Home » Language IDEs » PHP Development Tools (PDT) » Problem with the Apache DefaultHttpClient class(Getting a java.lang.ClassNotFoundException for DefaultHttpClient)
Problem with the Apache DefaultHttpClient class [message #667555] Fri, 29 April 2011 10:07
Hello!
I am a newbie for servlet applications, trying to learn the subject. On my way, I wrote a servlet class called FormWebServlet that uses the org.apache.http.impl.client.DefaultHttpClient class. However, I get the exception
java.lang.ClassNotFoundException: org.apache.http.impl.client.DefaultHttpClient
... that clearly shows that this class does not exist, although I have added the jar file to the project.
The server returns an "HTTP Status 500" error with the message that the "root cause" is this missing class:
java.lang.NoClassDefFoundError: org/apache/http/impl/client/DefaultHttpClient
	testPackage.FormWebServlet.doGet(FormWebServlet.java:45)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
TRIES
1) I searched for the missing jar file and added it to the project (by going on the project in "Eclipse JAVA EE IDE for Web Developers, 20100917-0705"'s project explorer, select "Properties", selected the "Java Build Path" and clicked the [Add External JARs...] button.) The added jar file is from the Apache site and is called httpclient-4.1.1.jar.
2) As I still get the same error, I extracted with 7-ZIP the DefaultHttpClient.class file and put it into the WebContent/WEB-INF/lib directory.
QUESTION
What am I doing wrong?
Notice: If I comment the definition of
HttpClient client = new DefaultHttpClient();
... and try to declare an HttpGet object instead with
			final String ADDRESS = ServletUtilities.getHttpAddress(BAR_CODE);
			out.println("ADDRESS = \"" + ADDRESS + '\"');
			HttpGet get = new HttpGet(ADDRESS);
... I get the same error, but this time for the class HttpGet - both part of the same JAR file.
DETAILS
Inculded JARs:
common-httpclient-3.0.1.jar
httpcore-4.1.jar
FormWebServlet.jar:
package testPackage;
import java.io.IOException;
import java.io.PrintWriter;
import javax.servlet.ServletException;
import javax.servlet.annotation.WebServlet;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import org.apache.http.HttpResponse;
import org.apache.http.client.HttpClient;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.impl.client.DefaultHttpClient;
import coreServlets.ServletUtilities;
@WebServlet(description = "Gets the book's barcode with a form", urlPatterns = { "/FormWebServlet" })
public class FormWebServlet extends HttpServlet {
	private static final long serialVersionUID = 6008315960327824633L;
	 * @see HttpServlet#doGet(HttpServletRequest request,
	 *  HttpServletResponse response)
	protected void doGet(final HttpServletRequest request,
			final HttpServletResponse response)
	throws IOException, ServletException {
		final String BAR_CODE = request.getParameter("barCode");
		response.setContentType("text/html");
		final PrintWriter out = response.getWriter();
		if (BAR_CODE != null) {
			HttpResponse httpResponse = null;
// Removed commented code that will use these objects
Previous Topic:User code folding
Next Topic:My PDT problem
Current Time: Sat Jul 19 16:13:22 EDT 2025
Powered by FUDForum. Page generated in 0.03439 seconds
