Home » Modeling » Papyrus » Class Object and Attributes issues(can't set the value of an object's attribute for a class)
Class Object and Attributes issues [message #668425] Thu, 05 May 2011 11:49 Go to next message
Hi !
I'm working with Papyrus 0.7, and with uml2
Here is what i want to do :
A class Transport, with an atribute Distance: Integer.
Now i want to make a class DeliveryA, which own an instance of Transport, with a fixed value of 1000 for Distance.
I'm aiming code generation(with Acceleo), and be able to say that each instance of DeliveryAcreate a new Transport with 1000 in its constructor.
Right now i'm trying to add a Property to DeliveryA, set its type to Transport, and now looking for somethings like a subproperty field, but i'm a bit lost.
And i don't want to use stereotypefor this.
I don't really know if my problem come from a bad understanding of UML or Papyrus, or maybe i'm doing it all wrong ... Can someone help me ?
Thanks !
Re: Class Object and Attributes issues [message #668614 is a reply to message #668425] Fri, 06 May 2011 08:41 Go to previous messageGo to next message
What comes up to my mind is an OCL constraint on the Transport property of DeliveryA. But I don't know if Acceleo can generate what you want from it.
Another option would be to model the constructor of DeliveryA as an operation with the <<Create>> stereotype from the standard profile and to add an appropriate method to it depending on what Acceleo requires, but you said you don't want to use a stereotype.
You could probably ask the Acceleo people, I don't think it depends on Papyrus.
Re: Class Object and Attributes issues [message #668636 is a reply to message #668425] Fri, 06 May 2011 10:12 Go to previous messageGo to next message
Ok thanks i'll have a look on what OCL can do and how.
But isn't here a way in UML2, after building some attribute, to fix its value somewhere ?
I don't understand why i can do that for stereotype's attributes, but not for classes attributes.
Re: Class Object and Attributes issues [message #668766 is a reply to message #668425] Sat, 07 May 2011 03:50 Go to previous messageGo to next message
You could also model an initial value for the class property. That initial value would construc a Transport object with a value of 1000 for Distance.
This would either require a constructor for Transport, or a subclass of Transport (e.g. Transport1000) with an initial value for Distance. In the latter case the class property of DeliveryA would have the type Transport1000.
Re: Class Object and Attributes issues [message #669232 is a reply to message #668425] Mon, 09 May 2011 10:50 Go to previous messageGo to next message
This sounds pretty good !
Just to be sure to understand, by initial value, you mean default Value, right?
Re: Class Object and Attributes issues [message #669426 is a reply to message #668425] Tue, 10 May 2011 06:18 Go to previous messageGo to next message
Yes, or even more precisely: the defaultValue of a Property (class attribute), which is a ValueSpecification object.
Re: Class Object and Attributes issues [message #669448 is a reply to message #668425] Tue, 10 May 2011 07:33 Go to previous messageGo to next message
Ok thanks a lot, it works. The problem was not with Papyrus but about me and UML.
Little question to conclude, in the model explorer, sometimes the Property icon got a little green cross on its bottom-right corner, what does it mean ?
Re: Class Object and Attributes issues [message #672338 is a reply to message #669448] Fri, 20 May 2011 13:53 Go to previous messageGo to next message
this is a decorator to express that your property is public
Re: Class Object and Attributes issues [message #672394 is a reply to message #669448] Fri, 20 May 2011 18:02 Go to previous messageGo to next message
I think that means the property is public.
Re: Class Object and Attributes issues [message #672395 is a reply to message #672394] Fri, 20 May 2011 18:14 Go to previous message
To complete the previous answer on the constant property, you may set to true the isReadOnly meta-property of the Property that should hold a constant value.
Previous Topic:Port and Connectors Question
Next Topic:(no subject)
Current Time: Sat Jul 19 17:59:11 EDT 2025
Powered by FUDForum. Page generated in 0.05267 seconds
