delete with deletion of connections to nested shapes [message #664307] |
Fri, 08 April 2011 06:28  |
Hi all,
the default delete behavior is to remove also connections of the deleted shape.
Are the business objects linked with those connections also deleted?
I also have the situation that my shape has child shapes with connections attached.
I'm treating this with
public void preDelete(IDeleteContext context) {
super.preDelete(context);
if (!(context.getPictogramElement() instanceof ContainerShape))
return;
ContainerShape container = (ContainerShape) context.getPictogramElement();
for (Shape child : container.getChildren()) {
for (Iterator<Anchor> iter = child.getAnchors().iterator(); iter.hasNext();) {
Anchor anchor = iter.next();
for (Iterator<Connection> iterator = Graphiti.getPeService().getAllConnections(anchor).iterator() ; iterator.hasNext();) {
Connection connection = iterator.next();
DeleteContext ctx = new DeleteContext(connection);
ctx.setMultiDeleteInfo(new MultiDeleteInfo(false, false, 1));
IDeleteFeature deleteFeature = getFeatureProvider().getDeleteFeature(ctx);
if (deleteFeature!=null)
deleteFeature.delete(ctx);
I use the MultiDeleteInfo to suppress the user question for each connection.
But MultiDeleteInfo is marked @noinstantiate.
Is there a better way to achieve this?
And do I have to care about the connection decorators?
Henrik
Re: delete with deletion of connections to nested shapes [message #667110 is a reply to message #664307] |
Tue, 26 April 2011 15:05  |
Hi guys, I did it by following (and adapting) Henrik 's solution:
I mainly extended the DefaultDeleteFeature and Override the method preDelete:
public class MyOWNDefaultDeleteFeature extends DefaultDeleteFeature {
return;
for (Iterator<Anchor> iter = container.getAnchors().iterator(); iter.hasNext();) {
For people that are not expert (e.g. myself), remember that you need also to call your MyOwnDefaultDeleteFeature in your FeatureProvider
public IDeleteFeature getDeleteFeature(IDeleteContext context) {
else {
Util.log("BIMFeatureProvider: calling MyOwnDefaultDeleteFeature for "+context,true);
return new MyOwnDefaultDeleteFeature(this);
Maybe, there is a better solution, but at least this seems work for me.
Thanks for your help and support!
D.
[Updated on: Tue, 26 April 2011 15:07] by Moderator
FUDForum. Page generated in 0.03996 seconds
