Home » Modeling » TMF (Xtext) » How to transform xText to XMI
How to transform xText to XMI [message #666060] Mon, 18 April 2011 16:29 Go to next message
xText comes with a snazzy ecore inference model that can take a grammar and guess a suitable eCore model for it. However, after I write a short program conforming to this grammar, I found that I still needed to write xpand templates to transform this to text!
Is there a way to turn the textual program in my specified grammar into an XMI (or similar) file conforming to the inferred ecore model?
Thanks!
Re: How to transform xText to XMI [message #666091 is a reply to message #666060] Tue, 19 April 2011 01:44 Go to previous messageGo to next message
if you work e.g. with a programmatically read model it is actually an model instance based on the generated ecore.
How you can read in the model files standalone you can find in the docs section Processing Xtext Models.
If you still need an XMI Feel free to move the contents of the read Xtext Resource to and XMI Resource.
ResourceSet rs = new ResourceSetImpl();
Resource resource = rs.getResource(URI.createURI("./mymodel.dmodel"), true);
EObject eobject = resource.getContents().get(0);
//create xmi resource
Resource xmiResource = ....
xmiResource.getContents().add(eobject);
//persist xmi resource
~Christian
[Updated on: Tue, 19 April 2011 01:50] by Moderator
Re: How to transform xText to XMI [message #666101 is a reply to message #666091] Tue, 19 April 2011 03:07 Go to previous messageGo to next message
Hi Christian
This is an area where I feel that Xtext has been too clever.
You can open an Xtext CS file in the Sample Ecore Editor and see the
tree view, but if you then do SaveAs *.xmi, the result is saved as CS
text rather than XMI text. Somehow Xtext has higher priority than XMI.
It would be nice to have this interactive approach work fully.
Ed Willink
On 19/04/2011 06:44, Christian Dietrich wrote:
> true);
> xmiResource.getContents.add(eobject);
> ~Christian
Re: How to transform xText to XMI [message #666121 is a reply to message #666101] Tue, 19 April 2011 04:13 Go to previous messageGo to next message
Hi Ed,
this seems to be a bug in the sample Ecore editor, which renames the
resource's URI rather than creating a new one with the extension from
the new URI, if it's not a conversion between "ecore" and "emof":
(EcoreEditor.doSaveAs)
if (currentExtension.equals(ECORE_FILE_EXTENSION) &&
newExtension.equals(EMOF_FILE_EXTENSION) ||
currentExtension.equals(EMOF_FILE_EXTENSION) &&
newExtension.equals(ECORE_FILE_EXTENSION))
Resource newResource = resourceSet.createResource(newURI);
newResource.getContents().addAll(currentResource.getContents ());
resourceSet.getResources().remove(0);
resourceSet.getResources().move(0, newResource);
else
currentResource.setURI(newURI);
Jan
Am 19.04.11 09:07, schrieb Ed Willink:
> Hi Christian
> Regards
> Ed Willink
>> Hi,
>> true);
>> ~Christian
Re: How to transform xText to XMI [message #666303 is a reply to message #666091] Tue, 19 April 2011 16:02 Go to previous messageGo to next message
Hi Christian,
Thanks a lot for the speedy response!
This works. Would be nice if the feature was part of the generated tooling rather than something you had to implement manually (eg some button that says "Save as XMI" in the generated UI).
Just for completeness this is the code I used with holes left out:
XMIResourceFactoryImpl resFactory = new XMIResourceFactoryImpl();
URI xmiuri = URI.createFileURI("blabla/bla/output.xmi);
XMIResource xmiresource = (XMIResource) resFactory.createResource(xmiuri);
xmiresource.getContents().add(app);
xmiresource.save(new HashMap());
where "app" is the resource that represents my model. Should be obvious to EMF pros but took me some time to figure out.
Re: How to transform xText to XMI [message #666310 is a reply to message #666303] Tue, 19 April 2011 16:35 Go to previous messageGo to next message
Regarding the "to xmi" Button. Since the model files are a texual persistence of the ecore Based model and the xmi files are a xml based persistence the only difference is the way of persisting. So there is usually no need for a transformation except some special usecases e.g. If you want deploy the Models to somewhere where Xtext is Not available.
Regards, Christian
Re: How to transform xText to XMI [message #697619 is a reply to message #666310] Sun, 17 July 2011 09:08 Go to previous messageGo to next message
Currently I too use this approach, save it as .xmi, which is then read by eg. ATL (in an ant based transformation sequence).
Christian, do you still think there is need for m2m transformations, that read the xtext-generated xmi model, and transform it, followed by an eventual XPand transformation to text?
Because this is my current approach (ie. I have an MDA that generates webapps). Allthough I don't use any expressions in my model, just declarative structural stuff, and generate 'defaults' in terms of behaviours, so for that purpose I'd say the XTend thing is very useful.
I wonder what your opinion is about this.
Re: How to transform xText to XMI [message #697625 is a reply to message #697619] Sun, 17 July 2011 09:27 Go to previous messageGo to next message
Hi, if you need an M2M depends on your usecase Wink if you use Xtend, Xpand, ATL, Acceleo or any other M2M/M2T Tech depends on your usecase too. And of course on your person knowledge of the technologies. As itemis guy i of cource would't like to see you using Xtend(2)
~Christian
Re: How to transform xText to XMI [message #697825 is a reply to message #697625] Mon, 18 July 2011 02:59 Go to previous messageGo to next message
Yeah okay, thanks for the reply.
I was thinking about it, and what is an advantage of my approach is that with the m2m step you can lower the abstraction level very much. Would it make sense to use XTend2 AFTER a m2m step? (is that even possible? Just kind of 'thinking out loud at the moment')
Re: How to transform xText to XMI [message #697855 is a reply to message #697825] Mon, 18 July 2011 03:06 Go to previous message
Hi, as far as the m2m target metamodel is emf based and you ve got
Java classes for it this should be no problem. You can even use
Xtend2 for the m2m itself.~Christian
Previous Topic:Nomenclature question about Parser Rules
Next Topic:Xtext from 2 ecore files
Current Time: Sat Jul 19 22:30:55 EDT 2025
Powered by FUDForum. Page generated in 0.05143 seconds
