Home » Modeling » TMF (Xtext) » Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext
Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #670321] Fri, 13 May 2011 10:05 Go to next message
Hello
I created new DSL which is extension of an existing one. There is a link that I was following but I cannot send it now Razz The title of the post is Xtext 1.0.0 and UML (Xpand on top)
In my case I didn't use UML meta model but the metamodel generated by another Xtext (base) grammar. The editor is working just fine.
The new grammar looks as follows:
grammar org.xtext.example.libExt.LibExt with org.eclipse.xtext.common.Terminals
generate libExt "URI_of_new_DSL"
import "URI_of_base_DSL" as building
Model:
 	(imports+=Import)*
 	(bref+=BuildingRef)*
Import :
 'import' importURI=STRING;
BuildingRef:
	"REF" name=ID ref=[building::Building|ID];
One note here: As you can see, in the models that conform with this grammar I allow import of model created in the base DSL.
However I tried to make small template in the generator project, and there were no errors found. However, I got errors when running the workflow mwe2 file of the .generator project. I got something like :
Couldn't resolve reference to Building 'Tower'
Does anyone know something about proper configuring of mwe2 of generator project when having imported metamodel in the Xtext grammar? Some useful links or maybe tips how to do this?
Thanks in advance
Nikola.
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #670327 is a reply to message #670321] Fri, 13 May 2011 10:20 Go to previous messageGo to next message
did you something like
register = org.xtext.example.mydsl.MyDslAStandaloneSetup {}
register = org.xtext.example.mydsl.MyDslBStandaloneSetup {}
in your generator projects workflow?
~Christian
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #670345 is a reply to message #670327] Fri, 13 May 2011 11:27 Go to previous messageGo to next message
Hi Christian
I tried but again the same error appears. This is my workflow file:
module workflow.BdlGenerator
import org.eclipse.emf.mwe.utils.*
var targetDir = "src-gen"
var fileEncoding = "Cp1252"
var modelPath = "src/model"
Workflow {
	component = org.eclipse.xtext.mwe.Reader {
		// lookup all resources on the classpath
		//useJavaClassPath = false
		// or define search scope explicitly
		path = modelPath
		skipOnErrors = true
		// this class will be generated by the xtext generator
		load = {
			slot = "system"
			type = "BDL"
	component = org.eclipse.xpand2.Generator {
		metaModel = org.eclipse.xtend.typesystem.emf.EmfMetaModel {
			metaModelPackage = "org.xtext.example.mydsl.MyDslAPackage"
			metaModelPackage = "org.xtext.example.mydsl.MyDslBPackage"
		expand = "templates::Template::main FOREACH greetings"
		outlet = {
			path = targetDir
		fileEncoding = fileEncoding
Also I put dependencies in MANIFEST.MF, but still the same error appears.
Nikola
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #670352 is a reply to message #670345] Fri, 13 May 2011 11:45 Go to previous messageGo to next message
can you please post the complete error message?
and can you post example models?
btw
there is something wrong with your workflow Wink
you read BDL into the slot system but call the generator with greetings
[Updated on: Fri, 13 May 2011 11:46] by Moderator
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #670354 is a reply to message #670345] Fri, 13 May 2011 11:50 Go to previous messageGo to next message
Hi Christian
I solved the problem. The code that I've added is:
        bean = org.eclipse.emf.mwe.utils.StandaloneSetup {
	 	platformUri=".."
and now the workflow file looks like:
Workflow {
	 	platformUri=".."
		path = modelPath
		skipOnErrors = true
		load = {
			slot = "system"
			type = "BDL"
		outlet = {
			path = targetDir
Now I have problem with the generator. The error that appears is as follows
Could not find any exported element of type 'BDL' -> Slot 'system' is empty.
My question is what is a slot actually?
Nikola
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #670356 is a reply to message #670354] Fri, 13 May 2011 11:54 Go to previous messageGo to next message
hi,
yes you have to add
	bean = StandaloneSetup {
		platformUri=".."
if you use platform:/resource imports
a slot is just an entry in a map
load = {
			slot = "system"
			type = "BDL"
stores all BDL to the map under the key system
and
call the min definition foreach of the entries of the slot greetings
and yes by default only stuff that has a name is exported/stored to the slot by this generator workflow.
(and stored to the slot)
~Christian
[Updated on: Fri, 13 May 2011 12:30] by Moderator
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #671042 is a reply to message #670356] Mon, 16 May 2011 11:39 Go to previous messageGo to next message
Hi Christian
me again ... Very Happy
The problems with the generation of text with templates are resolved !
I'm creating standalone java application in which I would like to read a model and to parse it. It works OK, BUTTTT when it comes to reading the cross references, the type of the cross reference is ok, but the name (taken with getName()) of the referenced object from the imported referenced model is null.
What I do in the code is the following: I invoke setups of both the base language and the new one that uses the base language for cross references.
BaseStandaloneSetup.doSetup();
BdlStandaloneSetup.doSetup();
Any suggestions?
Nikola
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #671044 is a reply to message #671042] Mon, 16 May 2011 11:43 Go to previous messageGo to next message
can you give me some reproducable code?
~Christian
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #671048 is a reply to message #671044] Mon, 16 May 2011 11:49 Go to previous messageGo to next message
You want the java code of the script only or everything ? I can send you the java code ?? :-/
Nikola
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #671051 is a reply to message #671048] Mon, 16 May 2011 11:51 Go to previous messageGo to next message
no the two grammars
+ the language generator workflows
+ the generator workflow
+ 2 sample models incl folder structure
are fine Wink
~Christian
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #671052 is a reply to message #671051] Mon, 16 May 2011 11:56 Go to previous messageGo to next message
Unfortunately I cannot send you Sad company secret
Maybe I have to reproduce the entire case with two dummy grammars and then ask you again...
Life it's not easy at all Very Happy
Thanks however
I'll write when I'll repeat the case.
Nikola
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #671058 is a reply to message #671052] Mon, 16 May 2011 12:11 Go to previous messageGo to next message
Of cource i am fine with dummy / sample dsls Wink
~Christian
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #671329 is a reply to message #671058] Tue, 17 May 2011 10:34 Go to previous messageGo to next message
Hi Christian
I've reproduced the code. So, again I cannot access the referenced objects. BTW it works fine with xPand but I cannot figure out what is the problem when I want to use the parser in a standalone application.
That's why I made two grammars: libraryBuilding as a base one and libExt that is using libraryBuilding.
The standalone application is contained in the project parseLibExt.
So the output is
A
null
and it should be
A
Tower
I hope this all u need?
Thanks again
Nikola
  • Attachment: workspace.zip
    (Size: 343.68KB, Downloaded 205 times)
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #671364 is a reply to message #671329] Tue, 17 May 2011 12:02 Go to previous messageGo to next message
you have to do the same as you do in the workflow Wink
new StandaloneSetup().setPlatformUri("..");
~Christian
Re: Configuring mwe2 file of Xpand .generator project when having imported metamodel in Xtext [message #671535 is a reply to message #671364] Wed, 18 May 2011 04:55 Go to previous message
Thanks Christian, that solved my problem ! Very Happy
Now it will be easy to proceed with the rest of the work.
Thanks again !
Nikola
Previous Topic:White Spaces into keywords of Xtext grammar
Next Topic:(no subject)
Current Time: Sat Jul 19 06:19:18 EDT 2025
Powered by FUDForum. Page generated in 0.06053 seconds
