Home » Eclipse Projects » Remote Application Platform (RAP) » Customization and NPE with RAP business theme
Customization and NPE with RAP business theme [message #668131] Tue, 03 May 2011 17:14 Go to next message
First of all thanks for the guys behind the RAP business theme to bring
such a great theme. I am trying to use it in our application (it works
well except one little issue that I describe below) and I have a few
questions:
1) As I read in a previous post, if I want to customize the logo of the
theme, I have to override one of the layout set. In this particular
case, I suppose I need to override the layoutset.logo and create a
class similar to LogoInitializer to provide my own logo, correct?
2) Is there a way to change the margins of the theme (e.g. the left and
right margins inside the browser frame)? If not through extension, I
suppose I would need to modify the theme source itself.
3) When I click on the configuration button of one of my view, I get
the following NPE:
at
org.eclipse.rap.internal.design.example.stacks.Configuration Dialog.loadActionSettings(ConfigurationDialog.java:218)
at
org.eclipse.rap.internal.design.example.stacks.Configuration Dialog.createDialogArea(ConfigurationDialog.java:135)
at
org.eclipse.jface.dialogs.PopupDialog.createContents(PopupDi alog.java:683)
Apparently one of my toolitem doesn't have a contribution item. That is
correct in the sense that I'm adding to the toolbar manager several
ContributionItem items and several IAction items. It works fine with
the default theme so does the business theme doesn't support the
IAction items?
Jean
Re: Customization and NPE with RAP business theme [message #668175 is a reply to message #668131] Wed, 04 May 2011 06:26 Go to previous messageGo to next message
Hi Jean,
please see my comments below.
On 2011-05-03 23:14:51 +0200, Jean Bovet <jean.bovet@oracle.com> said:
> questions:
I suggest that you chek out the org.eclipse.rap.examples project from
our CVS. In this bundle we override the logo. I think you can simply
copy this part.
No, there is no way to modify this via an extension. One possibility
would be to create a new design and use the business theme as base. I
think the
org.eclipse.rap.internal.design.example.business.BusinessWin dowComposer
is the right point to start. You only need to rewrite this one and use
the PresentantionFactory from teh business design.
> the following NPE:
> at
at
at
Apparently
> one of my toolitem doesn't have a contribution item. That is correct in
> IAction items?
This sounds like a bug to me. Can you provide a snippet to reproduce it
and file a bug against the eclips ebugzilla?
Thank in advance.
Cheers Holger
> Jean
Holger Staudacher | EclipseSource Karlsruhe
Need professional support for RAP and RCP?
Go to: http://eclipsesource.com/support
Twitter : @hstaudacher
Blog : http://eclipsesource.com/blogs/tag/rap/
Re: Customization and NPE with RAP business theme [message #668294 is a reply to message #668175] Wed, 04 May 2011 17:28 Go to previous message
Thanks Holger! I will check the examples and will provide a snippet to
reproduce the issue (I'll double check my code first to see if
something obvious can solve that).
Jean
On 2011-05-04 03:26:38 -0700, Holger Staudacher said:
> Hi Jean,
>> Hi,
>> questions:
> copy this part.
> think the
>> the following NPE:
>> at
at
at
Apparently
one
>> of my toolitem doesn't have a contribution item. That is correct in the
>> sense that I'm adding to the toolbar manager several ContributionItem
>> items and several IAction items. It works fine with the default theme
>> so does the business theme doesn't support the IAction items?
> Thank in advance.
> Cheers Holger
>> Thanks,
>> Jean
Previous Topic:How to trace a JS error message reason?
Next Topic:is rap runtime used plugin class
Current Time: Sat Jul 19 20:56:46 EDT 2025
Powered by FUDForum. Page generated in 0.04010 seconds
