Home » Eclipse Projects » EclipseLink » MOXy: can't xml-bindings xml-transient parent class when it has same name in different package(Class foo.MyOwnGrandpa extends class mumble.MyOwnGrandpa.)
MOXy: can't xml-bindings xml-transient parent class when it has same name in different package [message #667089] Tue, 26 April 2011 12:47 Go to next message
I'm trying to use schemagen with an external <xml-bindings> file.
I can't really touch the classes involved - especially the parent class, which is generated.
If I set xml-transient on the parent class, I get an error out of the AnnotationsProcessor:
Exception Description: Name collision.  Two classes have the XML type with uri  and name myOwnGrandpa.
The bindings file for the mumble package has no effect in this context, because of xml-transient. The bindings passed in to the AnnotationsProcessor are for the child package. So the obvious workaround - change the parent-class xml name or namespace - can't be used.
Am I missing something?
Any suggestions for a workaround?
Should I report this as a bug?
[Updated on: Tue, 26 April 2011 15:06] by Moderator
Re: MOXy: can't xml-bindings xml-transient parent class when it has same name in different package [message #667118 is a reply to message #667089] Tue, 26 April 2011 16:16 Go to previous messageGo to next message
Hi Ed,
Yes, please enter a bug for this issue. You can workaround it using a binding file like the following:
binding-a.xml
In the binding file specify a type name for the transient class. This type will not appear in the generated XML schema:
<xml-bindings
    xmlns="http://www.eclipse.org/eclipselink/xsds/persistence/oxm"
    package-name="example.a">
    <java-types>
        <java-type name="MyOwnGrandpa" xml-transient="true">
            <xml-type name="MyOwnGrandpa2"/>
        </java-type>
    </java-types>
</xml-bindings>
example.a.MyOwnGrandpa
package example.a;
public class MyOwnGrandpa {
example.b.MyOwnGrandpa
package example.b;
public class MyOwnGrandpa extends example.a.MyOwnGrandpa {
example.Demo
package example;
import java.io.File;
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
import javax.xml.bind.JAXBContext;
import javax.xml.bind.SchemaOutputResolver;
import javax.xml.transform.Result;
import javax.xml.transform.stream.StreamResult;
import org.eclipse.persistence.jaxb.JAXBContextFactory;
import example.b.MyOwnGrandpa;
public class Demo {
    public static void main(String[] args) throws Exception {
        Map<String, Object> properties = new HashMap<String, Object>(1);
        properties.put(JAXBContextFactory.ECLIPSELINK_OXM_XML_KEY, new File("src/exanmple/a/binding-a.xml"));
        JAXBContext jc = JAXBContext.newInstance(new Class[] {MyOwnGrandpa.class} , properties);
        jc.generateSchema(new MySOR());
    private static class MySOR extends SchemaOutputResolver {
        public Result createOutput(String arg0, String arg1) throws IOException {
            StreamResult result = new StreamResult(System.out);
            result.setSystemId(arg1);
            return result;
Generated Schema
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
   <xsd:complexType name="myOwnGrandpa"/>
</xsd:schema>
-Blaise
Re: MOXy: can't xml-bindings xml-transient parent class when it has same name in different package [message #667598 is a reply to message #667118] Fri, 29 April 2011 16:14 Go to previous messageGo to next message
Doesn't work for me.
"package-name" attribute isn't in the oxm 2.1 schema - what version is this for?
Also, the binding-file registration appears to be incompatible with that shown in http://wiki.eclipse.org/EclipseLink/Examples/MOXy/GettingSta rted/ExternalizedMetadata, where an intermediate map from package to Source is registered under ECLIPSELINK_OXM_XML_KEY.
Even if it works, I'd guess that setting the package in the root element of a global binding file to the parent's package:
<xml-bindings
    [B]package-name="example.a"[/B]>
would preclude any configuration of classes in the child package - where most of them are.
Re: MOXy: can't xml-bindings xml-transient parent class when it has same name in different package [message #667854 is a reply to message #667598] Mon, 02 May 2011 09:20 Go to previous messageGo to next message
Sorry - stupid me, I thought 2.1 was latest, not sure how. Anyway, I need bindings on multiple packages, so a global oxm file won't work, AFAICT.
Where are the semantics of the oxm binding file documented?
Re: MOXy: can't xml-bindings xml-transient parent class when it has same name in different package [message #667868 is a reply to message #667854] Mon, 02 May 2011 10:25 Go to previous message
Hi Ed,
You can have a bindings file per package. The following describes how to do this using EclipseLink 2.2. This can also be done in EclipseLink 2.1, but the code required is more verbose:
package example;
import java.util.ArrayList;
import java.util.List;
public class Demo {
        List<File> bindingFiles = new ArrayList<File>();
        bindingFiles.add(new File("src/example/a/binding-a.xml"));
        bindingFiles.add(new File("src/example/b/binding-b.xml"));
        properties.put(JAXBContextFactory.ECLIPSELINK_OXM_XML_KEY, bindingFiles);
            return result;
binding-a.xml
In EclipseLink 2.2, the package name can be specified in the bindings file:
<xml-bindings
    <java-types>
        </java-type>
    </java-types>
</xml-bindings>
binding-b.xml
<xml-bindings
    package-name="example.b">
    <java-types>
        <java-type name="MyOwnGrandpa">
            <java-attributes>
                <xml-attribute java-attribute="b"/>
            </java-attributes>
        </java-type>
    </java-types>
</xml-bindings>
-Blaise
Previous Topic:Relationships/FKs to non-PK columns
Next Topic:Working with whole schema
Current Time: Sun Jul 20 15:47:01 EDT 2025
Powered by FUDForum. Page generated in 0.03592 seconds
