Home » Eclipse Projects » Eclipse Platform » Can't run my Eclipse project(Google Plugin)
Can't run my Eclipse project [message #666923] Sun, 24 April 2011 11:27 Go to next message
I'm using Eclipse 3.6.2 with the latest version of the Google Plugin on Ubuntu 10.10. I've been developing with this combination successfully for some time, and all of a sudden, I cannot run or debug my project. I can, however, debug/run a new GWT project created with the Google Plugin. Just to be sure, I reinstalled Eclipse and the Google Plugin, and recreated my project.
In my project, when I attempt to debug it, the Google "Development Mode" panel opens.
At the top of that panel, my project's name is displayed in a tree structure. If I click on that, it opens up a single node, again with the project name.
Immediately below that panel, the message, "Double-click to open a URL (or right-click for more options). Click the yellow 'Reload web server' button above after server-side code changes.
There is a sub-panel below this, but nothing is displayed in it.
If I click on the above tree structure, nothing happens.
If I click on the "Reload web server" button, I get an error, "Unable to reload the web server. See the Error Log for details." The error log contains:
java.lang.RuntimeException: java.util.concurrent.ExecutionException: com.google.gwt.dev.shell.remoteui.MessageTransport$RequestEx ception: Unable to restart the web server. It is still in the process of starting up. Wait a few seconds and try again.
at com.google.gwt.eclipse.oophm.devmode.DevModeServiceClient.wa itForResponse(DevModeServiceClient.java:106)
at com.google.gwt.eclipse.oophm.devmode.DevModeServiceClient.re startWebServer(DevModeServiceClient.java:93)
at com.google.gwt.eclipse.oophm.views.hierarchical.WebAppLaunch View$ReloadServerAction$1.run(WebAppLaunchView.java:268)
at java.lang.Thread.run(Thread.java:636)
Caused by: java.util.concurrent.ExecutionException: com.google.gwt.dev.shell.remoteui.MessageTransport$RequestEx ception: Unable to restart the web server. It is still in the process of starting up. Wait a few seconds and try again.
at java.util.concurrent.FutureTask$Sync.innerGet(FutureTask.jav a:252)
at java.util.concurrent.FutureTask.get(FutureTask.java:111)
at com.google.gwt.eclipse.oophm.devmode.DevModeServiceClient.wa itForResponse(DevModeServiceClient.java:104)
... 3 more
Caused by: com.google.gwt.dev.shell.remoteui.MessageTransport$RequestEx ception: Unable to restart the web server. It is still in the process of starting up. Wait a few seconds and try again.
at com.google.gwt.dev.shell.remoteui.MessageTransport.processFa ilure(MessageTransport.java:371)
at com.google.gwt.dev.shell.remoteui.MessageTransport.processMe ssage(MessageTransport.java:389)
at com.google.gwt.dev.shell.remoteui.MessageTransport.access$40 0(MessageTransport.java:45)
at com.google.gwt.dev.shell.remoteui.MessageTransport$2.run(Mes sageTransport.java:309)
... 1 more
I am completely confused about what is happening here. I've been doing development with this combination of software for over a year, and now cannot get it to work at all. Please help if you have an idea of what's gone wrong. Thanks.
Re: Can't run my Eclipse project [message #667105 is a reply to message #666923] Tue, 26 April 2011 14:23 Go to previous messageGo to next message
I didn't find a solution, so I decided to restore a backup project and copy over all new source files. I don't know what happened, but it works again.
Re: Can't run my Eclipse project [message #755437 is a reply to message #666923] Tue, 08 November 2011 09:15 Go to previous message
I had the exact same thing happen to me just now. But i found out what it was:
it happened after a change to the gwt.xml. I was too quick to paste something from the web in there and there was an error in the xml. After changing it everything worked again.
Previous Topic:Project with RSE local location does not open on start-up
Next Topic:Viewer with editing support and properties view
Current Time: Sat Jul 19 23:53:26 EDT 2025
Powered by FUDForum. Page generated in 0.04081 seconds
