Home » Language IDEs » PHP Development Tools (PDT) » pdt php.ini on linux?
pdt php.ini on linux? [message #66965] |
Thu, 06 March 2008 14:28  |
Originally posted by: wendell.wendellwturner.com
I would like some help in getting PDT started. I've read
Mike Lubber's Step-by-step document, but it describes
Windows, and I'm using Fedora (on x86_64 which makes
installation even more fun).
I think I have php configured with the right zend debugger,
since phpinfo shows
"with Zend Debugger v5.2.12, Copyright (c) 1999-2007, by Zend
Technologies"
in the Zend Engine block of the page.
However, in eclipse, when I try to either Run or Debug a
php program, I get:
The debug session could not be started.
Please make sure that the debugger is properly configured as a php.ini
directive.
What php.ini is this talking about? The system one in
/etc, or the one down in plugins/org.zend.php.debug.debugger...?
I've edited both of them (with full path names to an x86_64
ZendDebugger.so). What is the problem?
I can run php from the command line, and that seems to work
ok.
Also, I have other questions:
Q: at startup I get an error about
org.eclipse.emf.ecore.util.EcoreEMap$DelegateEObjectContainm entEList
Is this a serious problem?
Q: the phpinfo() page shows "Debug Build no"; is this a problem?
Q: Do I need xampp instead of apache?
Thanks in advance,
Wendell
Fedora 7; x86_64
eclipse-SDK-3.3.2-linux-gtk-x86_64
ZendDebugger-5.2.12-linux-glibc23-x86_64
php-5.2.4
apache 2.2.4
Re: pdt php.ini on linux? [message #66985 is a reply to message #66965] |
Fri, 07 March 2008 04:46   |
Originally posted by: morgg.mail.com
Hi Wendell,
I have Zend Debugger working in an OpenSuse x86_64. If phpinfo() tells
you that it is working, that should be enough.
Did you remember to add dummy.php to your webroot?
If php says it's working but Eclipse cannot connect, maybe it is some
issue with the communication ports between them. I have edited the
system php.ini only...
zend_extension=/usr/lib64/php5/extensions/ZendDebugger.so
zend_debugger.allow_hosts=127.0.0.1,192.168.xxx/24,192.168.x xx.0/24
zend_debugger.expose_remotely=always
Note that it does not say anything about the port, something that I have
seen in other setups. I guess it just uses default port.
Make sure the port is well configured in Eclipse
(Window->Preferences->PHP->Debug->Installed Debuggers) with a value of
10000.
No, this must be related with PHP engine debugging. Mine is working and
it says the same.
I use Apache.
I hope it helps!
Wendell Turner escribió:
> I would like some help in getting PDT started. I've read Mike Lubber's
> I think I have php configured with the right zend debugger, since
> phpinfo shows
> Technologies"
> php program, I get:
> directive.
> What php.ini is this talking about? The system one in /etc, or the one
> ok.
> Thanks in advance,
> Wendell
> Fedora 7; x86_64
> php-5.2.4
> apache 2.2.4
Re: pdt php.ini on linux? [message #66993 is a reply to message #66985] |
Fri, 07 March 2008 11:04   |
Ok.
Yes.
Yes, I have that.
> 10000.
Yes, that is set to the default.
> I hope it helps!
Thank you for the response, but I still get the same response when
starting the debugger. Is there a log file that I can turn on? If I run
'eclipse -debug' there are some startup messages, but nothing else
(nothing about PHP or what it is trying to do). Where else can I look?
>> phpinfo shows
>> Technologies"
>> php program, I get:
>> directive.
>> ok.
>> Thanks in advance,
>> Wendell
>> Fedora 7; x86_64
>> php-5.2.4
>> apache 2.2.4
Re: pdt php.ini on linux? [message #67001 is a reply to message #66993] |
Fri, 07 March 2008 11:43   |
I have more information on this, but it is still inop, and I would like
some more help.
In the directory
eclipse/plugins/org.zend.php.debug.debugger.linux.x86_5.2.12 .v20071210/resources/php5
there are the files php, php-cgi, and ZendDebugger.so. All are 'ELF
64-bit LSB', and I can run both that php and php-cgi and they run
successfully (no complaints about missing libraries, etc).
However, when I run eclipse with these arguments:
./eclipse -debug -consoleLog -console
and try to run a php program, eclipse complains about
!MESSAGE PHP executable /resources/php5/php-cgi not found neither in
plugin org.zend.php.debug.debugger nor in fragments attached to it
How come? Why can't eclipse run the same program that I can run from the
command line? Is it because the zend.php.debugger is x86_5 and I need and
x86_64 one?
Thanks again,
Wendell
Re: pdt php.ini on linux? [message #67048 is a reply to message #67001] |
Sun, 09 March 2008 04:34   |
Originally posted by: michael.zend.com
This error means that file
eclipse/plugins/org.zend.php.debug.debugger.linux.x86_5.2.12 .v20071210/resources/php5/php-cgi
could not be found by the Eclipse.
I guess something is wrong with the installation. What system are you
running on?
Thanks!
> some more help.
> In the directory
> the command line? Is it because the zend.php.debugger is x86_5 and I
> need and x86_64 one?
> Thanks again,
> Wendell
Re: pdt php.ini on linux? [message #67057 is a reply to message #67048] |
Mon, 10 March 2008 13:08   |
I tried putting that in the PATH, but that didn't help.
> running on?
Fedora 7, x86_64
eclipse-SDK-3.3.2-linux-gtk-x86_64.tar.gz
ZendDebugger-5.2.12-linux-glibc23-x86_64.tar.gz
php-5.2.4-1.fc7
php-devel-5.2.4-1.fc7
php-common-5.2.4-1.fc7
php-cli-5.2.4-1.fc7
httpd-2.2.4-4
However, eclipse still complains that it can't find the debugger from the
php.ini.
>> some more help.
>> In the directory
>> Thanks again,
>> Wendell
Re: pdt php.ini on linux? [message #67077 is a reply to message #67057] |
Tue, 11 March 2008 08:48   |
Have you configured mentioned PHP in the "PHP Interpreter" section of
preferences?
Thanks!
>> running on?
> Fedora 7, x86_64
> php-5.2.4-1.fc7
> php-cli-5.2.4-1.fc7
> httpd-2.2.4-4
> the php.ini.
>>> like some more help.
>>> In the directory
>>> Thanks again,
>>> Wendell
Re: pdt php.ini on linux? [message #67105 is a reply to message #67077] |
Tue, 11 March 2008 11:02   |
In the Windows->Preferences->PHP Interpreter it only allows me to choose
PHP Version: 'PHP 5 or greater' or 'PHP 4', I left it at 'PHP 5 or
greater'.
The PHP Executable section had /usr/bin/php in the Executable path, and
PHP Debugger is 'Zend Debugger'. I added another entry with the full path
to the php under the plugins directory. I also added an entry for the
php-ini also. I also used the Search function, which added the PHP4
interpreter to the list.
Still, no change. When I try to run a php script I get
MESSAGE PHP executable /resources/php5/php not found
Thank you again for the suggestions, but I don't have it working yet.
> preferences?
> Thanks!
>>> running on?
>> Fedora 7, x86_64
>> php-5.2.4-1.fc7
>> php-cli-5.2.4-1.fc7
>> httpd-2.2.4-4
>> the php.ini.
>>>> In the directory
>>>> Thanks again,
>>>> Wendell
Re: pdt php.ini on linux? -success [message #67145 is a reply to message #67125] |
Tue, 11 March 2008 15:19  |
> You must select this PHP interpreter in the debug configuration dialog.
That was it. To be precise:
Run -> Open Debug Dialog:
PHP Executable: was /usr/bin/php
I changed it to
/home/..../resources/php5/php
and the debug session begins.
Thank you Michael for your help!
Wendell
Current Time: Sat Jul 19 13:42:52 EDT 2025
Powered by FUDForum. Page generated in 0.05539 seconds
