Home » Eclipse Projects » Rich Client Platform (RCP) » Dynamic cacading menu items
Dynamic cacading menu items [message #663624] Tue, 05 April 2011 18:03 Go to next message
I would like to create dynamic cascading menu items as follows:
When the user hovers over menu item A, it shows dynamic sub menu items b1, b2 and b3. On hovering over b1, it will show dynamic sub menu items c1 and c2 (similarly for b2 and b3). Is it possible to create a dynamic submenu under a dynamic submenu item? If so, is there an example?
Thanks!
Re: Dynamic cacading menu items [message #663758 is a reply to message #663624] Wed, 06 April 2011 08:33 Go to previous messageGo to next message
Keep in mind that multiple cascading menus are a poor UX design pattern.
That being said, where are you trying to create them? Main menu? view
menu? context menu?
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Dynamic cacading menu items [message #663929 is a reply to message #663758] Wed, 06 April 2011 16:28 Go to previous messageGo to next message
I am trying to create them in Menu.
Thanks!
Re: Dynamic cacading menu items [message #664084 is a reply to message #663929] Thu, 07 April 2011 08:48 Go to previous messageGo to next message
That wasn't one of the 3 choices I could identify, so you'll have to be
more descriptive :-)
Or do you mean you have an SWT Menu, and you'd like an SWT snippet?
PW
Paul Webster
Re: Dynamic cacading menu items [message #664760 is a reply to message #664084] Mon, 11 April 2011 16:56 Go to previous messageGo to next message
Ok...This is what I wish to do.
I have added a menu under "Project". I am adding a new dynamic under the menu. Under dynamic I add a new class which extends CompoundContributionItem. This would look something like
org.eclipse.ui.menus
|==== menu:project?after=additions (menuContribution)
|==== <menu> (menu)
|==== <dynamic> (dynamic)
|==== <CompoundContributionCommand> (class)
I override getContributionItems() in my class which returns contribution items. Each of these items return other contribution items thus making it a dynamic cascading menu. I was wondering if there is a way to do it or if I could find a snippet somewhere.
Thanks for your help.
Re: Dynamic cacading menu items [message #664882 is a reply to message #664760] Tue, 12 April 2011 07:22 Go to previous messageGo to next message
> |==== <menu> (menu)
From your CompoundContributionItem you can create MenuManagers and fill
them in with further CommandContributionItems or more MenuManager
(creating a cascading menu structure).
A MenuManager is an IContributionItem.
PW
Paul Webster
Re: Dynamic cacading menu items [message #665280 is a reply to message #664882] Thu, 14 April 2011 02:16 Go to previous messageGo to next message
Thank you very much for your help! It worked.
I have one more question pertaining to this. If I want to change the style of menu item (from SWT_PUSH to SWT_CHECK), can I change it on the MenuManager? I am returning menu managers in getContributionItems. Is there any way to do it in my scenario?
Thanks!
Re: Dynamic cacading menu items [message #666733 is a reply to message #665280] Thu, 21 April 2011 22:03 Go to previous message
I do not think it works,from SWT_PUSH to SWT_CHECK is not property change,it is native resource change of OS
Previous Topic:Completely lost.... any ideas? (Unable to launch application - errors attached)
Next Topic:Re-Exporting external library best practice
Current Time: Sat Jul 19 08:02:45 EDT 2025
Powered by FUDForum. Page generated in 0.04115 seconds
