Home » Modeling » GMF (Graphical Modeling Framework) » Retrieve connection editpart
Retrieve connection editpart [message #667781] Mon, 02 May 2011 04:29 Go to next message
I'm trying to obtain the editpart of a connection. To find the editparts for elements I use the editpart.findEditPart(Editpart, EObject) function.
However, this does not find editparts for connections. What would be a way to obtain these?
Re: Retrieve connection editpart [message #667951 is a reply to message #667781] Mon, 02 May 2011 19:46 Go to previous messageGo to next message
Hi Adrian,
I assume you are trying findEditPart(getTopGraphicEditPart(), EObject)?
Jevon
Re: Retrieve connection editpart [message #668158 is a reply to message #667781] Wed, 04 May 2011 04:39 Go to previous message
I used the editpart of my diagram element. This had all the model elements as children, but not the links between them. These can be found as source and target connections of the elements.
By editing the findEditPart method I've been able to retrieve the link editparts as well.
Previous Topic:Re: Cannot modify resource set when changing a reference to another model in the platform
Next Topic:Run Configuration for a GMF Diagram
Current Time: Sun Jul 20 06:01:33 EDT 2025
Powered by FUDForum. Page generated in 0.03853 seconds
