Home » Archived » M2M (model-to-model transformation) » [ATL] Support to arbitrary number of output models??
[ATL] Support to arbitrary number of output models?? [message #668106] Tue, 03 May 2011 14:27 Go to next message
I want to develop a transformation that takes one input model but produces a
number of output models that is not known beforehand (i.e. the number of
output models depends on the input model). Is this possible in ATL??
I think it is not possible because in the header of an ATL module you must
declare the output models. If this is the case... is there any work around
for this scenario?
Thanks in advance.
Mario
Re: [ATL] Support to arbitrary number of output models?? [message #668150 is a reply to message #668106] Wed, 04 May 2011 03:17 Go to previous message
You can transform to one model and split the resulting model afterwards using EMF.
Previous Topic:[ATL] "Quick Fix" and syntax checker does not work
Next Topic:[ATL] Using ATL in a "standalone" Software
Current Time: Sat Jul 19 15:57:20 EDT 2025
Powered by FUDForum. Page generated in 0.04570 seconds
