKTE+JZJqYeAUL/EP6ZPtvV1IuThFCKByUwDmJBEmR5ERiIxEYiSj x80j0fkvV02rcDFIdwsI
>> kQSE3PiZdYQ9tBMRDjzOJS+QgHPIgA5Ij5G2oLbyHX5Dx+USnHs2JjJmbCVd kqn5++gYqhQTN/aRdI6Y
>> mK4ROf0ECcmAeOAN9vdMOn1aNAsnaP1X8fHlrNXfeb9wmI6htXKznXthuztq 3cKKNW08xrPCqPu+2U6r
>> 6NkwI3cABRA4FFUAHkUvESibrOy9hHcED5MgQN0AXdpp/qAv0szN/tcGMtny OclXtRQ9ehYuou7ugwHr
>> NaOgP+iTQl6vkJRN+0ic6xOLQ4h29duVlt0ZbtZCpOtEncKpZrUpCUmVq0dN FdI/EkVIpaKBJYq7l22b
>> gZUNpyf2pkVC3FYZtpN0KOnXS21HiN1+ABNCanB3FMhC5QcbGqvo11qPkfw8 b1no0q93+ScUHAmSWRUM
>> gskqAlUSVIYQMmchvUpyiUfT65xvI4e3VdbFzY3Rrxl4WjtNyQDFMAiP4Dz9 g+/09c1TKVOsyk3mMRiJ
>> wI8AI/XjETBncXYO803YFgq0RZtdRkZHBEig1nI7US0sj82CjJBYHTizd3tQ Tx/ccPDmT9+ux/CYlAvv
>> pgRyt9G7D+1+3dw7Xi5vIw8t8r7rKNyQpp2XQY+08pOi61nfW72m0XmO4d25 XG5j4EfCuMVowxE6qCb3
>> czE3jeuNdOlimOM209szwwNNfxb2zLsJmubYeX1LQHU3d+/JydvTNjNsNVMI Swdb977N0DrKVpsutGTE
>> jH311ao60tXRSGGF8FlG/v8A+UeJ3DMuNUCYfaKLyuTx8J2EK2TaObx+Jnfe fcVGw4EONhQOTRn3Pbe6
>> ZV4y8gshyOpRtuJnUgkg/wDW+cLYoMVy7ipOq7iJoC7Mh2r7B6f0lYv/ABns PczHYvWuzbJ3TvUdj7pp
>> CGptp2HYGyau7otdi6VsAvXyCe9eK/QkJeReXGHs5LieebLcR6JDEcdDx+Av B7tyOCHHHGHLiXHiyZuF
>> 7uS8aNreNXyDISQPaoISF+o4zNW/chl4aZxWQujksmPMEUi7NFmKbCKO4jcw Lf5qNiz9Rb5YFt4r2ajb
>> 9bN61/zya5qMT/q3YSOpEY62DVen3WWNZ0SXZ0xvBydtjlJpCUJJtpZeRqMm 4RMZeOUL7YEpZMGbBxca
>> ors576yHc+IsT7mUVZSg52ge4unVqAIEs4uTx3yC2XXgXorjQkG9OmhoA34e RM3b6f2N2E68dTtWSDrX
>> LSH1/pj9pnTt/kLls6y7Nslxnu0zKpTMLVqApspCTjdEbAayzylwkK9g2KTW wO31uQdNHDZJAqK1Idt4
>> nM5J42bIzcw93bB7Qbj7vYFbnKhTlVgNznNRxWhBUswlkck7R9Q2HEGLFWq/ 9zaaaAL+rXTpUzssvZHb
>> VW2AgZCXp9X1q72PragtIXa2j9+0K8rPbBWLcK0ZTdhSdmmtQb6dXKSp7yYa OK0nFKVqK+O3lWqhnBHm
>> ajH2Lh5bwOGycnZka8WfBkQKrpqyqPcxFAwU+5e9rKH6Sp9sebcq2fosD9LL 1A0G4ix42LAHzMynS3Fc
>> Bup4hnDT0vBOL5Bwkas01LfY6Ib1Jw1XayFkfbSmn5aLaWcm7eNHzBeHImVN EDNhI5OJlU+YPCw+zuZl
>> GXYSRvW92mgQfUpGoO4+unSe4Jv0/l/W/jpeTrZx75QES8Dxz/L9c1bLtmcm sxidNMMl3LUxGTduq4OP
>> gHynCrdumXwOIKn9lFZRQCnAA8CgUR5/yD6564mVW+snb6Cz/L85I6zVp3p6 f1PelMlYO0QsNOy84yNH
>> N/lRYFYyzFsczpWCl2xV1nEnXAMscxyrnVIioYioF8g8Tdv+2u+fY8gZAt8c WGUnqGBHWhRIsDTpY6Tq
>> OwZ+CS3G7gN2DIm0nxFm9y2QNK1BIDKStruseDHtl+3zvLq5PzMO/wBT2ed1 e8kPnRdhgK06mo1ZvWTP
>> DsBuMdAtHDf51USOchJQ6B404KgdBch1VG6X0nH9ryF9/hsuXDV3oGUeTLoV PnptPgTOZ7l+0e79tZjw
>> 1fk9rNH3MN5FrWvcVLZDQv8A5VW9GoEkC3HVb9unsB3VtsdAai0e+/1F7KN1 rJt200p7BamqaJjJ/Il5
>> i4vopCOk5Bu2J7iUbHHdyrvxAqSAhyYuq7j3bj8VDiDA5fIV6CwPyFzU4eK6 0cgYLWn5dP7h868P0C+v
>> 3RnXuvqnqiqSjJC9NdNat1TqihvbJCRRFouI1VVnNaj5dNoxbIsgnJYZF24X cGIdUpnAkKcCAUM4PP3Z
>> sCNi45KKzMxonUt169BoNBpLwUHUjy/h8f46zN6D63aqa2dteRo8Aa2tV1nb OdVYpqPWDt0oks5dsPPl
>> Fi7dKoEOoqkQiihigJhEc0ebu3KfGcO9vaPhfhPQBR0HWVkw0PqOOsqFxa0G soWdtIOpdCYQjUUnKMs/
>> Kcr+URKQCooyL4FB95YpAUVH1MIj65UfuHMyIcbZGKEVXp4SNqjw1l2yJkTD ghQAMpkk9ZlI8iJCcTFI
>> YSE8zAA+JOQL5G+wCYfQoCP1H7ZI669IlLjV2qwv30gUsjKyCQJLOFCgBEWi QidCKYlEB+PHpHETCX6q
>> qmFQ4iIgAWPuGAVE+nGv8T4k+v8AYNBJRmRtwOsocNXMGQlOyUcN1hE51l2q yjdVZZZUy7hUxkTJiPuL
>> qGMHr6BwH2yz9+7fqA2+XkPKW/vs5H1UT+EmyUn3Tpi5UcOvaH+z5ThdyJfy Fwoqbj1/HnJPM0oUPkJU
>> di5s/wBJW8ZBt2JSgBCh48enAfbj9Mp5MzPManfgAFDgA4DPCTOcRGIjERiI xEYiMRGIjERiIxEYiMRG
>> IjERiIxEYiMRGIn/2Q==
>> </property>
>> </structure>
>> </list-property>
>> </report>
>>> id="1">
>>> <styles>
>>> </style>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <label id="7">
>>> </label>
>>> <image id="8">
>>> </image>
>>> <label id="10">
>>> </label>
>>> <text id="9">
>>> </text>
>>> </body>
>>> <structure>
>>> <property name="name">my_image</property>
>>> </property>
>>> </structure>
>>> </list-property>
>>> </report>
Re: IHTMLImageHandler not used when rendering images embedded using <IMAGE> tag [message #671090 is a reply to message #671085] |
package REAPI;
try{
//ImageHandlerTest
task.run();
task.close();
engine.destroy();
finally
* @param args
try
ex.runReport();
super(threadName);
rTask = task;
public void run()
try{
rTask.cancel();
catch(Exception e)
package REAPI;
* web-application.
* dummy constructor
return null;
return uri;
* @param imageDir
* @param prefix
* @param imageDir
* @param prefix
* file name prefix
* @param postfix
* file name postfix
String postfix )
File file = null;
do
//$NON-NLS-1$
count++;
* @param image
* @param context
* @param prefix
* @param needMap
boolean needMap )
if ( needMap )
String ret = null;
return null;
String fileName;
File file;
//$NON-NLS-1$
else
try
// servlet mode
else
if ( needMap )
else
return ret;
boolean needMap )
try
if ( needMap )
return fileName;
* @param image
* the image object
Jason
>> Jason
> Michal
>> id="1">
>> <styles>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <label id="7">
>> </label>
>> <image id="8">
>> </image>
>> <label id="10">
>> </label>
>> <text id="9">
>> </text>
>> </body>
>> <structure>
>> </property>
>> </structure>
>> </list-property>
>> </report>
>>> id="1">
>>> <styles>
>>> </style>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <label id="7">
>>> </label>
>>> <image id="8">
>>> </image>
>>> <label id="10">
>>> </label>
>>> <text id="9">
>>> </text>
>>> </body>
>>> <structure>
>>> </property>
>>> </structure>
>>> </list-property>
>>> </report>
Re: IHTMLImageHandler not used when rendering images embedded using <IMAGE> tag [message #671138 is a reply to message #671089] |
Mon, 16 May 2011 17:04  |
Debugging your code I discovered that the IResourceLocator
implementation I use (that I thought was not worth mentioning) was
incomplete. Everything works now.
Thanks for help!
Michal
> package REAPI;
> try{
> //ImageHandlerTest
> task.run();
> task.close();
> engine.destroy();
> finally
> * @param args
> public static void main(String[] args) {
> try
> ex.runReport();
> super(threadName);
> rTask = task;
> public void run()
> try{
> rTask.cancel();
> catch(Exception e)
> package REAPI;
> * web-application.
> * dummy constructor
> return null;
> return uri;
> * @param imageDir
> * @param prefix
> * @param imageDir
> * @param prefix
> * file name prefix
> * @param postfix
> * file name postfix
> String postfix )
> File file = null;
> do
> //$NON-NLS-1$
> count++;
> * @param image
> * @param context
> * @param prefix
> * @param needMap
> boolean needMap )
> if ( needMap )
> String ret = null;
> return null;
> String fileName;
> File file;
> //$NON-NLS-1$
> else
> try
> // servlet mode
> else
> if ( needMap )
> else
> return ret;
> boolean needMap )
> try
> if ( needMap )
> return fileName;
> * @param image
> * the image object
> Jason
>>> Jason
>> Michal
>>> id="1">
>>> <styles>
>>> </style>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <label id="7">
>>> </label>
>>> <image id="8">
>>> </image>
>>> <label id="10">
>>> </label>
>>> <text id="9">
>>> </text>
>>> </body>
>>> <structure>
>>> </property>
>>> </structure>
>>> </list-property>
>>> </report>
>>>> version="3.2.22"
>>>> id="1">
>>>> <styles>
>>>> </style>
>>>> </style>
>>>> </style>
>>>> </styles>
>>>> <page-setup>
>>>> <page-footer>
>>>> <text id="3">
>>>> </text>
>>>> </page-footer>
>>>> </page-setup>
>>>> <body>
>>>> <label id="7">
>>>> </label>
>>>> <image id="8">
>>>> </image>
>>>> <label id="10">
>>>> </label>
>>>> <text id="9">
>>>> </text>
>>>> </body>
>>>> <structure>
>>>> </property>
>>>> </structure>
>>>> </list-property>
>>>> </report>
Current Time: Sat Jul 19 23:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.05481 seconds
