Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » HBSessionDataStore.initialize() / reinitialize?
HBSessionDataStore.initialize() / reinitialize? [message #665945] Mon, 18 April 2011 05:40 Go to next message
I need to reinitialize the HBDataStore. But how?
I found that the reinitialize method has been removed on purpose:
http://dev.eclipse.org/newslists/news.eclipse.technology.emf t/msg04326.html
Indeed, calling the initialize method twice seened to work with teneo
prior to 1.0.1. I recently upgraded the teneo version I use.
From 1.0.1 it throws a DuplicateMappingException.
Perhaps becouse the org.hibernate.cfg.Mappings checks to see it the
class to be added has already been added.
The use case is this: I initialize a HBDataStore, read from database
some data and with that data I create dynamic classes that I add to the
set of EPackages and I would like to reinitialize so that I can use
those new mappings.
Please advice
Liviu
[Teneo] Re: HBSessionDataStore.initialize() / reinitialize? [message #665946 is a reply to message #665945] Mon, 18 April 2011 05:43 Go to previous messageGo to next message
Sorry for forgetting to put [Teneo] in subject bar.
On 18/04/11 12:40, Liviu Negrila wrote:
> Hello,
> those new mappings.
> Please advice
> Thanks
> Liviu
Re: [Teneo] Re: HBSessionDataStore.initialize() / reinitialize? [message #665949 is a reply to message #665946] Mon, 18 April 2011 05:48 Go to previous messageGo to next message
I'm using:
EMF Teneo Hibernate Runtime 1.1.2.v201011050935
Hibernate 3.3.2GA
>> Hello,
>> those new mappings.
>> Please advice
>> Thanks
>> Liviu
Re: [Teneo] Re: HBSessionDataStore.initialize() / reinitialize? [message #665951 is a reply to message #665949] Mon, 18 April 2011 05:51 Go to previous messageGo to next message
With org.eclipse.emf.teneo.hibernate_1.1.1.v200909151729 I can call
initialize multiple times.
With 1.1.2 I can't.
How can I reinitialize with 1.1.2 ?
On 18/04/11 12:48, Liviu Negrila wrote:
> I'm using:
> Hibernate 3.3.2GA
>>> Hello,
>>> those new mappings.
>>> Please advice
>>> Thanks
>>> Liviu
Re: [Teneo] Re: HBSessionDataStore.initialize() / reinitialize? [message #665968 is a reply to message #665951] Mon, 18 April 2011 07:52 Go to previous messageGo to next message
I did two things to be able to reInitialize:
1) I forced the Configuration reference be null on initialization:
I extended the HbDataStoreFactory and I overrriden the intialize method:
public void initialize() {
setConfiguration(null);
super.initialize();
2)
Also, rigth before calling the dataStore.initialize(), I reset the
hibernate properties I've used on first initialization on the datastore:
dataStore.getProperties().clear();
dataStore.setProperties(hibernateProperties);
dataStore.initialize();
Hope not to be sorry for this ugly hack later on.
Please advice
Liviu
> With 1.1.2 I can't.
>> I'm using:
>> Hibernate 3.3.2GA
>>>> Hello,
>>>> those new mappings.
>>>> Please advice
>>>> Thanks
>>>> Liviu
Re: [Teneo] Re: HBSessionDataStore.initialize() / reinitialize? [message #666131 is a reply to message #665968] Tue, 19 April 2011 04:59 Go to previous message
Hi Liviu,
Thanks for reporting this, not an ugly hack at all. I solved the issue following your approach and published a new build
which contains it. Let me know if the new build does not solve it...
gr. Martin
> @Override
> super.initialize();
> 2)
> Also, rigth before calling the dataStore.initialize(), I reset the hibernate properties I've used on first
> Please advice
> Liviu
>> With 1.1.2 I can't.
>>> I'm using:
>>> Hibernate 3.3.2GA
>>>>> Hello,
>>>>> those new mappings.
>>>>> Please advice
>>>>> Thanks
>>>>> Liviu
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:[EMF compare]
Next Topic:[Teneo] HbDataStore.reinitialize()
Current Time: Sat Jul 19 08:24:59 EDT 2025
Powered by FUDForum. Page generated in 0.04198 seconds
