Home » Modeling » GMF (Graphical Modeling Framework) » [SOLVED] How to programmatically set the location of a label?((Strategy for no overlapping figures))
[SOLVED] How to programmatically set the location of a label? [message #666802] Fri, 22 April 2011 12:25 Go to next message
I've programmatically added two labels on my edge, but now I would like to implement something in order to set the location of my labels in a clever way.
I want them close to the first and last point of the edge, but I want them not overlapping the nodes at the end of it.
I also want them to be relocated when I move the nodes at the end of the edge.
So nothing fancy, only a standard strategy for placing a labels.
But I can't figure out how to do it.
For now I can place them close to the edge ends like this (where edgeFigure is the PolylineConnectionEx figure of the edge) :
targetRoleLabel = new WrappingLabel();
targetRoleLabel.setText(relDef.getTargetRole() + " [" + relDef.getTargetCard() + "]");
Point labelPoint = new Point(edgeFigure.getEnd().x - X_OFFSET, edgeFigure.getEnd().y - Y_OFFSET);
targetRoleLabel.setLocation(labelPoint);
edgeFigure.add(targetRoleLabel);
So I should find a smarter way to define the Point argument for the setLocation(Point p) method.
So if you have any hint it would be very welcome Smile
Have a nice day,
Xavier
[Updated on: Wed, 27 April 2011 05:38] by Moderator
Re: How to programmatically set the location of a label? [message #667188 is a reply to message #666802] Wed, 27 April 2011 05:36 Go to previous message
I found the solution thanks to that GEF tutorial : http://www.eclipse.org/articles/Article-GEF-Draw2d/GEF-Draw2 d.html
I use the ConnectionEndPointLocator to locate the label at the end and at the start of my connection.
Here is an example for placing a label at the start (source) of my connection.
PolylineConnectionEx edgeFigure = (PolylineConnectionEx) getFigure();
WrappingLabel sourceRoleLabel = new WrappingLabel();
sourceRoleLabel.setText("My Label");
ConnectionEndpointLocator sourceRoleLocator = new ConnectionEndpointLocator(getFigure(), false);
sourceRoleLocator.setVDistance(15);
edgeFigure.add(sourceRoleLabel, sourceRoleLocator);
You can do the same for placing a label at the end (target) of your connection passing "true" as second argument in the ConnectionEndpointLocator constructor.
For my purpose I put that code in the refreshSourceDecoration() I override in my CustomConnectionEditPart.
Hope this will help people facing the same question.
Xavier
Previous Topic:Refresh RootEditPart
Next Topic:AbstractViewProvider.getCreationMethod getting the wrong method when creating a Diagram
Current Time: Sat Jul 19 11:28:34 EDT 2025
Powered by FUDForum. Page generated in 0.03580 seconds
